Everything posted by HANZ
really nice car
OEM style Conquest reproduction decals. Now offering reflective colors too!
HANZ replied to Burton's topic in Parts for sale
thats sick man. Ill be getting some of these really soon, looks great -
hahha awesome story
GLWS. sounds pretty sweet
nice car. love the paint job
gay.... well ill probably PM you Dodge, been talking to a couple people in my area and belive it or not i might be able to get one. but if it falls threw im gonna hit you up if your still willing to sell me one
Saw one on rock auto but it's 168$ looking for something cheaper thought if test my luck
Hey guys, was working on the car and my wires to my throttle sensor broke (throttle position sensor) and I suppose i should go shopping for a new one. I dont have a pay pal account yet and was hopping to just meet up with someone close by if there is anyone with the part willing to sell. or mabe give me some information on were to find one. thanks anything helps heres a picture of it its number 13 in the picture also part # is MD61 4078 thanks again email is vertia1209@yahoo.com
thanks for the info guys
ya man car is awesome! nice story
was going over alot of the service manuals, and i was woundering if there were torque specs on these manifolds? if not im assuming that you tighten from the middle and go out wards
is there alot of condesation in your garage cus that can do it
what kinda of sealant should i use? and i can get that stuff at any parts store right?
Hey guys. still working on the car but was going over all bolts for tightnes and i checked the chamber cover lockated under the intake manafold. the bolt thats on the right side seemed stripped, was woundering if i needed to replace the gasket if i pulled it off and if so where i would order it from. please let me know about information you may have.
now that i got that figured out just gotta get my intack and exhost manifold back on and start her up and hopefully all is good
that helps alot thanks.. haha thats exactly what i was looking for on the site
thank you very much. so you belive by me hooing it up and powering it threw the Gm maff would be a bad idea? i havnt hooked it up and drove withit on but if it works and drives good should i run it like that or you think ill just run into more problems?
my wires arnt mixed up ive tried hooking up direct power to the pink black wire from batery and it still wont go on. but when i put the power on the pink and black from the gm maf i get power
also there is power coming from the original maf plug its just not powering it up Also car has 88 ECU and im putting power to the GM maf senser plug. then i have full power to the translator
im not getting power to my maft when i hook it up. i was testing it and i can get it to go on giving it power from the batery. it will only be powerd from the plug into the maf not the stock connection , can anyone help me out. i was just going to wire it from my fan to give it ingition power and hook it up that way? will i run into problems? will this kill my translator ? havnt actuly hooked it up yet cus car is all aprart now but will soo n have back together. but im woundering if i hook it up that way will i run into problems? ill try and get some pictures up to better explain what im talking about
ARP head studs Clevitte Rod bearings Clevitte Main Bearings Timeing Chain kit Balance Shaft Eliminating kit Brass Freeze Plugs Wiseco 8.0:1 Pistons -.020 overbore Chrome Moly rings New OEM oil pump Balanced Crankshaft New TD05-18G Turbo TurboXS type h-RLF Blow off valve Bosh hi-flow fuel pump MSD Blaster 2 ignition coil New Ignition Wires *DM 3inch 2nd gen Exhaust system Silicone Re enforced pipe couplers Modified stock intercooler Endtank nipples A/C Delete Heater core bypass ACT xtreme pressure plate w? act hd street clutch disc Newer kyb gr-2 struts front and rear AEM wideband Autometer Boost /Vac New Turbo XS boost controler Schiender 284 camshaft 3in MK1 hardpipe Maf to turbo EGR block off Newer tiers Kenwood speakers all around these are mods (information i got when i bought car) should i keep it in cus i think it might not work and ill have to get another one but its def worth buying?
Any parts hoarders within driving distance of SE PA?
HANZ replied to helrazr70's topic in Parts for sale
you should let me get that coolant return line -
It was never hooked up in the car. But is there a simple way to check if it works ?
