bkgsquad
    brooklyn n.y
    11228
    ESI
  • Factory Color
    Rio/Mexican Red
bkgsquad's Achievements
  1. Yeah just thought of that coke! thanks for the warning, it slipped my mind for quick second. gonna have to use my flatbed then.
  2. Let me know if its driveable and still available. I'm in bklyn ny not too far. i would like to come see it I have family in clifton nj so i can drive it there if it runs. I wont b on line this weekend so plz txt me at 718-810-6350.. thks
  3. how did the car run prior to the knocking? did u ever find out what the knocking is? Is the car still driveable?
  4. oh wow, ok thanks for the advice guys. i guess stock it is then for me. lol thanks again.
  5. Hey all, i'm looking for an mpi setup for my 87. plug n play though..i don't much about it and the difference in parts but i hear its way more reliable than the crap our cars come with i'm not a racer guy anymore,been there done that! i'm just looking to drive my car as much as possible and pretty much go anywhere i want..any info,tips or advice will b greatly appreciated. trying to keep the quest alive but it's getting hard..
  6. i got some in brooklyn ny with ok tires. rims are not perfect but they will do for the winter i guess.
  7. i have one came off my running 89,didnt have any issues with it when i parked the car 8months ago..
  8. wow lot of information,and i appreciate it. i'm gonna do all that on the weekend . thks again
  9. all lines have been checked and or replaced.i'm running out of patience.i'm sure u guys can understand my frustation
  10. would a bad dizzy cause my idle to be erratic and cause all that popping and poof noise from my exhaust? where can i get another dizzy?
  11. i'm running trilogy injectors,it did the same with the stock ones as well. the timing,i'm not sure where it's at,someone else did it for me so i idk if it's set before or after but he did tell me it's at 10tdc. i did not think that the cts would cause a problem but i will replace that tomorrow cause the one on there looks kinda f'd up. today driving home it really ran like crap!!! i mean really bad like bucking as if i was just learning how to drive manual type of bucking. i had to get off the expwy it was bucking so bad.It was snapping and popping way too much and too loud out the exhaust also..
  12. hey all once again i need ur help with some bucking studdering isuues. i have replaced the following: vac advance plugs and wires cap and rotor msd blaster coil injectors and clips removed 1g mas and bov put back stock setup reset tps/isc timing is 10 tdc when its cold it bucks a bit when i give it gas regardless wht gear i'm in. It is running way better than it use to but it still has an issue and i honestly do not know wht to do next.It is not leaking any fuel from injectors or tb. i have done alot of stuff to the car as far as trying to make it a daily driver but i'm stumped right now. plz help before i give up and get rid of it.
  13. hey i had/have the same issue.i replaced alot of stuff. but today about an hr ago i replaced the injector clips. Let me tell you,wht an unbelievable difference it made on my 87. i also removed my 1g mas setup and bov and hardpipes i had. i put everything back to stock(no bov) and it runs waaaayyyy better. not quite 100% but much better than before.. just my 2 cents.. good luck
  14. hey there i have the parts u need as well,and they are fiji colored. I'm in brooklyn n.y. let me know if the other deals fall through.
