Trilogy injectors
Connerf5
May be the wrong spot to post this but I can't post in fuel section for some reason. I just got a set of trilogy injectors used from here actually. Wondering how I can get the adapters to fit in the throttle body. But besides that how to I get them to fit into the throttle body snug like the stock ones? The tops won't even fit into the top hat with the o-ring on.
I think the spacers were 1/4" or slightly bigger. Find something around that size like a nut for example and see if it works.
Injectors should be snug but still swivel in their housings. They should not clunk side to side. The tops use a standard domestic injector o-ring. BWD #274571 The bottom is mitsu parts you gat get from a TB rebuild kit.
