questsale Posted September 23, 2014 Report Share Posted September 23, 2014 Noticed that when I pull back the hi beam lever, my lights dont open, and no hi beams come on. Works fine when the headlights are already on. didnt test with headlights up, but off. I saw no burned fuse for popups, or anything else. What should I look for? Link to comment Share on other sites More sharing options...
JohnnyWadd Posted September 23, 2014 Report Share Posted September 23, 2014 It has its own relay. Check for it operating. If not operating then check switch and power and ground. If the relay is operating check the circuit past the relay , wires and pop up motors Link to comment Share on other sites More sharing options...
questsale Posted September 24, 2014 Author Report Share Posted September 24, 2014 I want to add that hi beams only work when the headlights are on. they wont work with them popped up. Where is this realy? by they battery? Link to comment Share on other sites More sharing options...
FRO Posted September 24, 2014 Report Share Posted September 24, 2014 Under the dash,, called the passing relay Link to comment Share on other sites More sharing options...
questsale Posted September 26, 2014 Author Report Share Posted September 26, 2014 Issue seems to have resolved itself. oh wells. Link to comment Share on other sites More sharing options...
JAinsworth Posted September 27, 2014 Report Share Posted September 27, 2014 Your flash to pass relay is located under the hood, driver's side firewall.Jimmy Link to comment Share on other sites More sharing options...
The Rabbit1 Posted October 8, 2014 Report Share Posted October 8, 2014 would it do this with car turned off? Link to comment Share on other sites More sharing options...
JAinsworth Posted October 8, 2014 Report Share Posted October 8, 2014 would it do this with car turned off? I don't think so. How fast are you going with the key off Jimmy Link to comment Share on other sites More sharing options...
Nightcall Posted October 8, 2014 Report Share Posted October 8, 2014 I want to add that hi beams only work when the headlights are on. they wont work with them popped up. Where is this realy? by they battery?im curious. Yeah i thought this^ Link to comment Share on other sites More sharing options...
The Rabbit1 Posted October 11, 2014 Report Share Posted October 11, 2014 I ask because I had my car off when I first got it and I remember the headlights had me about to tear the electrical apart till I happened to turn the key and they cycled.. I believe if the key is off the pass lever motion won't actuate the relay giving the idea that they are broke.. amiright? car is tore apart otherwise I would just test it out.. Link to comment Share on other sites More sharing options...
