sdrt Posted July 27, 2015 Report Share Posted July 27, 2015 I had this problem when I first purchased the car and I thought it was the struts. The rear drivers side is lower then passenger side. I have the coilovers set at the same levels and there is about 3/4 of an inch difference between the two sides. I thought I have read that other people have had this problem but have not found a solution. I hope the pictures help. http://i1071.photobucket.com/albums/u517/pwrwgn77/20150726_172920_zps1anuzhza.jpghttp://i1071.photobucket.com/albums/u517/pwrwgn77/20150726_173020_zps8btojcdm.jpghttp://i1071.photobucket.com/albums/u517/pwrwgn77/20150726_173038_zpsk2b3u2bq.jpg Link to comment Share on other sites More sharing options...
speedyquest Posted July 27, 2015 Report Share Posted July 27, 2015 I don't know about your suspension sag, but you should definitely change those tires. Those suckers look olllllldddd. Link to comment Share on other sites More sharing options...
importwarrior Posted July 27, 2015 Report Share Posted July 27, 2015 has your car been hit? or have any damage? Link to comment Share on other sites More sharing options...
sdrt Posted July 27, 2015 Author Report Share Posted July 27, 2015 Those tires are just rollers. You can see the damage the car sustained herehttp://www.starquestclub.com/forum/index.php?showtopic=144703&st=0 I was talking with a guy that has 4 of these cars and he said that most all of them had the same problem but he didon't know what it was. I guess it could be a bent subframe. I'll have to pull it. Link to comment Share on other sites More sharing options...
psu_Crash Posted July 27, 2015 Report Share Posted July 27, 2015 I have exactly the same issue. 3/4" to an inch higher on the passenger side of the car both front and back with identical suspension. It took a lot of difference in the coilovers to get it to sit evenly. Although my car has a salvage title from some pretty bad front end damage back in the late 80's Link to comment Share on other sites More sharing options...
DMNDSTAR87 Posted August 2, 2015 Report Share Posted August 2, 2015 Possibly rear control arm bushings....if the bushings are toast they tend to "freeze up" in both the differential and frame crossmembers and do not allow full travel up and down of the control arm... Gig out 1 Link to comment Share on other sites More sharing options...
