Everything posted by conquest707
g54b/4g64 to mazda r (rx7 turbo) adapter bellhousing
conquest707 replied to conquest707's topic in Parts for sale
awesome thanks! well i have a b2600 trans too haha -
depends on the transmission used, the rx7 trans (im fairly certain) sits about right for the SQ shifter hole. if you use a transmission from a truck it will be about six inches forward of stock -
http://projectzerog.com/rx7transmissions.shtml the bellhousing required for this swap and the hardest part to find. stronger transmission that is designed for higher revs. 200obo plus shipping
Buy the stuff i have no use for. Performance parts
ttt -
theres lots of ways they could make it work quite well i think.. maybe theyre not finished. like a front spoiler and negative pressure vents above the ic to draw air through maybe? like they do with radiators to keep the heat off the motor and such... nah then theyd be blasting the ic with hot air from the rad if it was right blow it... oh i give up...
yea the shaft has a little play to it
the cases and harness are identical i think. open it and 88+ have two boards inside not just one. -
the 19c is essentially a highly modified stock unit. Bored out compressor housing with a larger, flush wheel and the turbine wheel clipped. 100% direct fit replacement for the stock. but obviously more mods are recommended if you want to get the most out of it. -
Ok no hits on last thread, im moving at the end of the month, and someone needs to take this stuff. 19c turbo, little shaft play. 400obo ss braided turbo oil feed line and fittings 30obo 2.5" Downpipe with o2 bung 60obo 88 ecu 50obo NEW MK1 struts/shocks sold flatty mudflaps! a little beat around the mounting holes but still purdy cool! 50obo exhaust manifold and turbine housing no cracks 60obo each 1 mani left injectors: lots of sizes including some rarer ones i think, was going to get them flow tested for previous inquiries but dont have time or energy.. 100obo for the lot of em.. like 7-8 i think.. everything obo naturally. im out of the SQ's.. just dont want to carry them around anymore.. please take all prices shipped paypal accepted http://i824.photobucket.com/albums/zz161/conquest707/downsized_0626121054.jpg http://i824.photobucket.com/albums/zz161/conquest707/downsized_0810121721.jpg http://i824.photobucket.com/albums/zz161/conquest707/0810121723.jpg http://i824.photobucket.com/albums/zz161/conquest707/downsized_0810121729.jpg http://i824.photobucket.com/albums/zz161/conquest707/downsized_0810121728.jpg http://i824.photobucket.com/albums/zz161/conquest707/downsized_0810121731.jpg http://i824.photobucket.com/albums/zz161/conquest707/downsized_0810121725.jpg http://i824.photobucket.com/albums/zz161/conquest707/downsized_0810121728.jpg
bump for pic and price drop
would like to sell all this together: 19c turbo, ported/clipped turbine wheel, little shaft play. comes with everything, compressor housing to turbine housing with the "good" wastegate actuator. (tdo5) 2.5" downpipe, solid no flex section. looks like a tep unit. not certain though ss braided oil feed line with fittings 500 shipped obo heres a pic i had of it in my car.. detailed pics to follow http://i824.photobucket.com/albums/zz161/conquest707/downsized_1207011016.jpg also have a couple stock exhaust manis 50 each plus shipping MK1 struts packed up ready to ship 120 shipped a bunch of wheels if you are local.. 88+ ecus and knock boxes.. lots more just ask.
Best Offer Sale, bunch of stuff i have no use for
the hard part is taking out the ac unit, thats pretty straight forward, especially if you dont mind cutting through some lines to get them out then the duct fits perfectly in the span, dont have to screw it in or anything. -
i dont think i have a bung but ill check. 30 plus shipping for the duct and alt bracket? -
yea its such a simple bracket you can use about anything haha this ones off a mighty max i think. email me -
COWBELLS!
so its an independent system under the hood so you can just tear all that out, the lines, fan and all that. the bung plugs the hole left from the lines through the firewall, the duct replaces the system under the dash, and the bracket replaces the 15 pound thing that holds the ac compressor and alternator with an 8oz one that just holds the alternator. and yes it looks much cleaner, would only be able to tell it had ac to begin with from the hvac controls -
yep! the bracket, duct and a solid bung for the firewall is all you need to completely remove the AC. -
Bump for edit, thanks guys! -
Summer build thread - UPDATES?!?!?!
conquest707 replied to patra_is_here's topic in Just plain ol' B.S.
hey! i know that fender! -
also light porting on the ports, looks like a quick gasket match, i didnt do that one so cant tell you for sure. -
coilovers SOLD, thanks Ivan for fast payment. sorry to everyone else that was a hot item apparently. ill look up the numbers on the injectors and post them its all stock off an 88, the splitter is taken out and smoothed out a bit and no its a stock TB :/ -
Ive been out of the SQ thing for a while and have a bunch of OEM stuff i have had stored in the garage. Best offer picked up, shipped its got to be worth my time at least a little bit. Davis CA, near Sacramento Email arrow930@gmail.com for faster reply, http://i824.photobucket.com/albums/zz161/conquest707/downsized_0626121054.jpg http://i824.photobucket.com/albums/zz161/conquest707/downsized_0626121057.jpg http://i824.photobucket.com/albums/zz161/conquest707/downsized_0626121058.jpg http://i824.photobucket.com/albums/zz161/conquest707/downsized_0626121102.jpg Coilover project that never happened: NEW Cosmo Dual coil Coilovers- SOLD NEW MK1 Shocks/Struts- 140 Shipped Used Mr2 shocks- free if you want em Various little parts: 88 ecu- 50 Various injectors, primary/secondary- depends on which and how many 1g DSM AFM w/ Adapter harness i made- SOLD BSE kit- SOLD AutoMeter Gauges, rough fuel gauge and Narrow band A/F gauge- 30 NEW 255lph Walbro Fuel pump- SOLD Engine parts: alt w/ non AC bracket- 30 AC bypass duct- 20 distributor- 10 known good radiators- free pickup only Loaded 88 intake mani/TB all sensors and injectors with ported intake-80 or part out no Tstat housing i just threw out the numbers i seem to remember these things beeing worth -25/30% or so, give me an offer on lots. fast sales are the best sales at this point.
so i have this dodge d50 diesel with the 4d55 in it. its the BEST little truck, but the transmission is in dire need of replacement. im pretty sure the chassis has close to 400k on it at this point. recently rebuilt engine but ive pulled out 2 synchro rings so far and it sounds like a handful of bolts in a blender. if you have one or can give me a lead on one that would be the best thing.. ever. thanks in advance!!
B71 atlantic blue, clean, rust free, to a good home
conquest707 replied to conquest707's topic in Cars for sale
got a couple pics this morning -
yea i know.. *hangs head* thought i figured out a scheme but just isnt working out :/ ill for sure get back to you
