conquest kid Posted April 10, 2007 Report Share Posted April 10, 2007 how much boost can a stock motor handle Link to comment Share on other sites More sharing options...
Technology Posted April 10, 2007 Report Share Posted April 10, 2007 A lot. Just make sure you have a good tune, proper fuel, and you can probably run 30 psi without problems. make sure the I/C is good enough. MPI is probably the best bet for that. But this should be in Off topic or advanced vitrual mechanic. Link to comment Share on other sites More sharing options...
4bangerT Posted April 11, 2007 Report Share Posted April 11, 2007 maybe even 60psi, lol you should not need any more than 15-20 with the correct turbo. Link to comment Share on other sites More sharing options...
matt88 Posted April 11, 2007 Report Share Posted April 11, 2007 i run a T3/T4 60-1 on a stock block with 120,000 miles and stock balance shafts still!! 20 psi regular and 25psi while racing!!! of course mpi and a good tune!!! im around the 330whp range!! Link to comment Share on other sites More sharing options...
MontyTSI Posted April 11, 2007 Report Share Posted April 11, 2007 the key is not only having your car in constant good condition its also key that you have the ability to recognise a problem from the moment something is not right. I highly recommend you drive your car stock for awhile to work out any hidden gremlins that may be hiding before you up the boost and modify. good luck,Monty Link to comment Share on other sites More sharing options...
eviper21 Posted April 11, 2007 Report Share Posted April 11, 2007 there is no way id run more than 15psi on a stock quest..thats pushin it you'd need aftermarket seals and studs IMO Link to comment Share on other sites More sharing options...
xtremeboost Posted April 11, 2007 Report Share Posted April 11, 2007 how much boost can a stock motor handle Well , thats a trick question !! Its a trick question because you never said what size turbo ! It may be able to handle 25lbs off a 16G but it will only take about 18off a bigger T3T4 set-up even with a good tune !! Link to comment Share on other sites More sharing options...
Technology Posted April 11, 2007 Report Share Posted April 11, 2007 there is no way id run more than 15psi on a stock quest..thats pushin it you'd need aftermarket seals and studs IMO The solution to your problem is a gt42r. Link to comment Share on other sites More sharing options...
lionbull Posted April 11, 2007 Report Share Posted April 11, 2007 there is no way id run more than 15psi on a stock quest..thats pushin it you'd need aftermarket seals and studs IMO The solution to your problem is a gt42r. wrong the solution is MPI and run up to 30psi with good tiune and proper bolt ons Link to comment Share on other sites More sharing options...
MontyTSI Posted April 11, 2007 Report Share Posted April 11, 2007 technology was being funny, he knows a 7 to 1 TBI motor wouldnt even push a 42r to 11 psi at 6000 rpm Link to comment Share on other sites More sharing options...
4bangerT Posted April 11, 2007 Report Share Posted April 11, 2007 I have a 1.15a/r T3 housing with a 3-1/2" discharge on the exhaust, with stock compression and cam and TBI with 10psi i picked up 60 rwhp and get full boost in second gear at ~3,000rpm. The solution to make power on these motors is a way larger turbo on the exhaust side. I know they are low compression and you cant go overboard but the stock turbo design (no matter what guts it has) is pretty lack luster compared to the variety and reliability of Garrett style turbos. I highly recommend going Garrett first and foremost if everything else is running good. You will be blown away at how much power you will gain and at a respectively low amount of boost compared to what you would have to run with any Mitsubishi turbo to get the same amount of power. Link to comment Share on other sites More sharing options...
lionbull Posted April 11, 2007 Report Share Posted April 11, 2007 I have a 1.15a/r T3 housing with a 3-1/2" discharge on the exhaust, with stock compression and cam and TBI with 10psi i picked up 60 rwhp and get full boost in second gear at ~3,000rpm. The solution to make power on these motors is a way larger turbo on the exhaust side. I know they are low compression and you cant go overboard but the stock turbo design (no matter what guts it has) is pretty lack luster compared to the variety and reliability of Garrett style turbos. I highly recommend going Garrett first and foremost if everything else is running good. You will be blown away at how much power you will gain and at a respectively low amount of boost compared to what you would have to run with any Mitsubishi turbo to get the same amount of power. YES, i have been saying this for years. Stop putting baby turbos on your quests. I will be running a sc63 T4 P trim. I believe I will be the first on this board to run a t4 on a p trim at that. Link to comment Share on other sites More sharing options...
4bangerT Posted April 11, 2007 Report Share Posted April 11, 2007 Its time to do something different no MITSU TURBOS Link to comment Share on other sites More sharing options...
lionbull Posted April 11, 2007 Report Share Posted April 11, 2007 Its time to do something different no MITSU TURBOS Just a second. Is it one of those ebay garrets or a genuine one? The bigger AR ebay garrets spool fast as hell because of their small shafts unlike the "big shaft" garret which comes on later. That is why I asked which gear does it get you full boost Link to comment Share on other sites More sharing options...
4bangerT Posted April 11, 2007 Report Share Posted April 11, 2007 I have a real deal no nonsense Garrett, purchased far from the debochary of E-bay. Link to comment Share on other sites More sharing options...
MontyTSI Posted April 12, 2007 Report Share Posted April 12, 2007 I have a 1.15a/r T3 housing with a 3-1/2" discharge on the exhaust, with stock compression and cam and TBI with 10psi i picked up 60 rwhp and get full boost in second gear at ~3,000rpm. The solution to make power on these motors is a way larger turbo on the exhaust side. I know they are low compression and you cant go overboard but the stock turbo design (no matter what guts it has) is pretty lack luster compared to the variety and reliability of Garrett style turbos. I highly recommend going Garrett first and foremost if everything else is running good. You will be blown away at how much power you will gain and at a respectively low amount of boost compared to what you would have to run with any Mitsubishi turbo to get the same amount of power. YES, i have been saying this for years. Stop putting baby turbos on your quests. I will be running a sc63 T4 P trim. I believe I will be the first on this board to run a t4 on a p trim at that. which code sc63 is that.... i have larger of the 2 on the precision site. Link to comment Share on other sites More sharing options...
vmstsi Posted April 12, 2007 Report Share Posted April 12, 2007 Its time to do something different no MITSU TURBOS Just a second. Is it one of those ebay garrets or a genuine one? The bigger AR ebay garrets spool fast as hell because of their small shafts unlike the "big shaft" garret which comes on later. That is why I asked which gear does it get you full boost i have a garret gt32 i can hit full boost in first gear. my boost is set to 13psi. Link to comment Share on other sites More sharing options...
emagdnim Posted April 12, 2007 Report Share Posted April 12, 2007 Wow, big turbo guys coming out of the wood work around here finally? Holset FTMFW! Link to comment Share on other sites More sharing options...
soulja620 Posted April 12, 2007 Report Share Posted April 12, 2007 wow.. nobody mentioned this is in the wrong forum Link to comment Share on other sites More sharing options...
emagdnim Posted April 12, 2007 Report Share Posted April 12, 2007 Everyone is distracted by real turbo talk. on a turbo mitsu forum. Imagine that. It must be spring. Link to comment Share on other sites More sharing options...
quikconq Posted April 12, 2007 Report Share Posted April 12, 2007 It must be spring. i cant tell,,,around here anyhowsnow on april 10th,,,man that just suks Link to comment Share on other sites More sharing options...
Technology Posted April 12, 2007 Report Share Posted April 12, 2007 wow.. nobody mentioned this is in the wrong forum Better check yourself before you wreck yourself... lol, or check the second post. Yeaaahh! +1 fpr big garretts. Link to comment Share on other sites More sharing options...
D_Venable Posted April 12, 2007 Report Share Posted April 12, 2007 how much boost can a stock motor handle If it's just the stock turbo, the little 12A starts pushing a lot of hot air past 15psi, I don't like going above that on mine, so I'm set at about 15 on my stock setup. But this was after a few years of getting rid of small problems that arose. Fuel pump, bad gas tank, filters, bad coil, turbo rebuild, etc. Lots of little things that can arise. Drive it stock for a while, make sure the car is 100% before you mod it. Derek Link to comment Share on other sites More sharing options...
Technology Posted April 12, 2007 Report Share Posted April 12, 2007 If you can put it in 3rd gear and drive at 1000 rpm, then floor it and let off at 6000 rpm with no stuttering or hesitations, it's time to mod that bench. Link to comment Share on other sites More sharing options...
4bangerT Posted April 12, 2007 Report Share Posted April 12, 2007 Its true because i can still floor my car at 1000rpm in 4th and it will rev its way up with no nonsense. Link to comment Share on other sites More sharing options...
