Mike7447 Posted September 21, 2024 Report Share Posted September 21, 2024 I intend to start the engine rebuild today. I will be installing a .020 forged piston that I purchased from Dads, along with a Hastings ring set. To my knowledge, the ring set is to be installed out of the box, and not “gapped”. Can anyone confirm this for me before I get to that part? Link to comment Share on other sites More sharing options...
Dad Posted September 22, 2024 Report Share Posted September 22, 2024 21 hours ago, Mike7447 said: I intend to start the engine rebuild today. I will be installing a .020 forged piston that I purchased from Dads, along with a Hastings ring set. To my knowledge, the ring set is to be installed out of the box, and not “gapped”. Can anyone confirm this for me before I get to that part? In any build you need to check the gap, I always used factory specs on the gap just staying towards high side, sometimes you need to open it up, you will need to see. Forget checking oil rails as they are always over spec. Dad 2 Link to comment Share on other sites More sharing options...
Mike7447 Posted September 22, 2024 Author Report Share Posted September 22, 2024 11 hours ago, Dad said: In any build you need to check the gap, I always used factory specs on the gap just staying towards high side, sometimes you need to open it up, you will need to see. Forget checking oil rails as they are always over spec. Dad Thanks for that Randall. I did check the ring end gap with the rings squared, down 1” in the hole. The tops are .023-.024, and the seconds are between .021-.023 . The factory manual spec makes those end gaps loose, but obviously they are intended for a cast piston. Nonetheless, am I ok with this? As per your recommendation I had them finish the bore to 3.607. Link to comment Share on other sites More sharing options...
Dad Posted September 23, 2024 Report Share Posted September 23, 2024 Certainly won't have an issue with higher boost, it's way under the max of .031 I don't know how you squared them, iI would install a second ring on the piston and push a ring in with piston until installed ring sets on the deck, that helps square the ring you are checking in the hole. just a little off square will show a larger gap. Dad Link to comment Share on other sites More sharing options...
Mike7447 Posted September 23, 2024 Author Report Share Posted September 23, 2024 3 hours ago, Dad said: Certainly won't have an issue with higher boost, it's way under the max of .031 I don't know how you squared them, iI would install a second ring on the piston and push a ring in with piston until installed ring sets on the deck, that helps square the ring you are checking in the hole. just a little off square will show a larger gap. Dad Thanks, I’ll do that. I was pretty careful about pushing the ring in using the bottom of the oil ring land as a stop point, but it won’t hurt to try it again using the second ring as a stop point. I do intend to put some boost in the mix, ( 17-20 psi).I wouldn’t have spent the xtra money in the forged pistons otherwise. 1 Link to comment Share on other sites More sharing options...
