Magna heads
i have one of the kidney heads.
the only problem and not really a problem is that the rear water port is the same size as the front water port for TStat.
you need to weld it shut or figure out a way to fix the difference in size.
can see it in this pic.
http://i.ebayimg.com/00/s/NjI4WDE2MDA=/z/T-AAAOSwGvhT0GiE/$_57.JPG
http://i.ebayimg.com/00/s/NzUzWDE2MDA=/z/zR8AAOSwbqpT0Gib/$_57.JPG
just a heads up
if you do get the head be sure to order a australian intake gasket for it.
our stock intake gasket does not fit this particular head.
the rear water outlet port is bigger.
  • 2 weeks later...
Can u use this on Tbi. Also thought I read these will change your compression. Will your stock cam work with this also.
Not going to work unless you can weld aluminum.
The rear water port needs to be modified. But other then that it should.
Australia only for that head and it will still leak unless you mod the back port then stock gasket will work.
See the pic I posted post #9 above.
The port is taller then our stock intake manifold.
Even with the proper gasket stock tbi manifold will not cover
That port properly.
That's why I say it needs modification.
then all you need is the magna australian gasket and good to go.
http://www.ebay.com.au/itm/NEW-INLET-MANIFOLD-GASKET-MITSUBISHI-MAGNA-TM-TN-TP-TR-TS-SIGMA-GK-GN-G54B-MOTOR-/330793156934?pt=LH_DefaultDomain_15&hash=item4d04cf0146
that should be good for the magna, i know it is in australia and they might not deliver it here but look on the EBAY.com.au site one of them will ship it for sure.
He was trying to charge me 210 American good thing I didn't buy yet shipping to Alaska is only 125 by sea. Import warrior what would it take to finish building this head parts cost wise. Also how difficult is it to find magna manifold? Any advise would be appreciated thank you.
no clue on proper magna manifold i have had mine for a long time just never installed.
if you get the wrong manifold the runners will hit the power steering gear box and or brake booster.
you need the short runner. not sure what make model.
Currency Converter
http://www.xe.com/currencyconverter/
DaD on here has all that you need to build it
www.enginemachineservice.com
AGAIN repeating myself if not using a magna intake and gasket the rear port needs to be modified for our stock TBI intakes
  • 2 weeks later...
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
