falcosbejo
Everything posted by falcosbejo
Sold!!!
NO!!!! Broken tie rod, engine starts but when you hit the gas pedal the engine dies. Missing Trunk panels and carpets, needs seats
YUP!!!!!!
CONS: The car starts but when you step the gas pedal the engine dies. The Towing Company broke my tie rod....
Are you in Wise County or Fannin County? Let's Trade?
87 starion t3 upgraded in Socal 818 $1000
falcosbejo replied to putz2point6's topic in Cars for sale
What's your contact no.? -
What's your budget?
Where are you located? What's your contact no.?
The 86’s used 2 same size injectors of about 550 cc. The 87-89 used a primary of about 580 cc and a secondary of about 1000 cc. What do you think should I use? How much? Can you email me at falcosbejo@yahoo.com
Here's the Specs.. 1986 Mitsubishi Starion 2600 Esi-r (Specs.) -------------------------------------------------------------------------------- The motor has received a full tune up, including updated cylinder head for maximum performance & reliability. The entire motor has received new gaskets and seals. Sensors have been replaced, throttle body has been rebuilt, and the injectors have been cleaned and balanced. The factory turbo has been upgraded to a 14B hybrid turbo for more high end power. The 5-spd transmission is in great shape with no grinding. The transmission fluid has been flushed and replaced 1000 miles ago. The exterior is original Rocky White paint. There is a minor ding on the rear driver side quarter panel, but there is no frame damage and no accidents to the car. All body panels are aligned. The car drives and brakes straight as there are no problems with the suspension, drivetrain, or engine. The interior is a dark red / burgendy color. It is very hard to find an oem widebody Starion 2600 GSR-VR car in good shape, with low miles, that even runs these days. This Starion has a clean title. Exterior Original Factory Widebody Original Factory Paint (Rocky White Color) Interior JDM Honda Del Sol Driver Seat JDM Short Throw Shifter VDO Mechanical Boost Gauge (Replacing Factory Boost Gauge On Cluster) JDM Deep Dish Steering Wheel HKB Steering Wheel Hub Power Windows, Pwr Steering, Pwr door locks, Pwr side view mirror, Pwr antenna, No a/c yet!!! Not installed Engine 86 Starion 2600 GSR-VR 2.6L Motor 89 Starion 2600 GSR-VR Updated Head (Jet Valve Eliminated) 14B Hybrid Turbo (Set at 10psi - More Boost w/FCD) Custom 2.25" Cat-Back Free Flow Exhaust JDM N1 Style Muffler Stress Relieved Factory Turbo Exhaust Manifold Mitsubishi Eclipse Factory Blow Off Valve Mitsubishi Starion Factory Intercooler Mitsubishi Starion Factory Oil Cooler NGK-R Spark Plugs & Plug Wires Accel External Coil Recurved Distributor Rebuilt Throttle Body Cleaned/Balanced Factory Injectors Custom Intake/Filter Setup Fuel Pressure Gauge Mechanical Boost Controller Large Capacity Electric Fan (14" w/Thermo Switch - Runs Cool) New Valve Cover Gaskets (Installed) New Headgasket & New Head Bolts (Installed) New Water Pump (Installed) Suspension Factory 16" Wheels w/Polished Lip 205/55/16 Dunlop Tires (Front) 245/50/16 Bridgestone Potenza Tires (Rear) KYB Shocks (New All Around) H&R Lowering Springs Cusco Front Upper Strut Tower Bar
*88 interior and engine parts for sale* PRICES NEGOTIABLE
falcosbejo replied to 1988redstar's topic in Parts for sale
pm sent, call me asap... -
Where can I buy B-new injectors? How much? What brand? pls. email me at falcosbejo@yahoo.com, thank you.
LOTS OF AFTERMARKET STUFf & 83 hood! new lower prices!!!
falcosbejo replied to Mizzark15's topic in Parts for sale
What's your contact no.? Are you mark? -
you got mail
My bad!!!!
How much are the seats, sliders, brackets can you email me at falcosbejo@yahoo.com about the price?
ANY and ALL burgandy interior pieces... gotta go
falcosbejo replied to Lidoidol's topic in Parts for sale
Where are you located? How much is the entire interior? -
1986 Mitsubishi Starion 2600 Esi-r -------------------------------------------------------------------------------- Selling my Mitsubishi Starion 2600 GSR-VR car. Similar to the Dodge Conquest TSi. The motor has received a full tune up, including updated cylinder head for maximum performance & reliability. The entire motor has received new gaskets and seals. Sensors have been replaced, throttle body has been rebuilt, and the injectors have been cleaned and balanced. The factory turbo has been upgraded to a 14B hybrid turbo for more high end power. The 5-spd transmission is in great shape with no grinding. The transmission fluid has been flushed and replaced 1000 miles ago. The exterior is original Rocky White paint. There is a minor ding on the rear driver side quarter panel, but there is no frame damage and no accidents to the car. All body panels are aligned. The car drives and brakes straight as there are no problems with the suspension, drivetrain, or engine. The interior is a dark red / burgendy color. This Starion has a clean title. The car is currently registered in California. Located in Van Nuys. Thanks. PRICE: $2600 (firm) Exterior Original Factory Widebody Original Factory Paint (Rocky White Color) Interior JDM Honda Del Sol Driver Seat JDM Short Throw Shifter VDO Mechanical Boost Gauge (Replacing Factory Boost Gauge On Cluster) JDM Deep Dish Steering Wheel HKB Steering Wheel Hub Power Windows, Pwr Steering, Pwr door locks, Pwr side view mirror, Pwr antenna, No a/c yet!!! Not installed Engine 86 Starion 2600 GSR-VR 2.6L Motor 89 Starion 2600 GSR-VR Updated Head (Jet Valve Eliminated) 14B Hybrid Turbo (Set at 10psi - More Boost w/FCD) Custom 2.25" Cat-Back Free Flow Exhaust JDM N1 Style Muffler Stress Relieved Factory Turbo Exhaust Manifold Mitsubishi Eclipse Factory Blow Off Valve Mitsubishi Starion Factory Intercooler Mitsubishi Starion Factory Oil Cooler NGK-R Spark Plugs & Plug Wires Accel External Coil Recurved Distributor Rebuilt Throttle Body Cleaned/Balanced Factory Injectors Custom Intake/Filter Setup Fuel Pressure Gauge Mechanical Boost Controller Large Capacity Electric Fan (14" w/Thermo Switch - Runs Cool) New Valve Cover Gaskets (Installed) New Headgasket & New Head Bolts (Installed) New Water Pump (Installed) Suspension Factory 16" Wheels w/Polished Lip 205/55/16 Dunlop Tires (Front) 245/50/16 Bridgestone Potenza Tires (Rear) KYB Shocks (New All Around) H&R Lowering Springs Cusco Front Upper Strut Tower Bar
How to you swap an evolution engine?
