imwhatim
Everything posted by imwhatim
thank you for all you kind words... there is nothing wrong with this turbo ... my word. Just trying to hook up a starion guy. there is a sale PENDING...
Thanks for your kind words. This is a real mitu not chinesse remake... Its a sad day when that is a selling point.. hangs my head down low.
hot side housing is from my stock 12b. no shaft play very nice, less than 100. this cost me more to make this than im selling it for cold side-- 75--evo guy center--50--evo guy new impellers and rebuild kit--150-- az turbo/diesel rebuild and mods--250--az trubo/diesel total 525 thats not including the mandel bent down pipe. pics of it when it was in my car. http://i107.photobucket.com/albums/m308/ikonwun/1004101449-00.jpg
tps master and injector shipped out today should be to you by friday...
oval tube.. or side exit.. what i had drawn up too make ...
im parting out my 87 will that one work for you?
i have a 20g for sale... see my for sale thread...
Wakeman17 is looking for some of these....
all pms returned...... i dont know what exacly you want pics of? im on here when i can be. i work 12 hour shifts and dont have a computer at home( i know 2010).... motor top http://i107.photobucket.com/albums/m308/ikonwun/1004101449-00.jpg turbo http://i107.photobucket.com/albums/m308/ikonwun/0919100826-00.jpg turbo fins http://i107.photobucket.com/albums/m308/ikonwun/0919100826-01.jpg
replyed to pm's
the motor is all together and the bottom end was balanced .. wheels are gone i have different ones on there. exhauts is sheit i was going to make one the down pipe is nice... ill get spec of the turbo it fits in my stock turbo exhaust housing its very nice... i will miss this turbo... no video of the motor my friend...
Hard boost tubes----75 shipped....... Blitz BOV ---75 shipped..... 20g fresh rebuilt turbo(with custom braket for wastegate and wastegate with down pipe) ----- 450 OBO PLUS SHIPPING Gen 2 eclipse mass ----35 OBO shipped MOTOR is SOLD New TPS sensor ---sold New master cylinder--- sold shipped Trilogy turbo injectors 650/950----sold sold shipped supe nice shell with everything that i didnt list for sale ------sold
i started out with a 284 roller hydro cam. and then went back to stock setup becuase i damaged 2 rockers/ lifters. now im going back to the old setup( 284 rh) and rollers rockers again ... sweet thanks for the info...
i have a bolt on 20g with less that 100 miles on it .. freahly rebuilt.. 450 shipped
i have spark at the plugs so all of the ignition parts are working... what is this rocker out of... http://i107.photobucket.com/albums/m308/ikonwun/1122100851-00.jpg
the lifers are squishy where do i get super thin wire to pump them up after the oil pressure builds up?
cam dowel is at the top... The compression, how much was it? still got the guage ill recheck and get numbers The lifters weren't to be pumped up before installed that happens after they see oil pressure.? will this effect it not running... The spark you have how did you test it? plug each one of the wires off the spark plug and put a screwdriver in it togapped to ground and watch it spark when some esle cranks it. wires are in order The fuel, did you try starter fluid and did you check the plugs to see that they aren't new fouled from all the cranking you have been doing and its not started yet? sparyed starter spary and i can see the injectors sparying when you take off the top boost tube. new plugs in now and old plugs still looked good. ya i know that with spark fuel timing and compression you get running motor but .. wow i dont know... i was a german car tech for years now i build vw motors and porsche motors for side jobs... i dont work on japanese steel often
the ecu is working and all my fuse link look good. the mas is good and all the boost tubing is good. triple checked everything by now...
so i converting back to the 284 rh and just need to find two intak rockers . .. i cant get this stock cam to work... the timing is all lined up, i have spark, i have fuel and compression... so i dont know... ill post up pics of the rocker hopefully you guys can tell me what car its out of so i can go find some at the junk yard...
1957 ford pick-up truck. nor cal. project. 1500
imwhatim replied to patra_is_here's topic in Cars for sale
trade you for my starion... meet half way ..?????? -
thansk all for your help still not sloved tho.. the pumped up the lifters before i installed them. the cam towers are the ones for my head.. all motor /head parts rotating normaly ... the timing is spot on ( i checked it like 4 times by now) i have compersion i checked that too.. dis is in the head well and bolted down.. i just talked to a buddy about this and he said check and see if the injectors are spraying.. so that next.. ill keep you all posted.. thanks again .. i might have to keep this car you guys are awesome at helping... and i have taking it apart some many time i know it by heart..
So i swapped my cam out for a stock one and now i get a no start issue. i just swapped it out cam for cam.( rockers too) The cam was a 284 rh now its a stock one would i have to degree the stock cam? can i do this with the water pump and cover on? i get spark..checked i set timing at tdc and 10* btdc .. checked both i set timing 180* at tdc ands 10* btdc...checked both i really need to get this car running i have 5 guys coming over thurs to look/ buy it...
may be parting out any interest in parts..
the 20g is just rebuilt it looks so nice.. no the car/turbo burns no oil. i didn't know about the filter on top of the valve cover.. if i keep it ill do a proper oil catch can.. thats for your concern ... would you like to buy a car...? ill post more pics up asap.... (...probly sunday i can...i dont see day light much work and all...)
