Everything posted by stariont2000
Steering Wheel control are working now after cleaning the connections. Thanks. Now I want to replace the factory radio and install a aftermarket doble DIN radio. Anybody knows the adapter to make comparable my aftermarket radio with my factory steering wheel controls?
SOUTH FLORIDA MEET (Miami, Ft. Laud, and West Palm)
stariont2000 replied to stariont2000's topic in StarQuest Meet Planner
TO ALL THE STARION - CONQUEST OWNERS FROM FLORIDA. WHOM is ready to meet? Especially from South Florida! -
Thank you, #4 ucw458, That was my thought too. I had this car since 1989 and it used to work fine before. This issue started about two years ago and I drive this car about 3 times a week, 8 miles per day. Next time I will check all the relays. Thanks for all your replies!
Hello guys, anyone know why everytime I put my ignition on my AC fan goes on. Radiator fan works well with thermostat but the ac fan is always on. Sometime I do not mind because I am always with my ac on but when I hava a cold weather. I do not need this fan to be on all the time. Perhas it is a relay. Anyone had this issue before? please advise. Thanks, Ulises. 1987 Mitsubishi Starion ESIR. Owned since 1989
I am also interested in getting a coupling replacement or perhaps an used one to try to repair it. While I drive mine with a play. Please keep me posted. Thanks,
I am upgrading the fans for my starion and I need to confirm if the Radiador Fan and AC Fan blows the air to the engine or to the Radiator.. I think both are suppos to extract the hot air directed to the engine and the one in the front it is a pusher. Please confirm. I don't remember this. as I removed the factory ones long time ago. Thanks,
Do you have the steering wheel coupler o coupling in good or bad condition please advise.
Support my habit, buy my stuff! Stuff added 8/10!
stariont2000 replied to Munkee's topic in Parts for sale
Good morning, for any chance do you have a good or bad steering wheel coupler or coopling. If you have it please advice the condition and how much ship to 33176 Best regards, Ulises.- 36 replies
- wastegate
- distributor
(and 8 more)
Tagged with:
I know it is discontinued but I will buy an used one or bad one to try to fixed without removing mine until I know the weld is fine.
Sand it up and them you can polishe the aluminum
Any body knows where to get a Steering wheel coupler for my Starion or to have fix. Please advise Thanks,
Thank you very much Charles!
Also when are you taking apart the swicht for cleanning, you will see some little springs inside. Be very careful and stretch them a little bit and the problem will go away. Good luck!
Slave Cylinder leaking, stuck at work, help me get home
stariont2000 replied to riceboyler's topic in Virtual Mechanic
You don't have to buy the whole slave cylinder. They also sale the rebuilt kit and it is very simple to replace.. -
RADIATOR ANTIFREEZE RETURNS TO RESEIRVOIR TANK
stariont2000 replied to stariont2000's topic in Virtual Mechanic
I tought about it and I replaced the cap and still doing the same thing. Thank you. -
Thanks very much Charles for the tips. I will be waiting for the pictures.. I am also been thinking in updating the Radio. I had my car for 23 Years and I never want to change the Radio to keep it original and to use the steering wheel remote control but now with all the new technology, as mp3, USB, bluetooth, steering wheel remote control comparable, etc.. and prices are under $200 for Kenwood, Alpine or JVC. I am thinking about it again.
The Engine does not consume the antifreeze, it just send it back to the reseirvoir tank.. There is not white smoke in the pipes. When I checked the radiator is a little bit low but the water missing is on the little tank. -
I replaced the catalic coverter near the engine with an empty one over a year ago. After that I started experiecing the enginen driven very cool and also my reseirvoir tank got overfilled with the antifreeze 50/50 from the radiator. Everytime I refill the radiator, antifreeze goes back to the tank and radiator is low with fluid about half the reseirvoir tank. Engine does not reheat and works fine. But everytime I check the radior is a little low. Please advise, Thanks,
One side of the lower part to the radio and EQ lights burn up and I would like to replace them.. Any body try to replace this light bulbs? Do you have to take apart alot of things or just the front cover of the radio? EQ green lights are ok, I just need to replace the ones fron the dash, Please advise.. Thanks,
Thanks for your replies, I got it solved!! I actually made a boo boo and cross over the connector with a resistor and conected to the other plug I was connecting the black plug into the blower and not the blue connector. opps . Of course I realized that after I checked every AC system. AC is working and new blower is working awesome!
Yes, fan blower is good. I replace it with a new one. However the old one was working as well but had to much resistance.
I have an 87 Starion ESIR. I put a new blower. The Air Accondion Fuse was bad, I replace it and still no power. I checked fuse #5 & #12 both are good. Compressor works when I turn the ac switch on. I tried using a spare temperature speed resistor (The one inside the blower) and still does not work. I also tried using different AC control switch and still blower does not work. The only thing I have not able to test are the two relay behind the evaporator. I think you need to remove both cover to reach the screws.. Any ideas? I will appreciated. Thanks, ~Ulises.
Thank you for all your replies, I will re check the connections, control does not light up and horne works periodicly and some times gets stock bebping and I have to desconect to reset.
I have a 1987 Mitsubishi Starion ESIR with silver control. Recently I purchased a 1988 Steering wheel with the newers remote control. I swap the wheels but the remote control does not work. Should this work just switching the wheels or I need to replace something else. Please advise. Thanks Ulises.
