Technology Posted December 18, 2010 Author Report Share Posted December 18, 2010 I have seen flow bench testing results on DSM aftermarket intake manifolds. The best one was a one-off home built one with tapered runners and a very large plenum volume. And the 1.2:1 you mentioned is what this "street" version of the EIP cannon I have is. Link to comment Share on other sites More sharing options...
Bag-O-Chips Posted December 18, 2010 Report Share Posted December 18, 2010 just get that thing on, tune the Turd out of it ans lay down 600 whp already... is that so much to ask for!? hahahaha!!!! Just pullin your leg Andrew Link to comment Share on other sites More sharing options...
Technology Posted December 18, 2010 Author Report Share Posted December 18, 2010 I'm too busy being a jerk on this website to work on the car! Oh, I have a new picture to take and upload. brb. Link to comment Share on other sites More sharing options...
Technology Posted December 18, 2010 Author Report Share Posted December 18, 2010 (edited) http://www.starquestclub.com/forum/uploads/1292205643/med_gallery_3386_777_832152.jpg Got that done today. The rest of the fitting should hopefully be here tomorrow, and I can then finish putting the fuel pump in. The it's just wiring the pump in. I got a huge car stereo power wire to use for the pump. I will get a 30amp inline fuse for it, and I also have a relay to use from the stock fuel pump wire. It's going to be awesome. Totally useless with all the new uber high flow walbro-sized pumps coming out, but it's as much to show off as it is to make power. Edited December 18, 2010 by Technology Link to comment Share on other sites More sharing options...
Bag-O-Chips Posted December 18, 2010 Report Share Posted December 18, 2010 is that -8 or -10? Link to comment Share on other sites More sharing options...
quikconq Posted December 18, 2010 Report Share Posted December 18, 2010 (edited) i say -6-8 maybe Edited December 18, 2010 by quikconq Link to comment Share on other sites More sharing options...
Technology Posted December 18, 2010 Author Report Share Posted December 18, 2010 -8, but the line is 1/2", which is the same as -8AN. AN numbers are just 16ths of an inch. -4 is 1/4", -6 is 3/8", etc. You probably already knew that, hehe. Anyway, it's a -8 male AN flare so I can use a braided line to the fuel rail, then on the return side, it'll be a -6 to the regulator, and a hose and clamp on the low pressure return side. I'm using both stock return and feed lines as return lines. I really didn't need any of this, but now I'm way too far into it to stop. Skuzz. Link to comment Share on other sites More sharing options...
quikconq Posted December 18, 2010 Report Share Posted December 18, 2010 (edited) skuzzlol edit:::: hey tech,,,been reading thru your early on posts remember sam? mindgame backwardsi thought he was a decent guy,talked to him several times on the phone ,met him incolumbus ohio and bought some parts from him,watever happened to him???also wat management system you runnin? still the aem?you still have the 1g cas??and where did you get that cam??? Edited December 18, 2010 by quikconq Link to comment Share on other sites More sharing options...
Technology Posted December 18, 2010 Author Report Share Posted December 18, 2010 Yeah, sam vouched for me to get unbanned. I liked him and to me, his only flaw was claiming he thought of using the DSM cas before I did, haha! He and I were on the same wavelength, he was just going for more of a drag build. But you know, some people don't get along with this site, and I think it may have turned him off from SQ's. That's only a guess though. Still have the AEM, the 1G cas from a 1990 car (because the harness was a 1990 year model). I bought the cam directly from Schneider. I sent in a core and they reground it. Installing and degreeing that cam made the turbo spool about 200rpm sooner. Link to comment Share on other sites More sharing options...
quikconq Posted December 18, 2010 Report Share Posted December 18, 2010 that is a true roller cam ? am i wrong????it looks like the roller should,,long fat lobesthe roller i got from tim was to similar to a conventional cam,,they taper to a point..and was a turd of a cam Link to comment Share on other sites More sharing options...
Technology Posted December 18, 2010 Author Report Share Posted December 18, 2010 Just solid lifter, no roller. It still has a pointy end, perhaps it was just the angle you are seeing the cam from? Link to comment Share on other sites More sharing options...
quikconq Posted December 18, 2010 Report Share Posted December 18, 2010 Just solid lifter, no roller. It still has a pointy end, perhaps it was just the angle you are seeing the cam from? ahh yea possibly the angleso you decide to upgrade the rods?i thought you thinkin about it. Link to comment Share on other sites More sharing options...
Technology Posted December 18, 2010 Author Report Share Posted December 18, 2010 Not for a long time. I just want to get it running before I leave so it doesn't sit for years and rot away. I'm confident the bottom end will do 500 easy. For now, though, it's just the pump, intake manifold, idle motor and regulator. Most of which are easy to do, but still require building parts to make it work. Link to comment Share on other sites More sharing options...
quikconq Posted December 18, 2010 Report Share Posted December 18, 2010 500 at motor or wheels,,im at 357hp at wheels say close at 410 motor,,,and im still TBim gonna do more this spring with the TB and push big boost then convert mpihope you dont mind me askin question when the time comes for the switchive been talkin to scott about the megasquirt system.why did you go with aem? and not the squirt? Link to comment Share on other sites More sharing options...
Bag-O-Chips Posted December 18, 2010 Report Share Posted December 18, 2010 don't be scared to run big boost I'm gonna shoot for the 30 psi mark where the GT4088 loves it lol Link to comment Share on other sites More sharing options...
quikconq Posted December 18, 2010 Report Share Posted December 18, 2010 (edited) I'm at 30 psi on stock rodsgt35r,,,,boost away I plan too Edited December 18, 2010 by quikconq Link to comment Share on other sites More sharing options...
importwarrior Posted December 18, 2010 Report Share Posted December 18, 2010 http://www.starquestclub.com/forum/uploads/1292205643/med_gallery_3386_777_832152.jpg what is the part number for that black fuel line fittng. how does it attach tothe fuel line? Thanks Link to comment Share on other sites More sharing options...
StarquestRescue Posted December 18, 2010 Report Share Posted December 18, 2010 im at 357hp at wheels say close at 410 motor,,,and im still TBim gonna do more this spring with the TB and push big boost then convert mpi I'm at 30 psi on stock rodsgt35r,,,,boost away I plan tooQuickcong, you still using just a translator and two secondaries? What fuel pressure. My 850/1400 set up works really well but i am maxing them out with afr in the high 11's. I think i am going to run a 1050/1800 next year on e85 or maybe a stock secondary with a 1800 Bosch. I picked up another data logger box and want to add some more sensors. Link to comment Share on other sites More sharing options...
Technology Posted December 18, 2010 Author Report Share Posted December 18, 2010 (edited) what is the part number for that black fuel line fittng. how does it attach tothe fuel line? ThanksHere ya go: http://www.jegs.com/i/JEGS/555/110553/10002/-1?parentProductId=756885http://www.jegs.com/images/photos/500/555/555-110553.jpg It's a compression fitting, so the bottom part slides over the tube, then a little collar with a taper on both ends, then the AN side threads into the bottom part and squishes the collar onto the tube creating a seal. Edited December 18, 2010 by Technology Link to comment Share on other sites More sharing options...
Technology Posted December 18, 2010 Author Report Share Posted December 18, 2010 (edited) 500 at motor or wheels,,im at 357hp at wheels say close at 410 motor,,,and im still TBim gonna do more this spring with the TB and push big boost then convert mpihope you dont mind me askin question when the time comes for the switchive been talkin to scott about the megasquirt system.why did you go with aem? and not the squirt? 500 at the wheels is only 50hp away or about 3-4 more psi at the rate I was going. I hope this intake mani helps in that department. Free horsepower. But I think it's awesome you are pushing the TBI setup, and you will see gains from switching to MPI, no doubt. My turbo isn't much bigger than yours and I made 447 at 27psi, so that's the MPI in large part, I'd say. I keep forgetting to finish my posts, haha. I went with AEM because I started two other plans before and came across a better idea or a good deal. First was a megasquirt I built myself. It would have worked fine, but I wanted to use the VR distributor pickup, and forgot to install that circuit, so I eventually sold that, and read up on DJpowerhaus' 4g63 conversion and decided to adapt all the stuff to the g54b and use a stock ecu with a SAFC-2, then it changed to DSM Link. Then I came across a great deal (600 bucks off new price) AEM for the 1G DSM, and since I already was getting the harness and parts together for that, I stuck with it. And Other than using 1990 stuff, I really like it. My next engine electronics upgrade will be new, more powerful coils or some kind of amp. I have a feeling they are the reason my power is dropping off at high rpm. Edited December 18, 2010 by Technology Link to comment Share on other sites More sharing options...
quikconq Posted December 18, 2010 Report Share Posted December 18, 2010 My tune was crap,,,that's why I never submitted it to phinkoactually had skips in the line it was so choppyit was a timing/vacumn issue ,for the most part fixed by the end of summerbut then swapped to e85 and swapped in two 1600 Injectors then mywideband took a dump ,so I just called it quits for the rest of the summer. And decided to inspect/refresh the motor over the winter. Add in pauter,megasquirt I should be good for new TB numbersthen middle summer do the magna swap. Link to comment Share on other sites More sharing options...
Technology Posted December 18, 2010 Author Report Share Posted December 18, 2010 Summer was the heyday for my car. Tried to drive it as much as possible, so if there was a problem I fixed it stat. Winter here is almost impossible to even drive around normally, let alone in a powerful quest. Link to comment Share on other sites More sharing options...
quikconq Posted December 18, 2010 Report Share Posted December 18, 2010 AhhhWell in may I bought an awd eclipse projectso that kinda distacted me from the quest,,I know shame on me. But now that it's snowy I'm still boostin everyday and slidin sideways. Link to comment Share on other sites More sharing options...
Technology Posted December 31, 2010 Author Report Share Posted December 31, 2010 Got some good work done tonight. I realized I needed a nipple fitting for the brake booster, so my buddy and I drove to Ace hardware, which was closed, then to home depot, which has no selection, and then to fleet farm, which doesn't have much better selection, but had the exact thing I was looking for, a 1/8" npt to large barb fitting (the same size as the brake booster hose). So I got that done, it's under the manifold, so no pictures. I installed the manifold and started routing stuff. Reid, (afore mentioned buddy) continued to tap the fuel rail, and got it so the fittings actually go in more than 3 or 4 threads. Everything fits now, and I mocked up the intercooler pipes and thottle body, though there's nothing keeping me from bolting the TB down other than a desire to post this then sleep. So here's where it sits for tonight. http://www.starquestclub.com/forum/uploads/1293015698/gallery_3386_777_244916.jpg Next will be a couple things under the manifold on the engine, then fuel lines, install injectors, plug in sensors, and mount the regulator, then run short return lines under the hood, and tighten everything down again, and try to start. It could be done in a day, but free time is at a premium for me. Link to comment Share on other sites More sharing options...
Bag-O-Chips Posted December 31, 2010 Report Share Posted December 31, 2010 looking good!!! Link to comment Share on other sites More sharing options...
