GREENSTAR Posted January 15, 2004 Report Share Posted January 15, 2004 What's up guys! I am in the process of trying to get this to work. I have a few more bugs to work out on my side. I have an over rich problem which is caused by not have my water temp sensor hooked up because the little connection broke off but I am going to fix that this weekend. I did splice in the 1G MAS to my stock 86 MAS harness. I only had to run one extra wire to a switched 12v and 4 of the like wires. Two of the wires from the 1G mas will not be used. I don't want to preach that this works yet because I have not smoothed it out but so far I do get an idle and I can get some RPM's but with my over rich problem it is hard to tell if this works 100%. I have to give full credit to Chad for the wiring set up! Thanks man. I will keep all of you 86 guys posted if this works or not. I am going to work on it this weekend and I will give you results! Keep your fingers crossed. This will be a big step for all of the 86 guys to get rid of that damn stock mas! Thanks! Steve Link to comment Share on other sites More sharing options...
Ratmtattat Posted January 16, 2004 Report Share Posted January 16, 2004 I thought you were running without the MAS, like I am? Were you? and if you were, what changed your mind? Link to comment Share on other sites More sharing options...
GREENSTAR Posted January 16, 2004 Author Report Share Posted January 16, 2004 What's up man? Yeah, I was before I blew my stock motor. But I am doing my break in on my new motor and I want to make sure that all is running good. Plus, with the mas unhooked before it seemed that i did not get an accurate reading on the A/F gauge. I want to try and get the 1g mas to work and then ultimately go to the GM MAF route. We will see. I am just trying out my options. Steve Link to comment Share on other sites More sharing options...
jpitty Posted July 19, 2004 Report Share Posted July 19, 2004 So how well has this worked so far and witch terminal goes to positive and witch goes to negitive on the first gen mass Link to comment Share on other sites More sharing options...
edjee Posted July 23, 2004 Report Share Posted July 23, 2004 I was kinda wondering too, do I need to hook up + and - to the one red wire on the 1g mas? Or is it just the + on the ignition coil? Thx ;D Link to comment Share on other sites More sharing options...
Borinken Posted July 29, 2004 Report Share Posted July 29, 2004 Thanks for replying to my question. You said that there are two wires in the 1g mas that are not used, which one is it. And where is the 12v wire coming from? Thanks Link to comment Share on other sites More sharing options...
GREENSTAR Posted August 4, 2004 Author Report Share Posted August 4, 2004 If you go further into the Engine mods you will see my post exactly how to hook everything up. Steve Link to comment Share on other sites More sharing options...
G54Bstore Posted August 7, 2004 Report Share Posted August 7, 2004 so once the 1g mas is hooked up. that means no fuelcut right? Link to comment Share on other sites More sharing options...
ESIrType? Posted August 10, 2004 Report Share Posted August 10, 2004 so once the 1g mas is hooked up. that means no fuelcut right? A $3 10k ohm pot switch will change the fuel cut on the 86 for you. My brother did this and it worked great! The 1g mas should raise the fuel cut though. Shawn Link to comment Share on other sites More sharing options...
G54Bstore Posted August 11, 2004 Report Share Posted August 11, 2004 A $3 10k ohm pot switch will change the fuel cut on the 86 for you. My brother did this and it worked great! The 1g mas should raise the fuel cut though. Shawn yeah no 1 ever achived over 15psi with 1 of those. Link to comment Share on other sites More sharing options...
Too Deep Posted August 12, 2004 Report Share Posted August 12, 2004 so once the 1g mas is hooked up. that means no fuelcut right? mass has nothing to due with fuel cut on an 86 pressure sensor and ecu control fuel cut Link to comment Share on other sites More sharing options...
G54Bstore Posted August 12, 2004 Report Share Posted August 12, 2004 yep thats what i thought. so wut is the point of a 1 g mas then? ??? i just hacked the hell out of my stock 1 of course leaving the metered honey comb part alone. it flow plenty of air now.enough that i can run a stock 86 inj and the secondary injector. why worry about a 1g mas on a 86 setup for? Link to comment Share on other sites More sharing options...
Guest surferdude Posted August 13, 2004 Report Share Posted August 13, 2004 What did you hack on your stock MAF? Take out the two "slot" boards in the can's outlet neck? What about the MAF itself? I have a good unhacked 1g MAS and bought a 3" Honda intake tube off of E-BAY plus some really nice silicone connectors. Sounds like I might have wasted a bunch of $$$. I also have a Python secondary for a 87-89 - think I might try it. Link to comment Share on other sites More sharing options...
G54Bstore Posted August 13, 2004 Report Share Posted August 13, 2004 i got a python 86 injector i run along with the sec.but then again i run the 86 setup in my 88.i know this sounds weird but works for me. usually peoplr replace the 86&87 system for the 88 89 . i hacked my stock sensor by drilling holes all in the tubes in it past the 2 "slot"boards u are talking about. i mean think about it the square holes where the "slot"boards are isnt that restrictive. it s where the air has to pull through the 2 air tubes in the bottom that makes the air very restricted. Link to comment Share on other sites More sharing options...
GREENSTAR Posted August 14, 2004 Author Report Share Posted August 14, 2004 Sorry guys, I have been in and out of the scene since I sold my greenstar but I still hopp on as much as I can. I am glad to see people are still interested in the 1G on the 86. I can tell you that it surely made a big difference on my old 86. I was running 20 + PSI and it ran beautiful for me. I still am around guys if you need any help with this. Shoot me an email. Steve Link to comment Share on other sites More sharing options...
edjee Posted January 14, 2005 Report Share Posted January 14, 2005 mass has nothing to due with fuel cut on an 86 pressure sensor and ecu control fuel cut This is true, I got the instructions for the hks fcd on an 86, and you connect it to the pressure sensor output(A9) on the ecu. Link to comment Share on other sites More sharing options...
