myquest86
Everything posted by myquest86
Still have the blow off valve? if so what brand and can you send picture? Thanks
Found one for $27.00 shipped.....thanks guys!!!
78728
What is stock wheel bolt pattern and offset?
I totally understand, to be honest im only probably gonna be with TBI for about another month......thats why I dont wana pay alot for an injector
Thanks, I need one if anyone has one!!!
what size are stock 86 injectors.....are primary and secondary the same size on this year model?
looking for an injector for 86
ok, thanks
im looking for one for not soo much $$$$, i have seen several for like $25 shipped and even if they need to be cleaned and flowed thas only like 20 bucks. Thanks for the response though
stock intercooler,12a rebuilt, stock pipes, 86 injector, used water pump
myquest86 replied to traps's topic in Parts for sale
Pm'd -
Hey David, looking for stock 86 injector (1) Thanks
$20 each
Do you have any 86 Injectors?
So I sent my injectors out to be cleaned and flow tested and one of them is leaking externally. Im looking for 1 injector to replace it, preferably one that is know to be good and clean. Thanks for the help
Yeah, just the side with the red release button on it.
Do you have front seat belt buckles??
No it just has to be the style with the flat flange and 2 bolts
- 4 replies
- blow off valve
- turbo
(and 3 more)
Tagged with:
Need a new blow off valve that mounts like this one. Thanks Blow off valve.htm
- 4 replies
- blow off valve
- turbo
(and 3 more)
Tagged with:
I agree, you need to check fuel delivery and spark. You are just trying to get it to fire up right now, so just focus on the basics. Your engine needs air, fuel, and a good spark to ignite it. As long as you have those three things and the timing isnt off she should at least start. Good luck
Gas Pump Nozzle Shutoff Issue
myquest86 replied to TrustConquest's topic in Newbie Question and Answers
I would have to agree with Dodge2004srt4, pressure is building in the tank and causing the pump to shut off cuz it thinks your full. Try pumping the fuel a little slower and it should help out. You have to keep in mind that in the 80's fuel pumps didn't pump fuel as quickly as they do today. -
cleared codes and drove her again, still getting O2 code. No fuel in the fuel pressure vac line, but still gonna rebuild throttle body and have injectors sent out for cleaning.
any new ideas???? so far everything check out good
Can you install an 89 ECU in an 86 without major modifications?
