Bruno Posted March 18, 2009 Report Share Posted March 18, 2009 ok here's the story i bought a 88 tsi for a few bucks so i can use that motor for my 89tsi. the owner had it sitting outside for about 17 months.without starting it, he said there was nothing wrong with the engine when he last drove it . im thinkn its stuck some how, i put a breaker bar on the on the crank with an xtension and could not turn the it only the bolt turned i so topped cuz i do not want to snap that bolt, if it was a standard i could put it 1st hook a chain to my truck and try breaking it free but its an AUTO unless it would work if the gear is in DRIVE is the tourque convertter stuck, PLEAS ANYONE give me sum ideas besides the motor bein seized lol thanks for ur time and opinion!!! Link to comment Share on other sites More sharing options...
UlrichWolf Posted March 18, 2009 Report Share Posted March 18, 2009 Bruno, try pulling the plugs out, and dripping a little automatic transmission fluid in the cylinders. Try to rock it back and forth a little bit, see if it will snap loose. Otherwise, you're ripping into it. Tim Link to comment Share on other sites More sharing options...
BrazilBoy Posted March 18, 2009 Report Share Posted March 18, 2009 Pull plugs fill pistons with wd40 let soak overnight, pull starter and use crow bar to go tooth by tooth on the flywheel.. If the torque converter is stuck, put the rear end on jack stands and turn it if the rear wheels turn then its the converter Link to comment Share on other sites More sharing options...
Shelby Posted March 18, 2009 Report Share Posted March 18, 2009 real easy and simple remove the rad cap if no coolant is visiable,, your most likely out of an engine,,,next remove the spark plugs payiing attention where each came form,,any with strange looking crap on them,, rip the head off the rings have more then likely had coolant get to them and the pistons , now it's close to being a boat anchor Link to comment Share on other sites More sharing options...
Bruno Posted March 18, 2009 Author Report Share Posted March 18, 2009 real easy and simple remove the rad cap if no coolant is visiable,, your most likely out of an engine,,,next remove the spark plugs payiing attention where each came form,,any with strange looking crap on them,, rip the head off the rings have more then likely had coolant get to them and the pistons , now it's close to being a boat anchor come on shelby think positive lol hahahaha, well afer work 2day i took the plugs out and poured sum mystery oil in each cylinder gonna wait til saturday then try rokin it and then lft the rear up and do what brazil boy said. thanks for ur advice shelby,ulrichwolf,and brazilboy Link to comment Share on other sites More sharing options...
cyberquest Posted March 19, 2009 Report Share Posted March 19, 2009 i got one loose once by using the same bar i use for removing FW bolts. just a long peice of angle iron drilled to bolt to the holes in the FW. but as shelby said, chances are it was parked for a blown head gasket, with coolant sitting in the cylinders rust has taken its coarse. even if you get it free, a hone and new rings will be needed for sure. Link to comment Share on other sites More sharing options...
Shelby Posted March 19, 2009 Report Share Posted March 19, 2009 (edited) more damage will be done by forceing the engine to turn then by doing a partial tear down and look for sure at what the problem is,, been there all too many times one thing for dam sure DO NOT pull it and try to get the engine to turn over Edited March 19, 2009 by Shelby Link to comment Share on other sites More sharing options...
vbrad511 Posted March 19, 2009 Report Share Posted March 19, 2009 I've used the ATF trick before successfully. But if it were mine I'd probably pull the head to to see what was there, unless you've accepted that it's a junk motor. Doesn't take but an hour or so. Link to comment Share on other sites More sharing options...
3wrf381 Posted March 20, 2009 Report Share Posted March 20, 2009 diesel works wonders as well, i used it on an old generator that had been sitting for 15 years. Link to comment Share on other sites More sharing options...
Shelby Posted March 20, 2009 Report Share Posted March 20, 2009 got an engine that won't turn over try backing it up a little,, if it backs up or turns back wards something is broken and locking the engine ,, on one thats been seting 99times out of 100 it's water or coolant in the cyls,, and even if soaking it frees it up the trash need to be clean'd out so it's abetter option to remove the head and inspect Link to comment Share on other sites More sharing options...
Edde Posted March 20, 2009 Report Share Posted March 20, 2009 got an engine that won't turn over try backing it up a little,, if it backs up or turns back wards something is broken and locking the engine ,, on one thats been seting 99times out of 100 it's water or coolant in the cyls,, and even if soaking it frees it up the trash need to be clean'd out so it's abetter option to remove the head and inspect Home style honing job, one cylinder at a time Link to comment Share on other sites More sharing options...
