Oscar_the_Grouch
Oscar_the_Grouch last won the day on May 22 2013
Oscar_the_Grouch had the most liked content!
  • Yahoo
    mitsu_nut@yahoo.com
  • ICQ
    Miami, Florida
    33125
3721 profile views
Oscar_the_Grouch's Achievements
  1. Hello I have a the Oil Feed Line youre looking for. New Steel Braid for OEM turbo. $60.00 shipped comes with all adapters. Let me know Oscar OTG
  2. you should have received this RIGHT ? banjo goes to slave, big end is the adapter that connects oem line to new line and clamps on at oem location http://i161.photobucket.com/albums/t229/Oscar-the-Grouch/Clutch.jpg
  3. Okay... Which thread dies not match where? The fat end of the adapter will go to the hard line and the skinny end to the hose. Then the banjo bolt is self explanatory. Let me know where it is you're having trouble.
  4. Okay.... Post anything you feel you need to post. So again Getting back on track, what oil line is it?
  5. Okay... What oil line do you speak of? This is the first I hear of any of my lines leaking. Would like to know to clear the air.
  6. Because it's Greddy and this one has been aged for 11 years to perfection.
  7. Yes adapters are included for all lines sold unless otherwise mentioned.
  8. Hello I have found some of my SS Braided lines that I introduced to the community over a decade ago. These are NOS lines that have been orphaned and found in my recent move so I'll post new inventory as I find them. As of this post these are the lines available: ALL lines use Steel Aeroqip/Eaton Aerospace Fittings and Adapters for strength, reliability and durability (NOT ALUMINUM, unless otherwise specified) ALL lines are TEFLON Steel Braid (NOT RUBBER, unless otherwise specified) --------------------------------------------------------------- x2 Fuel RETURN Lines ----------------------------- $15.00ea shipped -------- OEM RETRUN Lo-Pressure ( FPR to Hardline return to tank ) ( Rubber hose w/imitation hose ends ) --------------------------------------------------------------- TEFLON (NOT rubber) Steel Braid, STEEL (NOT Aluminum) hose ends and ADAPTERS x1 Two(2) Piece FULL length Clutch Replacement Line --------------------- $65.00 SHIPPED (Replaces the OEM Hardline from master and the shorty rubber line to the slave with matching pieces in SS line) TEFLON (NOT rubber) Steel Braid, STEEL (NOT Aluminum) hose ends and ADAPTERS x1 One(1) Piece FULL Length OEM Replacement Clutch Line ------------- $40.00 SHIPPED (Replaces the OEM Hardline from master and the shorty rubber line to the slave with one piece SS line) TEFLON (NOT rubber) Steel Braid, STEEL (NOT Aluminum) hose ends and ADAPTERS 1x "SHORTY" Clutch Replacement Line ----------------------------------------- $25.00 SHIPPED (Shorty, From slave to hardline. Replaces ONLY the OEM rubber Shorty) SHORTY SHOWN BELLOW http://i161.photobucket.com/albums/t229/Oscar-the-Grouch/Clutch.jpg -------------------------------------------------------- x1 Brake Master Cylinder line SET ( Two(2) hoses ) --------- $40.00 SHIPPED ( These are RUBBER Steel Braided lines NOT Teflon ) ( These use Imitation hose ends that use standard worm clamps inside a cover ) ( Replaces BOTH rubber hoses to and from the brake master and the fluid reservoir ) http://i161.photobucket.com/albums/t229/Oscar-the-Grouch/20130919_132531-1_zps783a7b97.jpg ----------------------------------------------------------- 2x Turbo Oil Feed Lines ------------------------- $50.00ea SHIPPED TEFLON (NOT rubber) Steel Braid, STEEL (NOT Aluminum) hose ends and ADAPTERS http://i161.photobucket.com/albums/t229/Oscar-the-Grouch/TurboOilFeed.jpg ----------------------------------------------------------- TEFLON (NOT rubber) Steel Braid, STEEL (NOT Aluminum) hose ends and ADAPTERS 1x Turbo water FEED line ------------------------------------------- $65.00 SHIPPED ( From water pump to Turbo ) ( Teflon NOT RUBBER ) ( Uses imitation hose end at T-Stat, Looks like AN fitting but its a worm type clamp ) TEFLON (NOT rubber) Steel Braid, STEEL (NOT Aluminum) hose ends and ADAPTERS 1x Turbo water FEED line ( MUST TAP WATER PUMP ) ------ $85.00 SHIPPED ( From water pump to Turbo ) ( Teflon NOT RUBBER ) http://i161.photobucket.com/albums/t229/Oscar-the-Grouch/20140511_135031-1_zpsbe76b8dc.jpg TEFLON (NOT rubber) Steel Braid, STEEL (NOT Aluminum) hose ends and ADAPTERS 1x Turbo water RETURN line ---------------------------------------------- $65.00ea SHIPPED ( From turbo to T-Stat housing ) ( Teflon NOT RUBBER ) ( Uses imitation hose end at T-Stat, Looks like AN fitting but its a worm type clamp ) TEFLON (NOT rubber) Steel Braid, STEEL (NOT Aluminum) hose ends and ADAPTERS 1x Turbo water RETURN line ( MUST TAP T-STAT HOUSING ) ----- $85.00ea SHIPPED ( From turbo to T-Stat housing ) ( Teflon NOT RUBBER ) http://i161.photobucket.com/albums/t229/Oscar-the-Grouch/20140511_135518-1_zpsa7661d05.jpg ----------------------------------------------------------- TEFLON (NOT rubber) Steel Braid, STEEL (NOT Aluminum) hose ends and ADAPTERS x1 Hi-Pressure Power Steering line VERSION 1(Pictured) -------------- $100.00 Short version, tight fit, hugs the block, less volume needed. Adapters ARE INCLUDED TEFLON (NOT rubber) Steel Braid, STEEL (NOT Aluminum) hose ends and ADAPTERS x1 Hi-Pressure Power Steering line VERSION 2 --------------------------- $140.00 (12" longer than V1 made to run same route as OEM, 45deg fittings instead of 90deg on V1 for better fit) Adapters ARE INCLUDED Two(2) "Heat Loom" available NO heat shield SORRY http://i161.photobucket.com/albums/t229/Oscar-the-Grouch/PowerSteering.jpg ----------------------------------------------------------- x2 Lo-Pressure RETURN Power Steering Lines (U-Assemble)------------ $120.00 Same in "LOOK" to the Turbo Water lines bellow but A LOT LONGER of course. Rubber steel braid line, Aluminum fitting w/steel addapter at the Steering box and imitation hose end at the other end. U-Assemble NOTE: All you need is a VISE to hold the bottom part of the fitting while you thread the other part of the fitting into the hose. I can provide detailed instructions if you'd like. I no longer have space/tools/means to assemble these myself. I can have them assembled by a hydro shop but price will reflect that extra labor. http://i161.photobucket.com/albums/t229/Oscar-the-Grouch/TurboCoolant.jpg ------------------------------------------------------------ TEFLON (NOT rubber) Steel Braid, STEEL (NOT Aluminum) hose ends and ADAPTERS ABS Bypass lines please inquire as I DO NOT have any available but can get a GP on these if there's enough interest. NOTE: It will NOT be a Goodridge brand but it WILL BE a DOT approved line. Will get new pricing and try to keep it the same as the original lines at $45.00ea So far we have .... - BOOSTED88tsi - KIDMEN http://i161.photobucket.com/albums/t229/Oscar-the-Grouch/ABS.jpg LIST Will update as items sell or as I find more. Thanks OTG
  9. Hello This is the result of Parts Hoarding. Found this after being "LOST" for 11 years and well its up for sale. NEW / NOS / NEVER installed Greddy/Grex Front Strut Bar Very confident (Could be wrong) is the ONLY ONE available in NEW / Uninstalled condition. $240.00 SHIPPED within the 48. http://i161.photobucket.com/albums/t229/Oscar-the-Grouch/20130917_135916_zpsff4ef3f3.jpg http://i161.photobucket.com/albums/t229/Oscar-the-Grouch/20130909_135405_zpscc76e671.jpg http://i161.photobucket.com/albums/t229/Oscar-the-Grouch/20130909_135518_zps4fc944ff.jpg http://i161.photobucket.com/albums/t229/Oscar-the-Grouch/20130909_135503_zps9f72997a.jpg http://i161.photobucket.com/albums/t229/Oscar-the-Grouch/20130909_135448_zpsacdb3dff.jpg http://i161.photobucket.com/albums/t229/Oscar-the-Grouch/20130917_135858_zps3aed5c13.jpg http://i161.photobucket.com/albums/t229/Oscar-the-Grouch/20130917_140513_zps3e662161.jpg
  10. Hello All Well is that time.... The fronts are ready and payments need to be sent in for all those interested. REAR I have two of the originals I made but can make more if need be I just need interest with deposits to get the materials and the metals working. The weld-in plates also available just inquire as stated above. You WILL NEED to CUT and WELD or have someone else do it, these are NOT BOLT-ON. Thanks OTG
