tkal
Everything posted by tkal
I guess this is the last place to sign up
I would sign up for one.
T-56 dimensions, torque capacity, and gear ratios
tkal replied to AustinTSI's topic in Transmission Swaps
I have a fidanza flywheel and was thinking about the adapter plate/bell housing that I will need. Chad, did you make a new housing or a 3/8 plate? -
Cut it of with an abrasive disk as close as you can and then grinder it smooth.
I am a stainless steel sheet metal fabricator and tig welder. Welding a manifold up would be fun. I also have my own '87 I could jig it off of. If it would interest the members I could build a jig and assemble their manifolds along with mine. I would be willing fit and weld the entire gp. I am in Auburn, WA.
GP: MK1 POLY URETHANE TORQUE TUBE BUSHINGS
tkal replied to 101PROPOSE's topic in Group Purchase Info
Still in. -
101, I am still in for a bushing so hold my deposit. -
GP ON EIBACH SPRINGS....$228.50 shipped FIRM!!!PMT DUE.
tkal replied to Trilogy Turbos's topic in Group Purchase Info
Payment sent. Could you add me to the list along with those who have paid. -
Count me in for one set. -
GP: MOOKEEH GAS FRONT SHOCKS & REAR STRUTS
Deposit sent. -
I have recently picked up an '87. I can turn a wrench just fine however my diagnostic skills are not as high. When running there is a slight tick near number three exhaust valve. Doing a compression test dry all 4 cylinders test 130-135. When wet 1,2,4 go to 145-150 while 3 stays at 135. I have not done a leak down yet as I don't have a setup to do so. EGR has been eliminated. The pressure in the case seems to of blown out my oil pan gasket. Oil and coolant both look ok. My buddy believes that I have a bent valve and that is causing my pressure in the crank case.
Under normal or fast driving what does your oil pressure gauge show? Does it ever top out and stay there? If this is not normal any idea what might be amiss?
What kind of extra parts? A rough list would be nice.
What city is the car in, pac northwest is a little too general.
*edit* assuming this is not too much from the grave.
Would you define "apart?" How apart is it, do you have a pile of parts and a pile of bolts, or do you have a head and a short block? Are all the parts there? Are you sure? Pics please .
I dont suppose that I could get you to take a camera shot down the throttle body with a flash light. I want to see the inside of these hurricane manifolds. Thanks!
