artinist Posted December 1, 2005 Report Share Posted December 1, 2005 it will be interesting to see how it works. i am iffy about the injector placement. i think under boost the airflow is going to mix and mingle things in the plenum quite a bit and prevent the fuel from going into the port directly and end up having an uneven fuel mixture. #1 will most likely run quit lean and #4 the richest. Link to comment Share on other sites More sharing options...
Chad Posted December 1, 2005 Report Share Posted December 1, 2005 That is why I am using sequential injection, I'll have the injector fired in-sync with the intake valve opening. so fuel will be drawn in and mixed as the air rushes into the individual runners/cylinders only while air is drawn into that individual runner/cyl. Because I'm using such large injectors, the duty cycle (spray duration) will be vary narrow so it is unlikely to have any overlap, even at very high RMP/boost. If I were using batch fire, your assement would be correct. I'll be running 4 channel EGT's to monitor for such things too, only way to find out is to try it .... Link to comment Share on other sites More sharing options...
cyberquest Posted December 2, 2005 Report Share Posted December 2, 2005 man i want to see the dyno numbers on that puppy, looks like someone is cashing in that $500 from F.I.P. Link to comment Share on other sites More sharing options...
TopDawg_43 Posted December 3, 2005 Report Share Posted December 3, 2005 That has to be the most impressive intake that I've ever seen :shock:. Those pictures make me want to change up my whole setup. Keep up the good work Chad!!!!! Take it EZTopDawg_43~ Link to comment Share on other sites More sharing options...
ALANFROMPDX Posted December 4, 2005 Author Report Share Posted December 4, 2005 I can't wait for summer, Chad please keep us posted on PIR this summer.I think we just may be on to a good gathering this summer.We have a few cars in the making in oregon and it looks like this summer will be the summer for PIR. Link to comment Share on other sites More sharing options...
