Injectors
falcosbejo
There is nothing cheep for this car. Lets start with do you know what injectors you need? or atleast the flow rates or color of injector plastic top. Or even the exact year early late etc of your car and we can gustimate. I have one know good 850 and 2 unknow 850s ill see you all 3 for 50 bucks shipped. at worst case you will have to have one serviced and cleaned. (20-40 last I had one done depending on what it needs) and you will still come in way under new. Let me know. You could have both cleaned and done and sell the good one and recoop 40 50 bucks easy.
I too have the 83-86 black top injectors Here are the flow rates, injector numbers and year that they fit. part #......ID..From...To.....Description
MD614102 L 6/86-89 580cc, Primary, black, Driver Side of TB
MD614036 M 6/86-89 1080cc, Secondary, Green/blue, Pass
MD614114 K 2/86-5/86 850cc (2 Required)
MD614004 J 2/85-1/86 850cc (2 Required)
MD608909 H 6/83-1/85 850cc (2 Required)
MD608869 ? Thru 5/83 850cc (2 Required) Let me us know what year car you have. I have every injector but the secondary(green cap) Am trying to secure a couple in good working condition. Later,Gary
Here's the Specs..
1986 Mitsubishi Starion 2600 Esi-r (Specs.)
The motor has received a full tune up, including updated cylinder head for maximum performance & reliability. The entire motor has received new gaskets and seals. Sensors have been replaced, throttle body has been rebuilt, and the injectors have been cleaned and balanced. The factory turbo has been upgraded to a 14B hybrid turbo for more high end power. The 5-spd transmission is in great shape with no grinding. The transmission fluid has been flushed and replaced 1000 miles ago.
The exterior is original Rocky White paint. There is a minor ding on the rear driver side quarter panel, but there is no frame damage and no accidents to the car. All body panels are aligned. The car drives and brakes straight as there are no problems with the suspension, drivetrain, or engine. The interior is a dark red / burgendy color. It is very hard to find an oem widebody Starion 2600 GSR-VR car in good shape, with low miles, that even runs these days.
This Starion has a clean title.
Exterior
Original Factory Widebody
Original Factory Paint (Rocky White Color)
Interior
JDM Honda Del Sol Driver Seat
JDM Short Throw Shifter
VDO Mechanical Boost Gauge (Replacing Factory Boost Gauge On Cluster)
JDM Deep Dish Steering Wheel
HKB Steering Wheel Hub
Power Windows, Pwr Steering, Pwr door locks, Pwr side view mirror, Pwr antenna, No a/c yet!!! Not installed
Engine
86 Starion 2600 GSR-VR 2.6L Motor
89 Starion 2600 GSR-VR Updated Head (Jet Valve Eliminated)
14B Hybrid Turbo (Set at 10psi - More Boost w/FCD)
Custom 2.25" Cat-Back Free Flow Exhaust
JDM N1 Style Muffler
Stress Relieved Factory Turbo Exhaust Manifold
Mitsubishi Eclipse Factory Blow Off Valve
Mitsubishi Starion Factory Intercooler
Mitsubishi Starion Factory Oil Cooler
NGK-R Spark Plugs & Plug Wires
Accel External Coil
Recurved Distributor
Rebuilt Throttle Body
Cleaned/Balanced Factory Injectors
Custom Intake/Filter Setup
Fuel Pressure Gauge
Mechanical Boost Controller
Large Capacity Electric Fan (14" w/Thermo Switch - Runs Cool)
New Valve Cover Gaskets (Installed)
New Headgasket & New Head Bolts (Installed)
New Water Pump (Installed)
Suspension
Factory 16" Wheels w/Polished Lip
205/55/16 Dunlop Tires (Front)
245/50/16 Bridgestone Potenza Tires (Rear)
KYB Shocks (New All Around)
H&R Lowering Springs
Cusco Front Upper Strut Tower Bar
So which year car do you need the injectors for? If for the 86 you can have both for $50shipped by 2 Day Priority Mail. PayPAl is sfc711@yahoo.com Let me know,Gary
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
