clbsinvaders Posted March 20, 2008 Report Share Posted March 20, 2008 So I finally pull it out of the garage, only to find out there's a big freaking oil leak. No, the motor's not blown, just a lot of oil lost. It's coming from either the filter or just in front of the filter (closer towards the nose). Does anyone know what part may be leaking? I am so, so, so freaking close to having this completed; bleed brakes and run vacuum hose for boost gauge, and now this. Please help! It lost a half quart or more in the 2 minutes I had it running. Link to comment Share on other sites More sharing options...
PDX87Starion Posted March 20, 2008 Report Share Posted March 20, 2008 Both my oil cooler hoses started leaking on mine. It was kinda hard to locate the leak too. I removed the lines cut off the factor crimp, and took them to a hydrolic hose place. They matched the hose and length and crimped them on the the factory fittings for about $20.00 (for both). Also could be o-rings in the oil filter adapter. Link to comment Share on other sites More sharing options...
clbsinvaders Posted March 20, 2008 Author Report Share Posted March 20, 2008 I should mention it's only when the car runs. Oil cooler lines? Link to comment Share on other sites More sharing options...
scott87star Posted March 21, 2008 Report Share Posted March 21, 2008 Mine was similar, somehow I must have bumped the oil cooler lines because I was able to torque them down to spec and they are fine. Scott Link to comment Share on other sites More sharing options...
