Wolf87Conquest
About Wolf87Conquest
  • Birthday 02/24/1961
  • MSN
    MrMopar-wolf
  • ICQ
  • Website URL
    http://community.webtv.net/MrMopar-wolf/MyCartitle/
  • Interests
    Wolf. cars, woodworking, drawing, painting, model railroading, model cars,reading
    western Pa
    16101
  • Factory Color
    Sarajevo White
    Dark Red
2025 profile views
Wolf87Conquest's Achievements
  1. With the tach jumping while cranking, injectors should fire. I'd suggest testing with a meter that one side of the injectors has 12v. It should always be there. Then check ground at the ECU and the ground to injectors from ECU. The ECU fires the injectors with the ground. Air or a clog in fuel system will have an effect as well.
  2. Vavle guide, even valve seat can drop and make a valve hang. Pulling the head and careful inspection of all the parts will have the answer as to what happened. You said the car sat for several years, could be the spring is "locked" or bound. Anything in the vavletrain or head could be suspect. Just need to pull the head and see.
  3. Check to make sure the new links are connected solid. Use a meter to check. Then check fuses, again make sure of good, solid connections. Won't hurt to meter the circuit to the ignition switch. Including grounds. Should find the problem easily.
  4. It's a good idea to get the wire harness from the doner car. If nothing else, it will make sure you have it wired correctly.
  5. I am 50 miles north of Pittsburgh in a town called New Castle. Seats are burgundy leather. Pics are one the following webpage. I'm on webtv and do not have digital cam or any way to post recent pics, the ones on the page are from shortly after purchase in 03. http://community.webtv.net/MrMopar-wolf/MyCartitle/ E-mail me MrMopar-wolf@webtv.net with Conquest in subject line if you are interested in seeing the car for address info or any other questions.
  6. Must sell my non running TSI. Needs a little body work, one front tire, battery and might need a little electrical clean up/repairs. Was running good before I had to park it when license was taken. 87 widebody, 5 speed manual, mostly stock, custom graphics, 89 specs in ECU, new tires (but does need one new front tire as it was slashed), new rear brakes and calipers before being parked, new flex brake lines up front, new windshield, new diff mounts. Looking for any reasonable offer over $400 and will be sold as is. Car is in western Pa. Will need to be towed by buyer at time of sale. Any questions or you would like any further details feel free to e-mail me MrMopar-wolf@webtv.net with Conquest in the subject line. This car must be sold and with a little TLC can be on the road again. The car is in fair condition, body needs a little work, mechanically very sound as far as I know, interior needs work (torn seats). The car is white with burgundy interior.
  7. I don't know the answer, but I believe 86 and earlier used the same injectors for both and fired them alternately. I would think it safe to assume the wiring and electrics you are concerned with would be similar enough to follow the 86 system. I could be wrong, but it seems logical.
  8. Replacing a clutch is fairly straight forward. Check all related parts, like clutch master cylinder, slave, U joints, and pivot points for wear etc. Might be a good idea to replace the fluid. The flywheel should be resurfaced, same manner as brake rotor, and for the same reason.
  9. To be that cruddy and still work at all...you got a good strong motor. A good clean up, replace lube, check it electrically (good continuity) should be all it needs. Make sure you keep polarity correct. The motor's communtator may need a good cleaning, good motor brushes and brush springs, motor bearing lube it will be good to go for many years. General clean up and lube on the wiper arms would be a good idea as well. An electric motor repair shop should have brushes, brush springs and bearings if any are needed.
  10. It's a whole lot easier to replace the mounts than to remove and wrestle in the diff cradle (what you are calling the subframe) unless you have help. Jack the rear enough for acess and support safely. Two nuts each side inside a "notch"...swivel needed to get the right angle on them. I'd give them a shot of PB Blaster and let sit a while, then try them. Then there is one nut on top each side. You'll need a jack to hold the diff...and help move it when needed. I had to replace the mounts on mine, but the nuts in the "notch" were already a bit chewed and very rusty. Ended up using a Dremel tool and a cut off wheel to cut the bolt heads under the rubber of the mounts. It's an option if needed. The ones on top that mount the diff itself are easy to get to.
  11. Sounds like you had a loose connection when you were "throwing" parts at it. With electrical problems...the best thing to do is start testing the problem circuit with a meter. My prefered method is disconnect the car's battery and with meter set on Ohms, check continuity. The problem almost always shows up within 5 minutes. This method pinpoints exactly where the problem is...bad/dirty connection, failed part, or broken wire. Then you replace only failed parts, save hassle, money and time. Electrical problems can be a pain, but with the above method of testing, it can be found and corrected easily in most cases. Stress and panic free. If you don't have a multimeter...get one. Should be in any auto repair toolbox. You'll be glad you did. Also get extra long meter leads...comes in handy when you need to go from the battery cable to things like fuse box under dash. A good idea to have on hand a small soldering iron, solder, and shrink wrap in the most common sizes. Just in case you need it later.
  12. Mild or completely stock engine....stock replacement should be good. Mild to heavy mods (or planning future upgrades) then any high energy coil would be best. Lots of companies make them, question is...what's available as a replacement and how much you want to spend. Some high energy coils these days offer multi spark capability...to use that function you'd need to switch the ignition module with a multi spark unit. Mallory makes coils and modules, been around a long time as well. There's no need to go high energy coil (or ignition system) unless you already have or are planning major modifications to the engine and systems. Stock to mild mods should not need that hot a spark...so I'd stick with the stock unit in this case.
  13. Basic hand tools will work...fancy ratchet wrenches make it a bit easier...but I like a bending/swivel ratchet handle with normal sockets. Just seems the handle is tougher and can take more torque before breakage. Clutch tools like centering the bearing type tools..seal sets/puller etc. Plenty of shop rags...collector bins (fluids and parts). A floor jack will work, but I would add a strap to hold the trans securely to the jack for safety. Ziplock bags for the bolts/small parts...mark the bags as to where the bolts/small parts go to...easy install without hassles this way. Portable shop light is a very good idea. A can of PB Blaster for the rusty/cruddy bolts. A helper is always welcome...handing out tools, steadying large/heavy parts..heck even making jokes helps make the job easier and can make a beer run!...lol
  14. If the car was vibration free before the new tires....it would stand to reason the tires and balancing is not where it should be. If you swapped wheels and used the same tires...I would think you got a "bad" tire(s). It's known to happen that tires can be made wrong....shell, bead, belts, even tread can slip thru their quality control. What I think might be happening the balancing done was ok...the belts within are not right somehow, and when the speed get high enough, the belts move and unbalance the wheel. This is assuming the car was fine before the swap. Many parts in the steering, suspension and drive train can cause this issue...all steering components, steering knuckle, wheel bearings, suspension parts/bushings in front...CV joints and suspension parts/bushings in the rear...all drive line parts from trans rearward as well as trans and engine mounts. I've even found an "out of spec" brake rotor can cause this.
  15. This is one where more info would help narrow down where the problem may be. Transitional periods (idle to half throttle) can be tricky to figure out where to look. Is the engine at operating temps or cold? Does it gradually get better, or stay that way? Timing correct? I'd look at the normal sensors (Like O2, temp), vac hoses, vac advance, MAF to be certain all sensors are functioning properly and no vac leaks, and advance isn't sticking. From the post...I'd think fuel system is working fine, so I'd look to vac leaks etc. as possible problem area.
