fixture
Everything posted by fixture
ahhhhhhh oooooooo, werewolf in London. +2221121 come up with a song on your own and not someone elses, just like he used metallicas. fixture
My concern would be the injectors. The way they are setup in stock form would allow fuel to be delivered evenly from the 2 different CC injectors. If the injectors are setup like yours the cylinders front could be getting more or less fuel then the back. Are you running the same CC injectors? if so then this will not be an issue for you. Fixture
You want to get one that has a rising rate 1:1 ratio. This will increase fuel pressure 1lb per 1lb of boost. I got mine for around $80. Dont get the cheap ones since they will not work on our setup and or cause a fire. They are not a direct bolt on but are easy enough to mount and attach. There are a couple DIYs that people have done on this site. Fixture
I am going to set my car up for the track and wanted to get everyones thought on what suspension setup to have. I currently have koni adjustables with eibach springs. I am going to have a roll cage installed as well as sway bars. I assume camber plates, poly bushings, strut bars. Anything else to help with body roll and traction? Fixture
I got a couple good ones. Pm'd you. Fixture
I just need to lower portion of the intake for the Magna. I had the top plenum and just need the bottom. Dosent have to be modified. Let me know a price shipped. Fixture
T3/T4 kit from TEP installed
fixture replied to DSM RSM 89conquest's topic in Engine and Performance Mods
I bought that kit before as well with the BB option. The downpipe is left like that so you can attached it to any exhuast you might have, 2.5 or 3". I just took my down pipe that I had on the car and cut it where the TEP meets it and had it welded. Or you could use a exhaust clamp. Fixture -
9 sec 1/4 street legal backhalf starion SERIOUS inq. only
fixture replied to rank's topic in Cars for sale
I live about 15 minutes from Littlestown. If anyone wants me to check it out just let me know. I can take pictures, if he lets me. Fixture -
CENTERFORCE DUAL FRICTION CLUTCH KIT ANYONE?
fixture replied to 101PROPOSE's topic in Group Purchase Info
I would be in for ACT. I had one in my 300z TT. Great clutch. -
its a EGR Thermovalve (Controls vacuum and is OPEN when cold).
Correct Throttle Body for Magna MPI
fixture replied to Julio's topic in MPI/Standalone Trials and Tribulations
That should work for you. -
You might want to check out twinturbo.net. its a turbo oriented sitr, but alot of guys swap the NA to TT engine and post the NA engines for sale. Fixture
I want to see more pics! I bet that turbo sounds great when boosting. Great job.
I made my own as well. Just got some brake line from the auto parts store. Removed the screw/ nuts from the old line, attached them to the new line, bent the tube where I liked it and flared the ends. Attached it, bled the lines, complete. Fixture
you can get those at your local parts store. They are the coolant temp sensor. http://www.partsamerica.com/product_images/img/nie/ts5552.jpg
They were V6 with a turbo on the passenger side. http://i5.ebayimg.com/04/i/000/9a/91/6daa_12.JPG
I am in need of a turbine housing for my turbo. Its a turbonetics and I need a turbine housing that is for a stage 2 wheel. if you have one let me know what you want shipped to 17113. Of course any t3 housing is fine since they all interchange. Also what .ar it is. thanks all.
Just got my mirrors on my BMW and they were$150 shipped. Power and heated. Just needed paint. They have 4 wires. So I am sure they would work, but which wires do what is what I am unsure off. These fit perfect with no problems (on my BMW) http://i50.photobucket.com/albums/f340/EEEEeeee36/M-Technic%20Other%20Products/M3-mirror-1.jpg on my car http://www.streetneeds.com/uploads/auser/HPIM0386.JPG http://www.streetneeds.com/uploads/auser/HPIM0387.JPG
I had an 86 turbo and it was great. Very smooth engine. Congrats. Fixture
More pics of the M3 PLEASE!! Fixture
Couple shots of my daily driver. 93 bmw 325i
fixture replied to fixture's topic in The Other Addiction
I was seriously considering a convertible. They are really nice. Great looking car. Fixture -
My suspension setup is pretty stiff but it corners like no tomorrow. I have a chip, exhaust and intake. Its a fun car and I can still get 29mpg. http://www.streetneeds.com/uploads/auser/HPIM0387.JPG [http://www.streetneeds.com/uploads/auser/CopyofDSCF3631.JPG http://www.streetneeds.com/uploads/auser/DSCF3628s.JPG http://www.streetneeds.com/uploads/auser/DSCF3636.JPG http://www.streetneeds.com/uploads/auser/DSCF3643s.JPG Fixture
That looks really good! Keep up the good work. Fixture
Interior change out... VOTE your opinion
fixture replied to Fattire4me's topic in Body and interior Mods
I knew a guy that dyed his red interior black in his quest. It looked really good. You couldnt tell that it had been dyed unless you scratch the surface really bad. The seats he swaped out for black ones but the armrest, dash etc, was dyed. Fixture
