chiplee Posted October 24, 2007 Report Share Posted October 24, 2007 hydraulic rocker shafts needed to 22193. Offering $30 for the trouble, shipped. Will not accept a rocker assembly though. You need to dissassemble the assembly from a known good engine, inspect the shafts, have no trouble removing the cam towers and send only the two shafts. Looking for someone well known and knowledgable here. Quote Link to comment Share on other sites More sharing options...
99custcoug Posted October 24, 2007 Report Share Posted October 24, 2007 misubishiparts.com 37.xx a side these fit 86-89 cant find a prt number on them handy but they are there Quote Link to comment Share on other sites More sharing options...
quikconq Posted October 24, 2007 Report Share Posted October 24, 2007 well chip lmk if i can help ya out,,,and wat to look for ,,,as i want you to get exactly wat you ask for i have several sets thanx bryen Quote Link to comment Share on other sites More sharing options...
chiplee Posted October 24, 2007 Author Report Share Posted October 24, 2007 well chip lmk if i can help ya out,,,and wat to look for ,,,as i want you to get exactly wat you ask for i have several sets thanx bryen thanks. how do you have them? are they still in rocker assemblies are are they removed? If they're still in rocker assemblies you'll just have to pull all the bolts out and start trying to work the ends off, then the springs then the rockers and so on until the shafts are free.. What I'm looking for is that during this process you experience NO hangups or significant sticky spots while you're sliding parts off of the shafts. If they've ever been cranked down all the way in the middle or had the bolts tighted out of sequence badly they could be slightly bent. There are also typically burrs on the bolt holes that can scrape the insides of the rockers while you're assembling the thing. You might experience some minor sticking as the cam towers slide off because of some simply misalignment between the two shafts causing more friction on one than on the other. this is fine. Let me know if you think you have a good set and if my "offer" will suffice and I'll send the money via paypal. Quote Link to comment Share on other sites More sharing options...
quikconq Posted October 24, 2007 Report Share Posted October 24, 2007 well i have several,,like i said,, some on cracked heads some still in assembly form in a boxand some just the shafts lmk go check the loose shafts real quik bryen Quote Link to comment Share on other sites More sharing options...
chiplee Posted October 24, 2007 Author Report Share Posted October 24, 2007 well i have several,,like i said,, some on cracked heads some still in assembly form in a boxand some just the shafts lmk go check the loose shafts real quik bryen if you can slide rockers smoothly over the shafts with very few minor catches or sticky spots they're probably fine, but until you get to sliding actual cam towers over them you won't really know how straight they are. We also have to be 100% certain thay are hydraulic and not mechanical shafts. Quote Link to comment Share on other sites More sharing options...
quikconq Posted October 24, 2007 Report Share Posted October 24, 2007 well crap i just found a decent set,,,the arms and towers slid off with easebut i didnt check which arms hyd or mech ,,as i do have several of eachout of the 7 sets this is the only pair im comfortable in sellin how do i tell the difference in them????? Quote Link to comment Share on other sites More sharing options...
chiplee Posted October 24, 2007 Author Report Share Posted October 24, 2007 well crap i just found a decent set,,,the arms and towers slid off with easebut i didnt check which arms hyd or mech ,,as i do have several of eachout of the 7 sets this is the only pair im comfortable in sellin how do i tell the difference in them????? not sure, hyds should have an extra oil hole or something. I haven't used hyds in a while so I don't have a set, hence the "items wanted" post. I'll try to find out. thanks for looking at them though. Quote Link to comment Share on other sites More sharing options...
99custcoug Posted October 24, 2007 Report Share Posted October 24, 2007 on the hyd i am pretty sure ther are 3 oil holes on one of the shaft and only one on the other IIRC just had mine out to put roller rockers on and cant remember mine were out of a stock 87 tsi and i remember one of the shafts had more oil holes in it than the other Quote Link to comment Share on other sites More sharing options...
emagdnim Posted October 24, 2007 Report Share Posted October 24, 2007 Chip, I recommend going to mitsu to get shafted. :wink: Quote Link to comment Share on other sites More sharing options...
quikconq Posted October 24, 2007 Report Share Posted October 24, 2007 welli have some complete heads i could go thru,,,,or a parts book might have it in there too Quote Link to comment Share on other sites More sharing options...
99custcoug Posted October 24, 2007 Report Share Posted October 24, 2007 Chip, I recommend going to mitsu to get shafted. :wink: lol on more than one level lol even though the price on them isnt to bad 30.xx or so a peice and your guaranteed no burrs or anything like that if you could wait a week or two before you need them i'll have a parts car i can check them out for you but couldnt guarantee anything on those either what one person says comes off easily and no hang up another person may think is harder than hell to get off nothing against anyone in this topic but everyone has a different idea of "easy" Quote Link to comment Share on other sites More sharing options...
emagdnim Posted October 24, 2007 Report Share Posted October 24, 2007 I would spend the 60 bucks not to ruin my race head. :oops: Quote Link to comment Share on other sites More sharing options...
chiplee Posted October 24, 2007 Author Report Share Posted October 24, 2007 Chip, I recommend going to mitsu to get shafted. :wink: lol on more than one level lol even though the price on them isnt to bad 30.xx or so a peice and your guaranteed no burrs or anything like that if you could wait a week or two before you need them i'll have a parts car i can check them out for you but couldnt guarantee anything on those either what one person says comes off easily and no hang up another person may think is harder than hell to get off nothing against anyone in this topic but everyone has a different idea of "easy" yeah that's a good point. I'll probably do it that way. Quote Link to comment Share on other sites More sharing options...
99custcoug Posted October 24, 2007 Report Share Posted October 24, 2007 at mitsubishiparts.com its 74.39 for intake and exhaust shaft plus 15% shipping 14.95 minumum fits 86-89 i would go that way also Quote Link to comment Share on other sites More sharing options...
MontyTSI Posted October 24, 2007 Report Share Posted October 24, 2007 helpful info.... All rocker shafts will have some degree of difficulty in removal. 100k plus miles does wear them just a bit. I think what chip wants is for the seller to make sure the shafts are "true". Ive never had any rocker shafts just "slide out" with out at least a little motivation. Just trying to help bud Quote Link to comment Share on other sites More sharing options...
Dad Posted October 24, 2007 Report Share Posted October 24, 2007 Looking for someone well known and knowledgable here. I probably have a set-- I know I sent 2 new shafts to regginrx7 on here, But I may not fit your requirements. Dad I'll take a look today Quote Link to comment Share on other sites More sharing options...
quikconq Posted October 24, 2007 Report Share Posted October 24, 2007 Chip, I recommend going to mitsu to get shafted. :wink: lol on more than one level lol even though the price on them isnt to bad 30.xx or so a peice and your guaranteed no burrs or anything like that if you could wait a week or two before you need them i'll have a parts car i can check them out for you but couldnt guarantee anything on those either what one person says comes off easily and no hang up another person may think is harder than hell to get off nothing against anyone in this topic but everyone has a different idea of "easy" first off im not gonna waste any more of my time,,,,from the ones ive disassembled these slid right off NO degree of force the others did,,,and even the ones that ive had on runnin motors needed more force to get them apart second i was doin wat was asked from chipbut i do agree i would go new for a race head i was just responding to a wanted post,,,and i do have one decent pair glbryen Quote Link to comment Share on other sites More sharing options...
chiplee Posted October 24, 2007 Author Report Share Posted October 24, 2007 Chip, I recommend going to mitsu to get shafted. :wink: lol on more than one level lol even though the price on them isnt to bad 30.xx or so a peice and your guaranteed no burrs or anything like that if you could wait a week or two before you need them i'll have a parts car i can check them out for you but couldnt guarantee anything on those either what one person says comes off easily and no hang up another person may think is harder than hell to get off nothing against anyone in this topic but everyone has a different idea of "easy" first off im not gonna waste any more of my time,,,,from the ones ive disassembled these slid right off NO degree of force the others did,,,and even the ones that ive had on runnin motors needed more force to get them apart second i was doin wat was asked from chipbut i do agree i would go new for a race head i was just responding to a wanted post,,,and i do have one decent pair glbryen thanks for the effort. I guess at least now you know you have a known good set ready to sell. You waffled on knowing whether they were mech or hyd shafts and I decided certainty was worth the extra $30. either way , thanks again. Quote Link to comment Share on other sites More sharing options...
99custcoug Posted October 25, 2007 Report Share Posted October 25, 2007 by no means did i mean any offence to anyone by what i wrote about what one person says is easy another may say is harder or tighter everyone has there own opinion i hope no offense was taken by you quikconq i was giving a little insight on another option for chiplee in no way did i mean anything towards you or anyone else was just my 2 cents worth Quote Link to comment Share on other sites More sharing options...
12secslip Posted October 25, 2007 Report Share Posted October 25, 2007 http://www.chrisglass.com/journal/images/2004/0124_wafflehouse.jpg Quote Link to comment Share on other sites More sharing options...
