Dmaximum
Everything posted by Dmaximum
Are you sick of the orange glow? PLACE YOUR ORDER
Dmaximum replied to sapper's topic in Group Purchase Info
Put me down for a set.... Very Cool D -
Chad modded Magna GP - $370 for everything
Dmaximum replied to b00st3d's topic in Group Purchase Info
Put me down for the Next TR! -
Mine arrived on Thursday, Verry Nice Definitely worth the wait D
Thanks Larry for the update. Suppliers can be a pain sometimes! D
Definately intersted based on price and function. D
If anyone wants to know the latest from Forcfed4 read the following link http://www.starquestclub.com/index.pl?boar...;num=1081525884
Forcfed4, Hope you are doing better. and sorry about your Grandma, and hope to have you back soon. Best Regards D
I am also concerned, since I also paid in full... Since his business hours are Monday-Friday daytime... we cannot get him on the phone until next week... If someone knows him please check to see if he is okay.... maybe he had an accident....or something :-[
Mustang based CC Plates GP CLOSED SEE new post
Dmaximum replied to Oscar_the_Grouch's topic in Group Purchase Info
Oscar, Put me down for a set.... Thanks D -
Oscar how much mod's is required to install these plates.. How much cutting...... Please list in order the steps we will reqiure to get these up and running... from start to finish..... List the advantages of having these installed and what you can do with them installed and what the limits are if you don't..... This will help I think more people to consider this product ...including myself.. Best Regards D -
Paid in full Thanks. D
Can you get the 10mm wires in blue ? I see in the post that only the 7mm come in blue... Let me know... D
Put me down for a set 10m plus spreader if avail.. D
I am in for one... D
I am in for a Blue set.. D
Big Brakes Spacer/Brkt KIT Start a new GP ?
Oscar, Please see if you can supply the front brake lines with this kit. You seem to have a good connection for these types of parts and it would be nice to get all the custom parts all at once. Regards D -
You can put me down for one Oscar. I figure getting the kit and the rest of the parts locally I will probly save a wopping 300 or more 8) Thanks D -
Welderwiz's Silicone Hose GP (Order anytime!)
Dmaximum replied to Josh '88's topic in Group Purchase Info
I am down for 35 ft of red and 35 ft of blue D 8) -
1G Mass mod definitely recommended!!!
Dmaximum replied to tmendeol's topic in Engine and Performance Mods
Okay guys I found the problem why my system was running rich..after my 1g conversion... First off ...for anyone that has a problem with the conversion..they should do the following.. recheck the wires and make sure you have them connected correctly...the green and red or on some green and red with one being green and organge....usually this is one of the problems...one of those wires go directly to the tps...you need to double check in your wireing diagram manual ... I will post the exact number and maybe some pics of the correct wireing..later.. There is also two white and black wires that sometimes gets mixed up..so double check if you are not 100% sure.. I found my O2 sensor was bad...after changing it...my car runs perfectly now ..no more running rich... Thanks for all your help All. D -
First off,, you should not remove any the honey comb on the bottom of the mask until you get the mask wired in and working ...you can remove the silencer on the top..that connects to the intake pipe that will not hurt anything. After you get everything working and you are sure..you have the wires correct... Start the car and see how she idles ...the car should idle very well if not better than before... Now take a look at the bottom of your mas and you will see the two honey comb sections.. on that is oval and one that is kinda square....the on that is oval is the none meterd section and can be removed if you feel you car is running too rich...I did not remove mine...I am going to get a safc unit and use that to modify the mixture a bit... later D
Thanks Joel... D -
The Gas Vap tube and all the tubes from the original boot is hooked up exaclty as it was....I made some hoses inserts for the new intake tipe that fits great... It is running so rich that I get large flames out the tail pipe after 2,3 and sometime fourth gears... It looks cool but not a very good for mpg...would love to resolve this problem...if anyone could give me a few more ideas.. Thanks D -
I Just did the 1g mass and civic tube conversion...it does seem to idle better and has a better power range...but it is running too rich  I can smell the gas at idle... I also have to let the car warm up before I can driver...if I try to drive before warming up she bogs..sorta like having the choke on......or something...she seems to be choking with fuel..if she is not warmed up first.. I did not remove anything from the 1g mass, just bolted it in and drilled a hole and mounted the bypass valve to the top of the lid...and connected the hose...just like the original... What you you guys think is the problem.... Thanks D -
I need a front air dam, when you get some pics let me know D
I have a Clifford unit in my quest and it has a built in turbo timer... it came with a auto start unit so just activate and your ready to go.. I don't know about your unit ...sorry Dude Later D
