G54B3sgte Posted March 28, 2009 Report Share Posted March 28, 2009 (edited) I have a megasquirt version 2 forsale $375 plus shipping flatop pistons std. never installed $60 plus shipping 2 85lb injectors with modified fuel injector rail and bolts $120 plus shipping Timing Chain kit (balance shaft elimination kit without sleave) $65 plus shipping brand new rings never installed std size $50 plus shipping brand new main bearings std size $45 plus shipping brand new rod bearings std size $45 plus shipping magna head without valetrain SOLD!! new oem valves $60 plus shipping schnieder valve springs $65 plus shipping valve seats and keepers and valve guides $70 plus shipping 86 ecu $100 plus shipping 86 airflow meter $50 plus shipping 1st gen dsm airflow meter $50 plus shipping passenger side pacer tail light without harness $50 plus shipping 87 Cluster $25 plus shipping maroon cluster cover $25 plus shipping thats all i can think of for right now if i find more parts i will list them as i find them i do paypal for payments and i do not over charge on shipping ( i hate people who do that) contact me via 817-703-7532 or aim stealthedgt4 pictures of items will be provided for pm requests also will consider trades for 4g6x parts as that is what i am going with i need a head intake and exhaust manifold and turbo a wiring harness and a ecu Edited April 1, 2009 by G54B3sgte Quote Link to comment Share on other sites More sharing options...
Ironside Posted March 28, 2009 Report Share Posted March 28, 2009 Are they clevite bearings??? Quote Link to comment Share on other sites More sharing options...
G54B3sgte Posted March 28, 2009 Author Report Share Posted March 28, 2009 Are they clevite bearings??? the rod bearings are clevite the main bearings are federal mogul Quote Link to comment Share on other sites More sharing options...
Minagera Posted March 28, 2009 Report Share Posted March 28, 2009 Send me pics of the magna head bud, we can maybe work something out. minagera@gmail.com Quote Link to comment Share on other sites More sharing options...
Scotty Dont Posted March 28, 2009 Report Share Posted March 28, 2009 On the megasquirt --What is the circuit board version and what ignition is it set up for? Quote Link to comment Share on other sites More sharing options...
G54B3sgte Posted March 28, 2009 Author Report Share Posted March 28, 2009 (edited) On the megasquirt --What is the circuit board version and what ignition is it set up for? All 'Basic Components' PWM Flyback Damping Circuit components Hall Sensor/Coil(-) and VR Sensor Ignition Trigger Components IGBT High Current Ignition Driver Components Current Limiting Circuit Components MegaSquirt II includes all of the features and benefits of the original... Onboard MAP sensor for NA or boosted engines up to 21psi! Speed density or Alpha-N. Use any injector - High or Low impedance. Compatible with output from narrowband and wideband O2 sensors. Log data on your laptop for later analysis. Tuning software is free for download and regularly updated with new features. Open Source design - all code and hardware information is available online. Includes proper female DB37 connector and shell for building your wiring harness. Additional Features new to the MegaSquirt-II 24 MHz HCS12 processor, Fuel control to 1 µsec (100 times more resolution than MegaSquirt-I), Ignition control (full spark timing advance control, dwell control, etc) for one coil/distributor (7 pin HEI for example) and Ford's EDIS systems, On-board stepper motor driver for IAC stepper control (we install the jumpers for this by default) Ford PWM idle valve firmware support, Built-in rev limiter, either 'fuel cut' or 'spark retard', All tables are now 12×12 in size, WBO2 AFR target table (in AFR units), Independent dual-tables for VE and AFR target, EGO feedback in wide-band mode is proportional to the difference between the measured AFR and the target AFR, the bigger the difference, the bigger the feedback step, Spark advance table can have different rpm and kpa bins than VE and AFR tables, 115,200 baud serial interface with MegaTune2.25+, CANbus networking Barometric correction amount and direction configurable in software, and provisions for: barometric correction based on initial MAP reading, independent 2nd barometric MAP sensor for continuous real-time baro correction, or no baro correction. TPS values for open loop and flood clear mode are user configurable, MAP based open loop can be set as well as TPS, Both TPS and MAP based accel enrichment is built into the code, you can configure the ratio of each, Blended Alpha-N and speed density is an option, 2 spare I/O lines for custom controls. (This is in addition to 4 lines for Idle stepper control if you don't need this, or the Fast idle solenoid then becomes a spare if you do use a stepper motor.) Edited March 28, 2009 by G54B3sgte Quote Link to comment Share on other sites More sharing options...
Scotty Dont Posted March 28, 2009 Report Share Posted March 28, 2009 Sweet I already now all that info im running ms i just want to know the pcb version number. Quote Link to comment Share on other sites More sharing options...
G54B3sgte Posted March 28, 2009 Author Report Share Posted March 28, 2009 Sweet I already now all that info im running ms i just want to know the pcb version number. MegaSquirt-II Engine Management System w/PCB3.0 Quote Link to comment Share on other sites More sharing options...
Fome Posted March 28, 2009 Report Share Posted March 28, 2009 whats the info on the pistons (brand, size, cast hypers, ect) Quote Link to comment Share on other sites More sharing options...
G54B3sgte Posted March 29, 2009 Author Report Share Posted March 29, 2009 whats the info on the pistons (brand, size, cast hypers, ect) size STD. as it was posted made by Perfect Circle Cast pistons these are flat tops as i stated above not stock turbo pistons Quote Link to comment Share on other sites More sharing options...
81zfan Posted March 29, 2009 Report Share Posted March 29, 2009 what about the timing chain kit can i get pics to wooten82@aol.com Quote Link to comment Share on other sites More sharing options...
G54B3sgte Posted March 29, 2009 Author Report Share Posted March 29, 2009 what about the timing chain kit can i get pics to wooten82@aol.com email sent with pics Quote Link to comment Share on other sites More sharing options...
G54B3sgte Posted March 29, 2009 Author Report Share Posted March 29, 2009 i will be away from the computer most of today so its either best to call me or send me an email because all my emails go to my phone the email adress is stealthedgt4@aim.com Quote Link to comment Share on other sites More sharing options...
G54B3sgte Posted March 30, 2009 Author Report Share Posted March 30, 2009 bump Quote Link to comment Share on other sites More sharing options...
87quest-TSI Posted March 30, 2009 Report Share Posted March 30, 2009 Can you send me some pics of the magna head to quest@jeepquest.net Quote Link to comment Share on other sites More sharing options...
G54B3sgte Posted March 30, 2009 Author Report Share Posted March 30, 2009 pics have sent to the guys who have requested Quote Link to comment Share on other sites More sharing options...
G54B3sgte Posted March 31, 2009 Author Report Share Posted March 31, 2009 I have a megasquirt version 2 forsale $375 plus shipping flatop pistons std. never installed $60 plus shipping 2 85lb injectors with modified fuel injector rail and bolts $120 plus shipping Timing Chain kit (balance shaft elimination kit without sleave) $65 plus shipping brand new rings never installed std size $50 plus shipping brand new main bearings std size $45 plus shipping brand new rod bearings std size $45 plus shipping magna head without valetrain been ported and polished SOLD! new oem valves $60 plus shipping schnieder valve springs $65 plus shipping valve seats and keepers and valve guides $70 plus shipping 86 ecu $100 plus shipping 86 airflow meter $50 plus shipping 1st gen dsm airflow meter $50 plus shipping passenger side starion tail light without harness $50 plus shipping 87 Cluster $25 plus shipping maroon cluster cover $25 plus shipping thats all i can think of for right now if i find more parts i will list them as i find them i do paypal for payments and i do not over charge on shipping ( i hate people who do that) contact me via 817-703-7532 or aim stealthedgt4 pictures of items will be provided for pm requests also will consider trades for 4g6x parts as that is what i am going with i need a head intake and exhaust manifold and turbo a wiring harness and a ecu Quote Link to comment Share on other sites More sharing options...
Quest4life Posted March 31, 2009 Report Share Posted March 31, 2009 Do you have a pic of the cluster? What color? Dos it include the switches? Thanks Quote Link to comment Share on other sites More sharing options...
G54B3sgte Posted April 1, 2009 Author Report Share Posted April 1, 2009 bump Quote Link to comment Share on other sites More sharing options...
G54B3sgte Posted April 3, 2009 Author Report Share Posted April 3, 2009 bumpx2 Quote Link to comment Share on other sites More sharing options...
G54B3sgte Posted April 5, 2009 Author Report Share Posted April 5, 2009 bump+ Quote Link to comment Share on other sites More sharing options...
