GoFastBeater Posted April 24, 2005 Report Share Posted April 24, 2005 I notice people sometime avoid installing a fuel pressure gauge due to price.  This is a nice setup for a decent price.  Just thought I'd throw it up here. Sender  Summit part NRD-S8434  $59.95http://www.we-todd-did-racing.com/wetoddimage.wtdr/wODkyMDcwNnM0MTNkZmQzMXk1NDE=.jpg Mechanical gauge  Summit part NRD-K7040B  $45.95http://www.we-todd-did-racing.com/wetoddimage.wtdr/wODkyMDY2NnM0MTNkZmQzMXk1NDE=.jpg Digital gauge  Summit part NRD-M8034  $59.88http://www.we-todd-did-racing.com/wetoddimage.wtdr/wODkyMDY4NnM0MTNkZmQzMXk1NDE=.jpg The mechanical gauge has an amber backlight and matches the factory gauges nicely.  I switched to the digital because its much easier to glance down to get an exact idea what your pressure is. ADAM Link to comment Share on other sites More sharing options...
Truth Posted April 25, 2005 Report Share Posted April 25, 2005 damn, so you can get out for under a hundred bucks for a change. that's cool. i been looking for a gauge that i can get for my new three gauge pod from jolyrgr Link to comment Share on other sites More sharing options...
D_Venable Posted April 25, 2005 Report Share Posted April 25, 2005 Are you selling the analog gauge then? If so, how much you want for it? Derek Link to comment Share on other sites More sharing options...
GoFastBeater Posted April 25, 2005 Author Report Share Posted April 25, 2005 Pm'ed you. ADAM Link to comment Share on other sites More sharing options...
MANGO Posted September 7, 2005 Report Share Posted September 7, 2005 the sending unit, it only works with the digital gauge you have right? or does the sending unit required for the mechanical too? thanks!MANGO Link to comment Share on other sites More sharing options...
heefner Posted September 7, 2005 Report Share Posted September 7, 2005 Its a digital and analog gauage, mechanical gauges don't use sending units, they run a fuel line right to the back of the gauge. Thats a no no for an in the cabin fuel pressure guage. Link to comment Share on other sites More sharing options...
D_Venable Posted September 7, 2005 Report Share Posted September 7, 2005 The ANALOG gauge (Summit part NRD-K7040B $45.95, same one as above) I bought off Adam does require the same sending unit, as it's still an electronic gauge. Derek Link to comment Share on other sites More sharing options...
MANGO Posted September 7, 2005 Report Share Posted September 7, 2005 ooopps, yep, you folks are correct. i meant the "analog" one which I had mistaken for a mechanical gauge. Thank you for clearing that up,MANGO Link to comment Share on other sites More sharing options...
GoFastBeater Posted September 7, 2005 Author Report Share Posted September 7, 2005 My fault. I should have used the proper terminology to begin with. ADAM Link to comment Share on other sites More sharing options...
Boosted_One Posted September 13, 2005 Report Share Posted September 13, 2005 Ya I use that same digital fuel pressure gauge and the electric sender. It works fine for me. 36psi baseline. 46 psi under boost. Nice install. Link to comment Share on other sites More sharing options...
underpsi Posted September 20, 2005 Report Share Posted September 20, 2005 You can use a mechanical fuel pressure gauge in the cabin. The unfortunate part is having to purchase an isolator to keep the fuel out of the cabin. Personally I like the electric set-up for a clean simple install. just my 2 cents Link to comment Share on other sites More sharing options...
Boosted_One Posted September 20, 2005 Report Share Posted September 20, 2005 You can use a mechanical fuel pressure gauge in the cabin. The unfortunate part is having to purchase an isolator to keep the fuel out of the cabin. Personally I like the electric set-up for a clean simple install. just my 2 cents also electrical is safer too...less plumbed lines, etc. Link to comment Share on other sites More sharing options...
Banky Posted December 12, 2005 Report Share Posted December 12, 2005 Im going to be installing a magna MPI soon. Where can I put this sender? Link to comment Share on other sites More sharing options...
Trilogy Turbos Posted December 17, 2005 Report Share Posted December 17, 2005 I had this Norsdok setup a few years ago; everytime I hit 20psi the sender went bad; Summit sent me a total of 4 sending units in 1 year.I swap to a nice setup that is lasting for about 2 1/2 to 3 years now.It's not cheap,$175.00, but it reads up to 150psi (if necessary :roll: ).Here is the link.... http://www.trilogyturbos.com/shop2.cfm?ct=13&st=0 Regards, HeronTrilogy Turbos Link to comment Share on other sites More sharing options...
