Guest Posted June 18, 2002 Report Share Posted June 18, 2002 Well ladies and gentlemen I've been doing some research and have found that some of the higher output pumps made by Carter (Federal MOgul) are really Walbro pumps . The P72131 comes in a Carter box but has the Walbro stamp on the pump with part #GSL392 which in the Carter book only flows 55gph with a cut off psi of 190 . I called Walbro and they said that pump flows 255lph which is alot . I ordered one in and it is an inline pump with a 1/2" inlet and a banjo nipple on the outlet . The stock banjo fitting can be mounted on it you just can't use the pulse fitting on the end . A standard 10mx1.0m nut with the brass washers should hold the pressure. I'm putting a 1/2" nipple on the outlet since I'm running -08 stainless steelbraided fuel line . Peace Geo Link to comment Share on other sites More sharing options...
PiercedJD Posted June 20, 2002 Report Share Posted June 20, 2002 how much was it? and where di you order it from? www.autoperformanceengineering.com has some 255 lph externals, have been wondering how well they'd fit though...... Link to comment Share on other sites More sharing options...
ZeroKewl9 Posted June 28, 2002 Report Share Posted June 28, 2002 Yeah I too would like to know the price..... ttt Link to comment Share on other sites More sharing options...
Guest Posted June 30, 2002 Report Share Posted June 30, 2002 I can get them for 149.00 with a lifetime warranty but the you would have to order a fitting to match your fuel line . I'm running -08 (1/2") fuel line . It comes with a 1/2" inlet and banjo fitting for the outlet . The size is the same as ours maybe 1/2" smaller in diameter otherwise the same . That web sight lists different fittings I believe the 10mm will fit the stock line.. Peace Geo Link to comment Share on other sites More sharing options...
artinist Posted March 3, 2003 Report Share Posted March 3, 2003 I havent tried this guy yet but his walbro pumps for the 3000GT are dirt cheap. i am sure if we give him a part number he can order that also. http://www.importpoweronline.com/walbro.html Link to comment Share on other sites More sharing options...
Rusky Posted March 4, 2003 Report Share Posted March 4, 2003 Anyone know what this will support? Horsepower wise? artinist, your website has that pump for $120 shipped. Sounds like a good price. Geo, how is the pump working? Link to comment Share on other sites More sharing options...
Boosted_One Posted March 5, 2003 Report Share Posted March 5, 2003 Just make sure you get the external pump as the DSM and 3KGT are intanks. There's also 2 versions... a 190LPH and a 255LPH external. Link to comment Share on other sites More sharing options...
artinist Posted March 5, 2003 Report Share Posted March 5, 2003 this is a very high caliber pump. the in-tank version is used on eclipses and 3000GTs for 500+hp Link to comment Share on other sites More sharing options...
Jake87TSI Posted March 5, 2003 Report Share Posted March 5, 2003 lightningmotorsports.com has these pumps..... Link to comment Share on other sites More sharing options...
A187A Posted March 7, 2003 Report Share Posted March 7, 2003 http://apeusa.com/test does also Link to comment Share on other sites More sharing options...
Rusky Posted March 7, 2003 Report Share Posted March 7, 2003 Okay, now which type is better ??? the in-tank or the external? And is there any good performance in-tank pump? Thanks. Link to comment Share on other sites More sharing options...
artinist Posted March 7, 2003 Report Share Posted March 7, 2003 best in-tank is the supra pump. but thats what it is. an in-tank pump and it wont fit the starion. Link to comment Share on other sites More sharing options...
Prtaick Posted April 29, 2005 Report Share Posted April 29, 2005 sorry i know this post is hella old but this fuelpump thing ie really getting to me Fuel Pump (OE Electric In-Line Type) Pressure Rating: 95 Gallons Per Hour: 68-93 THATS 257-352lph !!!!!!!! http://partimages.genpt.com/partimages/169926.jpg "NAPA" whats wrong with our stock pump? Link to comment Share on other sites More sharing options...
Prtaick Posted April 29, 2005 Report Share Posted April 29, 2005 350lph is that wrong? Link to comment Share on other sites More sharing options...
Kr0nus Posted April 29, 2005 Report Share Posted April 29, 2005 The GSL 392 is $127 shipped with the kit that is compatible with our cars is at www.autoperformanceengineering.com like someone already said. You have to type in StarQuest under the promotion code when you buy. Link to comment Share on other sites More sharing options...
860QuestTuner Posted April 30, 2005 Report Share Posted April 30, 2005 on the walbro website they have flow graphs for the pump.As to visible size difference the 255 for the dsm is a smaller in tank style, but size in the case doesn;t matter. My buddie has a holley pump that looks just like my walbro. Per the rep from walbro the pumps are bought from a main manufacturer that many companys use but are built internally different. Our stock pumps don't flow nearly enough volume than the walbro pump. I have the 255 in my quest and it moves fuel like water out of a firehose. also the turbo or supercharged cougers used the same fuel pump as ours stock. Not sur of year though. Link to comment Share on other sites More sharing options...
Prtaick Posted April 30, 2005 Report Share Posted April 30, 2005 wait... you said some interesting things but im not talking about the "gsl 392" im talking about our stock pump flowing 352lph and 860QuestTuner what are you talking about? did you read what you wrote before you posted it ? oh and walbro supplies pumps to napa. that's what most of there replacement pumps are Link to comment Share on other sites More sharing options...
860QuestTuner Posted April 30, 2005 Report Share Posted April 30, 2005 What ?our replacement pump at napa are not walbro, I didn't say that. The stock pump will not provide enough volume for high boost/high power period. If you are staying with stock turbo and light mods keep the stock pump. It doesn't flow what you say,I have flow tested a stock pump in person. Anyway I was saying that most aftermarket fuel pump parts are made by one manufacturer and built/moded by another,thats why so many look alike-as stated in an earlyer post. Link to comment Share on other sites More sharing options...
860QuestTuner Posted April 30, 2005 Report Share Posted April 30, 2005 I believe the pressure rating for the walbro is 150 psi max, Oh and if you were wondering I did destroy my stock pump overworking it. I was't saying the stock pump was bad,they have been lasting like 15 years in some cars. They don't meet demand of a higher output fuel system. Link to comment Share on other sites More sharing options...
Prtaick Posted April 30, 2005 Report Share Posted April 30, 2005 ok im not going to go on anymore about the stock pump till i can go get some real #s from it. im just going off what was listed in the book for this pump when i worked at napa and i looked it up. i also looked up pumps for justabout everything under the sun ( supra, 300zx, some older porsches and even a bunch of puckup trucks! ) and they all had the same specs as shown everywhere online. so why would they lie about our pump? and the otherthing i was saying is that napa replacement pumps for the most part ARE walbro pumps. well atleast at my store 85 out of 100 had the walbro logo stamped on them Link to comment Share on other sites More sharing options...
wolfsquest Posted May 1, 2005 Report Share Posted May 1, 2005 Thanks, Prtaick, for posting that pic in reply#12 is that a gsl-392?! How much was it at napa? Link to comment Share on other sites More sharing options...
Prtaick Posted May 1, 2005 Report Share Posted May 1, 2005 yeah i dont know what a 392-gsl is that pic is a P70199 napa pump its $140. they also sell a lowerpriced one the 2P70199 for $89 . i worked there so i got my pump for like $50 Link to comment Share on other sites More sharing options...
wolfsquest Posted May 1, 2005 Report Share Posted May 1, 2005 The reason I asked, is 'cause I went and bought one @ Napa w/the 2p part# and it had walbro 392 stamped on it and it looks EXACTLY like that one, for $89.95+tx., but I was told by someone here that it COULDN'T be (he's only a 1000mi. away in N.M.!) a walbro @ that price. Maybe NOW he'll learn to S.T.F.U. when someone else finds a good deal!! Props, and thanks!! Link to comment Share on other sites More sharing options...
Prtaick Posted May 1, 2005 Report Share Posted May 1, 2005 i dont know what my pump said on it but it to "moves fuel like water out of a firehose" im doing some work on my fuelsystem soon ill haveto flow test the pump and see what its all really about Link to comment Share on other sites More sharing options...
Kr0nus Posted May 6, 2005 Report Share Posted May 6, 2005 The reason I asked, is 'cause I went and bought one @ Napa w/the 2p part# and it had walbro 392 stamped on it and it looks EXACTLY like that one, for $89.95+tx., but I was told by someone here that it COULDN'T be (he's only a 1000mi. away in N.M.!) a walbro @ that price. Maybe NOW he'll learn to S.T.F.U. when someone else finds a good deal!! Props, and thanks!! You found one at your Napa that was right. Other people went to Napa with the same part number and got a Master FP. I honestly think you got lucky man. One of 2 things happened either you got the wrong one or the other guys did. Either way the Napa guys need to stick to one pump (EVERYWHERE), and I hope it will be the real GSL 392 because that is a sweet a** price. Prtaick My FP (392) really did flow like a firehose LOL. It's nuts. Just put a hose in some water and hook it up and check out how much water comes out. Link to comment Share on other sites More sharing options...
