twojayzeestarion Posted June 25, 2015 Report Share Posted June 25, 2015 http://m.ebay.com.au/itm/161744056731 Have to contact seller for shipping he offer 6-10 day air mail for 200au. Ends up being 323.50$ to your door Quote Link to comment Share on other sites More sharing options...
twojayzeestarion Posted June 25, 2015 Author Report Share Posted June 25, 2015 Also he has 8 avaliable in either m8 or m9 casting Quote Link to comment Share on other sites More sharing options...
NikoFab Posted June 25, 2015 Report Share Posted June 25, 2015 Nice find Quote Link to comment Share on other sites More sharing options...
twojayzeestarion Posted June 25, 2015 Author Report Share Posted June 25, 2015 I bought me one gonna put it together with modded magna and 8:1 je pistons Quote Link to comment Share on other sites More sharing options...
importwarrior Posted June 25, 2015 Report Share Posted June 25, 2015 i have one of the kidney heads. the only problem and not really a problem is that the rear water port is the same size as the front water port for TStat. you need to weld it shut or figure out a way to fix the difference in size. can see it in this pic. http://i.ebayimg.com/00/s/NjI4WDE2MDA=/z/T-AAAOSwGvhT0GiE/$_57.JPG http://i.ebayimg.com/00/s/NzUzWDE2MDA=/z/zR8AAOSwbqpT0Gib/$_57.JPG Quote Link to comment Share on other sites More sharing options...
89StarQuestNYC Posted June 25, 2015 Report Share Posted June 25, 2015 What's the difference between m8 & m9 heads?Also any benefit over NJV Heads? Thx Quote Link to comment Share on other sites More sharing options...
twojayzeestarion Posted June 25, 2015 Author Report Share Posted June 25, 2015 My magna still has large port so it won't be an issue Quote Link to comment Share on other sites More sharing options...
twojayzeestarion Posted June 25, 2015 Author Report Share Posted June 25, 2015 They flow much much more than any non ported m28 Quote Link to comment Share on other sites More sharing options...
importwarrior Posted June 25, 2015 Report Share Posted June 25, 2015 just a heads up if you do get the head be sure to order a australian intake gasket for it.our stock intake gasket does not fit this particular head. the rear water outlet port is bigger. http://i.ebayimg.com/00/s/NjI4WDE2MDA=/z/T-AAAOSwGvhT0GiE/$_57.JPG Quote Link to comment Share on other sites More sharing options...
Infamous907 Posted July 7, 2015 Report Share Posted July 7, 2015 Can u use this on Tbi. Also thought I read these will change your compression. Will your stock cam work with this also. Quote Link to comment Share on other sites More sharing options...
STARION_NORTH Posted July 7, 2015 Report Share Posted July 7, 2015 Just scored one! Thanks for posting the link, I have been looking for one of these for a while now. Quote Link to comment Share on other sites More sharing options...
importwarrior Posted July 8, 2015 Report Share Posted July 8, 2015 Can u use this on Tbi. Also thought I read these will change your compression. Will your stock cam work with this also. Not going to work unless you can weld aluminum. The rear water port needs to be modified. But other then that it should. Quote Link to comment Share on other sites More sharing options...
88351wtsi Posted July 8, 2015 Report Share Posted July 8, 2015 Ok I have one on the way but where can I get the gaskets? Quote Link to comment Share on other sites More sharing options...
importwarrior Posted July 8, 2015 Report Share Posted July 8, 2015 Australia only for that head and it will still leak unless you mod the back port then stock gasket will work. See the pic I posted post #9 above. The port is taller then our stock intake manifold. Even with the proper gasket stock tbi manifold will not cover That port properly. That's why I say it needs modification. Quote Link to comment Share on other sites More sharing options...
88351wtsi Posted July 8, 2015 Report Share Posted July 8, 2015 Got a magna mpi on the way though Quote Link to comment Share on other sites More sharing options...
importwarrior Posted July 8, 2015 Report Share Posted July 8, 2015 then all you need is the magna australian gasket and good to go. http://www.ebay.com.au/itm/NEW-INLET-MANIFOLD-GASKET-MITSUBISHI-MAGNA-TM-TN-TP-TR-TS-SIGMA-GK-GN-G54B-MOTOR-/330793156934?pt=LH_DefaultDomain_15&hash=item4d04cf0146 that should be good for the magna, i know it is in australia and they might not deliver it here but look on the EBAY.com.au site one of them will ship it for sure. Quote Link to comment Share on other sites More sharing options...
importwarrior Posted July 8, 2015 Report Share Posted July 8, 2015 new link http://www.ebay.com.au/itm/Mitsubishi-TS-Magna-4G54-2-6L-Fully-Remanufactured-Cylinder-Head-/151739152999?pt=LH_DefaultDomain_15&hash=item23545bba67 $220 Au = $163.112 American Quote Link to comment Share on other sites More sharing options...
Infamous907 Posted July 8, 2015 Report Share Posted July 8, 2015 He was trying to charge me 210 American good thing I didn't buy yet shipping to Alaska is only 125 by sea. Import warrior what would it take to finish building this head parts cost wise. Also how difficult is it to find magna manifold? Any advise would be appreciated thank you. Quote Link to comment Share on other sites More sharing options...
importwarrior Posted July 8, 2015 Report Share Posted July 8, 2015 no clue on proper magna manifold i have had mine for a long time just never installed.if you get the wrong manifold the runners will hit the power steering gear box and or brake booster.you need the short runner. not sure what make model. Currency Converterhttp://www.xe.com/currencyconverter/ DaD on here has all that you need to build itwww.enginemachineservice.com AGAIN repeating myself if not using a magna intake and gasket the rear port needs to be modified for our stock TBI intakes Quote Link to comment Share on other sites More sharing options...
NotStock88 Posted July 19, 2015 Report Share Posted July 19, 2015 My question is about the valves. Because it was on a non-turbo engine, will the exhaust valves need swapped out for turbo valves? Quote Link to comment Share on other sites More sharing options...
importwarrior Posted July 20, 2015 Report Share Posted July 20, 2015 That's what I did. Quote Link to comment Share on other sites More sharing options...
