drronn@hotmail.com Posted August 22, 2014 Report Share Posted August 22, 2014 So I replaced everything in the front end of my 86, tie rods, ball joints, pit man arm, sway bar, struts and strut plates and the f'n thing still sounds like the front wheels are or engine is going to fall out.. It clanks and clatters like crazy...Horribly annoying and no f'n mechanic around here can seem to figure it out what the hell it is...So any information or suggestions would be grateful before I drive it into a wall.. Are there any full schematics / diagrams of the struts and all components anywhere??? THanks in advance Ronn7209899377drronn@hotmail.com Link to comment Share on other sites More sharing options...
chassispuke Posted August 22, 2014 Report Share Posted August 22, 2014 u might have installed the wrong struts in the front there are two different sizes. one for narrow body and for wide body. i believe the narrow body cars have shorter length struts. i might be wrong though. Link to comment Share on other sites More sharing options...
ucw458 Posted August 23, 2014 Report Share Posted August 23, 2014 Make sure the wheel bearings are tight. Also make sure the nut at the top of the strut housing is as tight as you can make it. If the nuts are slightly loose the strut will move inside the housing making a clunking noise. Link to comment Share on other sites More sharing options...
mrvwbug Posted August 23, 2014 Report Share Posted August 23, 2014 X2 - Again does anyone have SCHEMATICS? I have a similar problem. Also are you suppose to grease the tops of them? I have the KYB G-2's so I was told you should not need to do this. I will try to tighten them some more but need to known about the grease question? Please advise,, Thx, SLim Jim Link to comment Share on other sites More sharing options...
mr-starion Posted August 23, 2014 Report Share Posted August 23, 2014 When my jam nuts on the strut housings were loose i had all the clinks and clanks, actually ended up scoring the struts and making them leak. Had to replace them since i was easily bottoming out and when i put new ones i put loctite on the jam nuts. This will show you everything ,http://www.starquestgarage.com/manuals/service/conquest/1988/88_conquest_service_manual_-_group_02_-_front_suspension.pdf Link to comment Share on other sites More sharing options...
markhansenconquest Posted August 27, 2014 Report Share Posted August 27, 2014 the grease is so it don't rust.................. Link to comment Share on other sites More sharing options...
