on4now4 Posted August 16, 2009 Report Share Posted August 16, 2009 Which wire is the one for rpm i need to splice into it for my boost controller Link to comment Share on other sites More sharing options...
Shelby Posted August 16, 2009 Report Share Posted August 16, 2009 i'd sugest you use the dash tach signal wire , from the neg terminal on the coil , not the ecu Link to comment Share on other sites More sharing options...
on4now4 Posted August 16, 2009 Author Report Share Posted August 16, 2009 the instructions say to use the ecu, is there an advantage to using the coil? Link to comment Share on other sites More sharing options...
Shelby Posted August 17, 2009 Report Share Posted August 17, 2009 only if you tap'd into the dash feed after the diode it'd protect the ecu from any short out of your device,, in any event they are both the same signal and the ecu signal is a shield'd wire , the tach signal is not Link to comment Share on other sites More sharing options...
Technology Posted August 17, 2009 Report Share Posted August 17, 2009 Yeah, I think the tach signal should be fine, even though the stock tach isn't very accurate, I think that's a mechanical problem in the tach, not a bad signal issue. It's a white wire with a black stripe going to one of the big plugs behind the cluster. There's a wiring diagram in the service manuals, i think that's where I found which one. Maybe DJ's got one on projectzerog.com Link to comment Share on other sites More sharing options...
on4now4 Posted August 17, 2009 Author Report Share Posted August 17, 2009 hooked up to the coil works perfect thanks Link to comment Share on other sites More sharing options...
Shelby Posted August 18, 2009 Report Share Posted August 18, 2009 i've test'd 4 conquest tachs with machines costing $50k,, all were so close as to be not worth mentioning , now aftermarket units thats a diff story Link to comment Share on other sites More sharing options...
860QuestTuner Posted October 25, 2009 Report Share Posted October 25, 2009 I have an Apexi AFC and used the ecu for tach signal. it was way erratic and off from my tach that was wired off the coil. Link to comment Share on other sites More sharing options...
