oxorockmanoxo
Everything posted by oxorockmanoxo
i tried to document as much as i can. please dont judge the methods or the workmanship on my project. for the amount of time and tools i had available at the time, i am actually very proud of my work. hope this helps any of you that have been thinking about ever doing this conversion. this is my first how-to ever, i just hope it helps. also, although reversing the sides, i will refer to everything as passenger/driver side as the side they were on originally. i hope you dont get confused. there alot of pics, and i apologize if they are too big or if they slow your comp down. ----------------------------------------------------------------------------------- first. i would like to informally thank DJpowerHaus for his comment and help in this forum: http://www.starquestclub.com/forums/viewto...p;highlight=rhd. then i also got alot of information from here: http://home.exetel.com.au/starion/steering_conversion.htm. i also so far have used all original parts. the car steers great and stops very well, without importing anything. i decided to either hack the original dash, or even perhaps custom make an aluminum one. this project is actually not that expensive to accomplish, just very time consuming. ----------------------------------------------------------------------------------- first off, you will need to pull out the motor. then you will need to remove anything and everything from the front seats forward: seats, dash, consoles, steering column, etc. you will also need to remove the abs and all a/c components, you will no longer be able to run the a/c or abs if pursuing this conversion (im sure you can of course, just more work for you, i wasnt running either on my other starion already, so i dont plan on running them on this one either). it may also be easier to remove the windshield wiper motor, but can be put back in after installing the throttle cable and brake booster. i was unable to document this process as this car was already gutted completely and only had a mock-up 4g64 installed, which was easily removed. ----------------------------------------------------------------------------------- with the engine gone, i first cut a hole out in the passenger wheel well right next to the frame well. part of the wheel well will also be needed to be pounded out from the engine bay side to fit the steering box. http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1147.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1151.jpg ----------------------------------------------------------------------------------- take off the relay rod from both the steering box side and idler arm. remove the castleated nuts and pound the joints off. becareful not to mess up the nut, threads, or joint. with those off, the relay rod and tie rod ends should droop down out of the way easily. http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1149.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1150.jpg ----------------------------------------------------------------------------------- i then removed the three bolts hold the steering box and idler arm to the frame rails. the bolt locations are identical on both sides. the nut is not welded to the rail so will need to be held with a socket. http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1148.jpg ----------------------------------------------------------------------------------- here it is with the steering box and idler removed. http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1152.jpg ----------------------------------------------------------------------------------- you then slide the steering box through the hole cut in the wheel well so that it will bolt to the frame rail from inside the wheel well exactly as the idler arm was. then you bolt the idler arm on the drivers side on the inside of the frame rail just as the steering box used to be. essentially, you just swapped the two items. http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1153.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1154.jpg ----------------------------------------------------------------------------------- re-attach the relay rod to the steering box and idler arm. here it is up to this step. http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1155.jpg ----------------------------------------------------------------------------------- inside the cabin, remove the throttle pedal assembly entirely: pedal, cables (throttle and cruise), mounting bracket. under the hood, remove the bracket holding the the brake resovoir and unbolt the master cylinder from the brake booster. do not remove any brake lines as to keep as much fluid in the system as possible. the lines should be allow to move the master forward enough to remove the booster. inside the cabin again, remove the cotter pin holding the pedal to the brake booster piston. then unbolt the brake booster. the bracket holding the brake pedal is also held on by the nuts of the booster, and should come off when the 4 nuts are removed. pull away the bracket. (STEPS NOT PICTURED...SORRY) under the hood again, remove the brake booster. here it is with the brake booster removed from both sides. http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1168.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1166.jpg ---------------------------------------------------------------------------------- as you can see here from under the hood, the steering column should almost fit exactly through the a/c hole already in the firewall. the brake booster will need to be mounted where the abs modulator was, so the bracket will need to be removed (the clutch master also mounts there, so remove the brack completely and cleanly). inside, i used the steering column boot to outline the size needed to cut for the actual steering column. then i used the brake pedal bracket and held it up to where it matched with the outline as it originally did on the drivers side. i then outlined the holes for the brake booster by using the bracket. (NO PICS AGAIN) with those outlined, i then cut the holes needed and drilled holes for the bolts of the brake booster. here it is from both sides with everything cut out. http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1169.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1170.jpg --------------------------------------------------------------------------------- make sure the wheels are as straight as you can get them. reinstall steering column making sure it is also as straight as possible. http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1171.jpg --------------------------------------------------------------------------------- i used a makeshift corner bracket to loosely hold the brake pedal bracket up so i could line it up with the brake booster. make sure you line up the pedal with the bracket on the piston. with everything lined up and in place, fully tighten and install the brake assemblies. with the brake bracket installed, you can then mount the rest of the steering column together onto the brake pedal bracket. http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1172.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1174.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1175.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1173.jpg --------------------------------------------------------------------------------- inside the cabin, for the throttle pedal, there is a little hump on the inside of the wheel well that is just about the right height and distance away from the brake pedal to mount the bracket. holding the bracket up, i marked the position of the holes and drilled into the wheel well. http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1177.jpg --------------------------------------------------------------------------------- because that hump sticks out further than the firewall, you will have to bend the pedal backwards to match it with the level of the brake pedal. to get the height correct, i notched the original holes of the bracket so i could adjust pedal height and just tighten it fully when mounted. (PICTURES NOT OF COMPLETE BENDING AND NOTCHING. IT REQUIRED TO BE BENT A BIT FURTHER AND TO BE NOTCHED TO MOVE IT HIGHER.) http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1178.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1179.jpg ---------------------------------------------------------------------------------- to mount the throttle cable there is a position to the right of the brake pedal bracket on the firewall that slopes in. i drilled holes and mounted the throttle cable so that from under the hood the cable goes up and towards the drivers side. fully mount the the cable and connect it to the pedal. http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1180.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1182.jpg ---------------------------------------------------------------------------------- inside, disconnect the clutch pedal from the piston and remove the lower nut holding the clutch master. (NOT PICTURED) under the hood, remove the clutch line and plug the master and the line to not lose fluid and make so much of a mess. then remove the bolt holding the clutch resovoir. take off the nut holding the top of the clutch master and slide it outward and remove the master completely. http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1183.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1184.jpg ---------------------------------------------------------------------------------- inside, remove the two bolts holding the clutch pedal bracket up. try to hold the bracket up on the other side in relation to the brake pedal and mark the firewall where to drill and cut holes so that it matches (not mirrors) the original holes on the drivers side. http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1185.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1186.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1187.jpg ---------------------------------------------------------------------------------- mount the clutch pedal bracket. first put it up loosely. is used a bracket i found (i dont know the name of the bracket, but i just went to ace hardware and picked up about 6 ft of the material. hopefully you know what it is after seeing the pics). with that up, you can put up the clutch master and begin to slowly tighten everything. make sure that the pedal is lined up with the piston, tighten everything up. http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1190.jpg under the hood, loosen the bottom half of the clutch resovoir on the top of the master so you can swivel it around. mount it to the firewall. here it is up to this point from the inside and out. http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1189.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1188.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1192.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1193.jpg ------------------------------------------------------------------------------------- according to the webpage link i provided, you can cut off and re-weld the steering support onto the other side. i however, do not have a welder handy, and of the few times i have welded, i am not the best. http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1168.jpg so going back to the bracket i bought at ace, i made my own steering support. i did cut the original support out, but only to fit the support that i made. i hope that pics will be able to speak for themselves on how to do this. http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1270.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1271.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1269.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1280.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1279.jpg -------------------------------------------------------------------------------------- disconnect all hydraulic lines from the brake master. you can leave the resovoir still connected. bolt it on to the booster. loosen the caps on the master to rotate them to be able to mount the resovoir on the opposite side of the master now. also loosen the rubber hoses to be able to rotate them so there will be no kinks. bolt the resovoir onto the firewall. http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1276.jpg for the break and clutch lines, i used most all the original lines. of course you can put all new lines, but i was on a budget and did not find it to be a life or death situation. first i removed the line originally coming from the brake master going to the abs modulator. i then used the line originally going to the r/f wheel for use on the l/f wheel now. i disconnected the end going to the caliper and reconnected it to the master for the l/f wheel. on the other end of that line, i bought a brake line coupler and attatched that end to the original l/f line. http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1274.jpg for the r/f line, this was the only new line i bought. i bought a 15" line and installed it to the line going to the caliper and then to the master. http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1275.jpg i then took the line still connected to the rear portioning valve and attatched the other end directly into the port of the master that originally went to the abs modulator. http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1276.jpg for the clutch i just reused the old line. i rebent it and fit it and just connected it to the clutch master. http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1277.jpg then just bleed the crap out of everything. ---------------------------------------------------------------------------------------- here it is with the lines, steering support, and everything up to this point. http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1273.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1278.jpg ---------------------------------------------------------------------------------------- in the end, everything works great. i just moved, and instead of getting a trailer, i just used some chains and pulled it across town. car steered great and stopped very well. like i said, this car came gutted and had no real motor. all the work above took me a good 10-12 hours split into 4 days. should be a while until any more major work. ill keep it updated as it happens. thanks for looking. - adrian
i concur
hahaha. my bad. i was gonna say i had a drivers side star tail light. so i go out and look and i do. but then i realized my drivers side is your pass side. and the one you are looking for that i have is cracked. sorry man. heres a pic to show the differences. star on top. quest on bottom. http://i32.photobucket.com/albums/d13/oxorockmanoxo/sqlights.jpg hope that helps. goodluck. ill let you know if i come across any tail lights. - adrian
oxorockmanoxo's '87 ESI-R: greenstar
oxorockmanoxo replied to oxorockmanoxo's topic in StarQuest Showroom
with the break in the rain and my need to move the car to a new garage, i got the break master moved over, break resovoir mounted, break lines in, clutch line in, fluids bled, and steering support in. so breaks are fully functional now as well as the clutch and steering. as soon as i get it garaged, gonna start taking body panels off and start working on the motor, finally. http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1273.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1278.jpg im guessing powerball is like lottery? im doing this conversion with all original parts. the only things i bought was one break line, i was able to reuse all old lines, i got new ones, but when i found i didnt need them, i just returned them all but one. oh, i also bought some hardware to support the steering column. i know ill have to buy some more stuff cause i want to make a dash, but that wont be for a while. but im saying is the conversion is pretty cheap to do. just time consuming. - adrian -
sorry man. no updates. i had finals, then christmas, then new years, and now im moving again. i thought that i was gonna have to get rid of it too. but im not. ill find somewhere to keep her. gotta get rid of the 4g64 though and some other parts that i have stored here. ill start working on her again maybe mid jan. like i said, i dont want it on the road in less than two years. gonna take alot of time with this. ill keep you all posted though. - adrian -
my brothers quests paintjob is complete (slidertsi)
oxorockmanoxo replied to idriftnaked707's topic in StarQuest Showroom
ya. i been there a couple of times. left cards and numbers. didnt know that was your place, or your parents at least. we can all meet up sometime for sure. - adrian -
they have one already. its been up for a while. http://www.starquestclub.com/forums/viewtopic.php?t=63534 get with it scott. sheeesh. - adrian
oh ya, what is "ftw"??? -
no. everything is the same. imagine that i just moved everything straight over to the passenger side, which is more or less what i did exactly. you can see in the pics, the ignition is still on the right side and the turn signals are still on the left side. like i said, im doing a write up and dont want to post anything until it is complete. the steerening column has a good amount of support right now, but i want to make a better support bracket for it for safety reasons. then all i need are to get brake/clutch lines. other than the dash, the conversion will be done after those things. - adrian -
sponsors. or something to that extent. ill end up getting the parts i want anyways. but if i can get them for free or cheap just by promoting them. im all for it. just thought id give it a try. im not keeping my hopes up. but it would be nice. - adrian my car: http://www.starquestclub.com/forums/viewtopic.php?t=68096
actually got to do some work this past week. just a little teaser of whats to come. the conversion is about 75% done. ive been documenting everything and am doing a how-to on the conversion. - adrian http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1188.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1189.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/sq%20rhd%20conversion/CIMG1192.jpg -
if you are have an 86. car should run without the mas plugged in or even installed. if it is down, i would look to something else being suspect. running with no mas doesnt work for all 86s though as i have seen (depends on mods you have installed). but for the most part, should idle and drive fine without it. - adrian
so i guess youre not thinking about selling it no more? good job. - adrian
Starquest Parted out - UPDATED - California - PICS
oxorockmanoxo replied to NorcalTsi's topic in Parts for sale
how much for just the driver quarter? i can pick it up. - adrian -
after doing quite a bit of research and really examining my obligations. i think that the best way, and fastest way to get my starion back on the road is to stick with the g54b. i would have liked to and still want to eventually do this swap, but i dont think it will be any time soon. and i dont really want to have this block sitting in my garage. its a bare 4g64 block that has been fully machined, honed, decked, cleaned and ready for assembly (no crank, rods, pistons, bearings, etc.). its got a 4g63 turbo head (head is bad), motor mounts, and oil pan which was put in the car for fitment issues only. block fit in great and tranny bolted up perfectly. dont really know what its worth or how to price on it. i was just seeing what others might think its worth and what kind of demand there is out there for this. im not trying to get rich off it and i know for sure that i am up for trades. thanks for looking. engine stamp: 4g64 mv8864 http://i32.photobucket.com/albums/d13/oxorockmanoxo/greenstar/CIMG1127.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/greenstar/CIMG1128.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/greenstar/CIMG1129.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/greenstar/CIMG1130.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/greenstar/CIMG1131.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/greenstar/CIMG1132.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/sell/4g64/CIMG1139.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/sell/4g64/CIMG1142.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/sell/4g64/CIMG1143.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/sell/4g64/CIMG1145.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/sell/4g64/CIMG1146.jpg - adrian
how much if i pick it up? thanks taki. - adrian
i know, i remember. they gave me the shell, motor, and radiator. they were gonna take the motor out, but got lazy and said i could have it. i sold the gunmetal one a couple weeks back. guy came from utah and drove it home. kinda sad, wish i still had my car, or a running sq at least. patience is key though i guess. - adrian -
for the time being, ya, its my dd. it aint no sq, but itll do for now. - adrian -
well, like i said i want the paint to be forest green. imma do doorjams and engine bay flat black. havent quite decided on the interior, but if i do, i want to the tan leather interior. thanks for the offer jack, but im really into the 88/89 style seats. then i really think imma stick with the 4g64. and also, i really dont plan anything soon, 2 years at least. of course ill post pics and what not along the way. - adrian -
i want to say thanks to newlogics in san pablo for hooking me up with this car. its an 87 shell, has a 4g64 already in and a custom aluminum radiator. i havent deicided if im going to keep the 4g64 or put in my g54b. well see. i really didnt plan on having it road ready for at least 2 years, even before i got the other motor. but the body is straight for the most part, no rust, looks like they got into a fender bender with the l/r quarter panel and l/f fender too. but all in all, its gonna be a good project, and i really wanted to say thanks to newlogics for helping me out. oh ya, it aint green yet, but i want it to be forest green like my very first one. so ill just stick with the name. http://i32.photobucket.com/albums/d13/oxorockmanoxo/greenstar/CIMG1118.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/greenstar/CIMG1119.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/greenstar/CIMG1120.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/greenstar/CIMG1121.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/greenstar/CIMG1122.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/greenstar/CIMG1123.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/greenstar/CIMG1124.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/greenstar/CIMG1125.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/greenstar/CIMG1126.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/greenstar/CIMG1127.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/greenstar/CIMG1128.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/greenstar/CIMG1129.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/greenstar/CIMG1130.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/greenstar/CIMG1131.jpg http://i32.photobucket.com/albums/d13/oxorockmanoxo/greenstar/CIMG1132.jpg - adrian
price lowered. im beginning to think i wouldnt even be able to give the car away if i wanted. - adrian
ThaGremlins RIde **Updated with a few SIDEwAys PICS***
oxorockmanoxo replied to thagremlin's topic in StarQuest Showroom
http://i106.photobucket.com/albums/m270/starionsofnorcal/101506%20redwood%20rd/DSCF1419.jpg http://i106.photobucket.com/albums/m270/starionsofnorcal/101506%20redwood%20rd/DSCF1439.jpg http://i106.photobucket.com/albums/m270/starionsofnorcal/101506%20redwood%20rd/DSCF1429.jpg -
I am looking for an 86-89 Starion or Quest TSI
oxorockmanoxo replied to 86LOVEQUEST's topic in Items Wanted
you can buy mine. hahaha. im sure 3k will cover the car and shipping to ny. http://www.starquestclub.com/forums/viewtopic.php?t=65840 its just a thought. so now you know you have options. - adrian -
thanks guys. i made the louvers. cut into the headlamp fram a little. cut a humongous hole in the frame wall behind the headlamp. and also cut slits into the black veil under the front headerpanel. i hope it sells too. - adrian
my feed back: (from sqc) http://www.starquestclub.com/forums/viewto...t=oxorockmanoxo my feed back: (from ebay) http://myworld.ebay.com/jdmrockman/ hope that helps. - adrian
