mbruneaux Posted September 20, 2015 Report Share Posted September 20, 2015 (edited) The current cam is junk and I have 2 other cams of unknown origin I got with the car. I've taken pictures and documented measurements to put out there in case anyone can tell me what I have. I appreciate feedback on which one I should use or neither. One camshaft I call "standard" because it has an "A" stamped on the end which tells me, from my research, that it as a hydraulic camshaft but has wear on the " fuel pump" lobe. The other is a "mystery" camshaft because the end is longer and has been ground down. All the markings are different also. The lift is higher on the mystery cam which makes me want to use it. "standard" cam Hydraulic? Stamped with an "A"Markings* G* "< 22"* 8* J* 3 "three dots in Mitsubishi diamond pattern"* "5" painted on* Wear marks on "fuel pump" lobe? Journal #1 33.90mmJournal #2 33.90mmJournal #3 33.89mmJournal #4 33.93mm Lobe #1 42.32mmLobe #2 42.33mm "Mystery" Camshaft No stamp just grind marksMarkings* C1 CWC* 2900* D1* B12 Journal #1 35.30mmJournal #2 34.55mmJournal #3 35.20mmJournal #4 35.27mm Lobe #1 42.62mmLobe #2 42.69mm http://i984.photobucket.com/albums/ae322/mbruneaux/Both%20Cam%20ends%201_zpsg5gdgrvf.jpg http://i984.photobucket.com/albums/ae322/mbruneaux/Standard%20Cam%204_zpse5yr3erv.jpg http://i984.photobucket.com/albums/ae322/mbruneaux/Standard%20Cam%203_zps3few9hqr.jpg http://i984.photobucket.com/albums/ae322/mbruneaux/Standard%20Cam%202_zpstsm0rsk9.jpg http://i984.photobucket.com/albums/ae322/mbruneaux/Standard%20Cam%201_zpse4q877fe.jpg http://i984.photobucket.com/albums/ae322/mbruneaux/Both%20Cam%20ends%202_zpsuu9ybjq6.jpg http://i984.photobucket.com/albums/ae322/mbruneaux/Mystery%20%20Cam%201_zpsp4oj26v8.jpg http://i984.photobucket.com/albums/ae322/mbruneaux/Mystery%20%20Cam%202_zpsfrz4gxyp.jpg http://i984.photobucket.com/albums/ae322/mbruneaux/Mystery%20%20Cam%203_zpsjm42khj4.jpg http://i984.photobucket.com/albums/ae322/mbruneaux/Mystery%20%20Cam%204_zps7jgyvvny.jpg Edited September 20, 2015 by mbruneaux Link to comment Share on other sites More sharing options...
860QuestTuner Posted September 21, 2015 Report Share Posted September 21, 2015 The cwc cam is an aftermarket blank. Top end and Schneider both use those blanks to cut performance cams Link to comment Share on other sites More sharing options...
860QuestTuner Posted September 21, 2015 Report Share Posted September 21, 2015 Top end usually cuts the stub off the end. Link to comment Share on other sites More sharing options...
mbruneaux Posted September 21, 2015 Author Report Share Posted September 21, 2015 Top end usually cuts the stub off the end. So, might be a Shneider? I want to go with this one. Link to comment Share on other sites More sharing options...
NotStock88 Posted September 21, 2015 Report Share Posted September 21, 2015 Your better off buying a new OEM cam off rockauto.com or amazon. Read this and the schneider cams http://www.sqperformance.com/forum/index.php?topic=245.0 Link to comment Share on other sites More sharing options...
mbruneaux Posted September 21, 2015 Author Report Share Posted September 21, 2015 (edited) Your better off buying a new OEM cam off rockauto.com or amazon. Read this and the schneider cams http://www.sqperform...php?topic=245.0 Thanks, I'd heard rumblings about them but didn't know it was so wide spread. The fact that it's a blank leads me to believe it's not a Schneider cam because they regrind factory cores, so I don't know who made it. Edited September 21, 2015 by mbruneaux Link to comment Share on other sites More sharing options...
860QuestTuner Posted September 21, 2015 Report Share Posted September 21, 2015 Schneider still sells new cams through Trilogy Turbos. I have a new 274 still in box with the cwc markings. I was told that cwc textron is the only blank manufacturer in the US. Almost every aftermarket cam the was new had seen in the past 10 years was cwc cam. Link to comment Share on other sites More sharing options...
mbruneaux Posted September 21, 2015 Author Report Share Posted September 21, 2015 Schneider still sells new cams through Trilogy Turbos. I have a new 274 still in box with the cwc markings. I was told that cwc textron is the only blank manufacturer in the US. Almost every aftermarket cam the was new had seen in the past 10 years was cwc cam. That's good to know, what does the 274 designate? Duration? Link to comment Share on other sites More sharing options...
860QuestTuner Posted September 22, 2015 Report Share Posted September 22, 2015 Yes,duration: 274 intake ,274 exhaustLift: .434 intake , .434 exhaustLobe separation: 114 Link to comment Share on other sites More sharing options...
