BoostedBimmer Posted May 14, 2014 Report Share Posted May 14, 2014 Ok, im replacing my rear calipers, and that 10 x 22 mm clevis pin is frozen onto the end of the parking brake cable! I removed the cotter pin (obviously), and tried to even hammer that pin down (using a heavy duty screwdriver to get leverage), with no luck. Its rusted frozen to the end of the cable. I was thinking of resorting to the use of my dremel to cut the head off of the clevis pin to remove it, but I cant seem to find the same replacement clevis pin. What to do?? Link to comment Share on other sites More sharing options...
questsale Posted May 14, 2014 Report Share Posted May 14, 2014 Spray it with PBBlaster and use channel locks to squeeze it out.Apply Copper anti sieze to every bolt you put back in place Link to comment Share on other sites More sharing options...
vbrad511 Posted May 14, 2014 Report Share Posted May 14, 2014 Smoke wrench. Link to comment Share on other sites More sharing options...
Turbo Cary Posted May 15, 2014 Report Share Posted May 15, 2014 I would try Freeze All. Its like PB Blaster but I think it worked better when I tried it. Link to comment Share on other sites More sharing options...
markhansenconquest Posted May 15, 2014 Report Share Posted May 15, 2014 soak it in toilet boil cleaner all day...acid will eat rust.. Link to comment Share on other sites More sharing options...
