3
Everything posted by boostin20lbs
i was hoping to get a paint mached one haha
any one have one and a good passenger tail light thanks
on the core support on the passenger side there is a silver little box. thats for your injectors. try replacing that. ive had one go bad on me. and it did that exact same thing.
Will it make a difference if I do the larger valves.
I did all the timing about 6k ago and I have a 272 cam I was thinking of running
My head gasket finally went im getting the head done and wanted to see which gasket had best results. Im only planing on running no more then 15psi. I have a 16g with all the hard pipes and intercooler upgrade. backed by a 1g and 3inch exhaust. idk whether I want to go with biger valves and heavier valve springs tho.
how hard is the whole torque sequence when it comes to the arps. this is the oe head gasket. ive been pretty lucky so far. the motor only has 115k on it. this will be the first time the heads ever been off.
time for a new one witch is the best brand and model to go with. not planning on running alot of boost. just dont want it to fail to early thanks jeff
Ill take it whats your paypal
Need a good water line. Its the one that runs over the valve cover. Cant Can't remember its the feed or drain. Let me know if you have any thing. Thanks
Clear Lenses again.. $60 shipped.
boostin20lbs replied to JustPaus_88TSi's topic in Group Purchase Info
yes yes there is interest!!!! -
in need of one for a swap. any one got one! thanks
Need one piston oil squirter. One of mine failed. for a 87 conquest.
boostin20lbs replied to kaaos's topic in Items Wanted
still need one? -
Need a good tps. Let me know what you got. thanks
From the album: black 88
i have 95 lb bosch injectors with the trilogy fuel rail i also have a 1g fuel rail. i have a modded magna intake,msII ecu set up to run EDIS. full EDIS with mk1 crank pulley dizzy plug and trigger mount. I also have a patch cable for the ms ecu to run with stock harness on tbi set up. built by scott. i also have a untouched 6ft ms harness. i have a 31x12x3 cx racing intercooler with universal 3in aluminum piping i never got around to using. pictures and prices will come as soon as i get the time to got get them. IF not tomorrow night should be the next day. if there is anything specific you need that i didnt mention let me know and ill see if i have it. thanks
Parting out all my mpi parts for motor swap. Let me know what do you need and i will get prices and pictures. thanks
NikoFab JDM Rear Hatch Spoiler: GP Closed
boostin20lbs replied to NikoFab's topic in Group Purchase Info
ill get pics and video as soon as it is -
holset hx35, magna intake and me for now. ill have pics up when its done -
yup yup thats what ive been doing -
i hoping with in two to three weeks if i manage to make time for it. -
looks great cant wait to get mine hopefully it will be done by the same time as my car hah -
yeah i almost coated the pliers with rubber so they wouldnt slip off haha but once i figured it out its easy.
