Yahoo
stariont2000
Miami Florida, USA
MIAMI, FLORIDA
stariont2000's Achievements
Steering Wheel control are working now after cleaning the connections. Thanks. Now I want to replace the factory radio and install a aftermarket doble DIN radio. Anybody knows the adapter to make comparable my aftermarket radio with my factory steering wheel controls?
SOUTH FLORIDA MEET (Miami, Ft. Laud, and West Palm)
stariont2000 replied to stariont2000's topic in StarQuest Meet Planner
TO ALL THE STARION - CONQUEST OWNERS FROM FLORIDA. WHOM is ready to meet? Especially from South Florida! -
Thank you, #4 ucw458, That was my thought too. I had this car since 1989 and it used to work fine before. This issue started about two years ago and I drive this car about 3 times a week, 8 miles per day. Next time I will check all the relays. Thanks for all your replies!
Hello guys, anyone know why everytime I put my ignition on my AC fan goes on. Radiator fan works well with thermostat but the ac fan is always on. Sometime I do not mind because I am always with my ac on but when I hava a cold weather. I do not need this fan to be on all the time. Perhas it is a relay. Anyone had this issue before? please advise. Thanks, Ulises. 1987 Mitsubishi Starion ESIR. Owned since 1989
I am also interested in getting a coupling replacement or perhaps an used one to try to repair it. While I drive mine with a play. Please keep me posted. Thanks,
I am upgrading the fans for my starion and I need to confirm if the Radiador Fan and AC Fan blows the air to the engine or to the Radiator.. I think both are suppos to extract the hot air directed to the engine and the one in the front it is a pusher. Please confirm. I don't remember this. as I removed the factory ones long time ago. Thanks,
Do you have the steering wheel coupler o coupling in good or bad condition please advise.
Support my habit, buy my stuff! Stuff added 8/10!
stariont2000 replied to Munkee's topic in Parts for sale
Good morning, for any chance do you have a good or bad steering wheel coupler or coopling. If you have it please advice the condition and how much ship to 33176 Best regards, Ulises.- 36 replies
- wastegate
- distributor
(and 8 more)
Tagged with:
I know it is discontinued but I will buy an used one or bad one to try to fixed without removing mine until I know the weld is fine.
Sand it up and them you can polishe the aluminum
Any body knows where to get a Steering wheel coupler for my Starion or to have fix. Please advise Thanks,
Thank you very much Charles!
Also when are you taking apart the swicht for cleanning, you will see some little springs inside. Be very careful and stretch them a little bit and the problem will go away. Good luck!
Slave Cylinder leaking, stuck at work, help me get home
stariont2000 replied to riceboyler's topic in Virtual Mechanic
You don't have to buy the whole slave cylinder. They also sale the rebuilt kit and it is very simple to replace..
