About conquest707
- Birthday 09/30/1986
all types of ill isht
Davis, CA
94573
Atlantic Blue
Being Modded
3243 profile views
conquest707's Achievements
g54b/4g64 to mazda r (rx7 turbo) adapter bellhousing
conquest707 replied to conquest707's topic in Parts for sale
awesome thanks! well i have a b2600 trans too haha -
depends on the transmission used, the rx7 trans (im fairly certain) sits about right for the SQ shifter hole. if you use a transmission from a truck it will be about six inches forward of stock -
http://projectzerog.com/rx7transmissions.shtml the bellhousing required for this swap and the hardest part to find. stronger transmission that is designed for higher revs. 200obo plus shipping
Buy the stuff i have no use for. Performance parts
ttt -
theres lots of ways they could make it work quite well i think.. maybe theyre not finished. like a front spoiler and negative pressure vents above the ic to draw air through maybe? like they do with radiators to keep the heat off the motor and such... nah then theyd be blasting the ic with hot air from the rad if it was right blow it... oh i give up...
yea the shaft has a little play to it
the cases and harness are identical i think. open it and 88+ have two boards inside not just one. -
the 19c is essentially a highly modified stock unit. Bored out compressor housing with a larger, flush wheel and the turbine wheel clipped. 100% direct fit replacement for the stock. but obviously more mods are recommended if you want to get the most out of it. -
Ok no hits on last thread, im moving at the end of the month, and someone needs to take this stuff. 19c turbo, little shaft play. 400obo ss braided turbo oil feed line and fittings 30obo 2.5" Downpipe with o2 bung 60obo 88 ecu 50obo NEW MK1 struts/shocks sold flatty mudflaps! a little beat around the mounting holes but still purdy cool! 50obo exhaust manifold and turbine housing no cracks 60obo each 1 mani left injectors: lots of sizes including some rarer ones i think, was going to get them flow tested for previous inquiries but dont have time or energy.. 100obo for the lot of em.. like 7-8 i think.. everything obo naturally. im out of the SQ's.. just dont want to carry them around anymore.. please take all prices shipped paypal accepted http://i824.photobucket.com/albums/zz161/conquest707/downsized_0626121054.jpg http://i824.photobucket.com/albums/zz161/conquest707/downsized_0810121721.jpg http://i824.photobucket.com/albums/zz161/conquest707/0810121723.jpg http://i824.photobucket.com/albums/zz161/conquest707/downsized_0810121729.jpg http://i824.photobucket.com/albums/zz161/conquest707/downsized_0810121728.jpg http://i824.photobucket.com/albums/zz161/conquest707/downsized_0810121731.jpg http://i824.photobucket.com/albums/zz161/conquest707/downsized_0810121725.jpg http://i824.photobucket.com/albums/zz161/conquest707/downsized_0810121728.jpg
bump for pic and price drop
would like to sell all this together: 19c turbo, ported/clipped turbine wheel, little shaft play. comes with everything, compressor housing to turbine housing with the "good" wastegate actuator. (tdo5) 2.5" downpipe, solid no flex section. looks like a tep unit. not certain though ss braided oil feed line with fittings 500 shipped obo heres a pic i had of it in my car.. detailed pics to follow http://i824.photobucket.com/albums/zz161/conquest707/downsized_1207011016.jpg also have a couple stock exhaust manis 50 each plus shipping MK1 struts packed up ready to ship 120 shipped a bunch of wheels if you are local.. 88+ ecus and knock boxes.. lots more just ask.
Best Offer Sale, bunch of stuff i have no use for
the hard part is taking out the ac unit, thats pretty straight forward, especially if you dont mind cutting through some lines to get them out then the duct fits perfectly in the span, dont have to screw it in or anything. -
i dont think i have a bung but ill check. 30 plus shipping for the duct and alt bracket? -
yea its such a simple bracket you can use about anything haha this ones off a mighty max i think. email me -
COWBELLS!
