how to push rear brake piston 87 quest
tristarionTSI
Guest Kenmarrow
I just did the rear brakes on the 89 today.. They were a real SOB.. had to take them off the car and use a punch and hammer to get these to turn after soaking with PB Blaster.. This car had been sitting for 14 years and things are just tuff to move on it.. and the reason behind "if it at first does not move, get a BIGGER hammer".. Good luck
Got the piston back in, now brakes dragging, gonna adjust and bleed. they were a bear
Thanks
Do you know why they are dragging? Its because that crusty piston turned back into that crusty cylinder and the oring that seals the fluid in is also crusty in the groove it lays in. The boot you saw on the outside is also supposed to turn on the piston in a groove. All those crusty surfaces is the main reason the rear brakes stick and don't work (worth a damn) on most all of these cars. The parking brake lever on the back, the wedge and center piston stick too because of those stacked spring washers that bind in the back side because they rust and stick the e-brake on. If you just screwed the piston back in all you did was force it past rust to put on new pads but they will drag and slow you down all the time because they can not release. Have to 100% completely tear them down to rebuild them or just replace them. It takes some patience to get the wedge back in under the parking lever unless you have the tool to press the spring washers down.
