ultraflexxj Posted June 25, 2013 Report Share Posted June 25, 2013 tonight the rubber ring around the intake some how ended up going through the intake of my turbo destroying my 18g fp turbo. im starting think i wasn't ment to have a starquest first my engine took a s*** with the je pistons now my turbo took a s*** whats worse is i dont have the money to fix it and its my dd Link to comment Share on other sites More sharing options...
ultraflexxj Posted June 25, 2013 Author Report Share Posted June 25, 2013 has anyone on the form run a holset hx40w Link to comment Share on other sites More sharing options...
Dred_85.5_TSI Posted June 25, 2013 Report Share Posted June 25, 2013 talk to starquestJOE on here I believe he has a HX40w. I am running a HX35w. Link to comment Share on other sites More sharing options...
Fuze Posted June 25, 2013 Report Share Posted June 25, 2013 If you need the 18G rebuilt, it's about $200-$250. Mike Turbo Link to comment Share on other sites More sharing options...
ultraflexxj Posted June 25, 2013 Author Report Share Posted June 25, 2013 i called mike turbo they said 375+ Link to comment Share on other sites More sharing options...
ultraflexxj Posted June 26, 2013 Author Report Share Posted June 26, 2013 i found an off brand hx35 for sale locally for cheap and get an adapter Link to comment Share on other sites More sharing options...
Technology Posted June 26, 2013 Report Share Posted June 26, 2013 Just get a 12a if it's a daily driver. Link to comment Share on other sites More sharing options...
ultraflexxj Posted June 27, 2013 Author Report Share Posted June 27, 2013 (edited) Dred can I see some pics of your set up I just got an hx35w Edited June 27, 2013 by ultraflexxj Link to comment Share on other sites More sharing options...
Dred_85.5_TSI Posted June 27, 2013 Report Share Posted June 27, 2013 http://i632.photobucket.com/albums/uu41/Dred_85-5_tsi/84%20Starion%20ES%20project/DSC01278.jpghttp://i632.photobucket.com/albums/uu41/Dred_85-5_tsi/84%20Starion%20ES%20project/DSC01279.jpghttp://i632.photobucket.com/albums/uu41/Dred_85-5_tsi/84%20Starion%20ES%20project/DSC01276.jpg Link to comment Share on other sites More sharing options...
ultraflexxj Posted June 27, 2013 Author Report Share Posted June 27, 2013 How well does it spool Link to comment Share on other sites More sharing options...
Dred_85.5_TSI Posted June 27, 2013 Report Share Posted June 27, 2013 any gear above first it spools 15psi by ~3200 rpm. Thats with the bullseye .70 A/R T3 housing. Link to comment Share on other sites More sharing options...
spadey Posted June 28, 2013 Report Share Posted June 28, 2013 I wouldn't put your money on an off brand hx35 read on diesel forums about them. By a real one. You can em for between 200-300. Plus your gonna need an adaptor external wastgate if you don't have one plus making the oil lines. You could spend easy over $375 with making it work. Link to comment Share on other sites More sharing options...
ultraflexxj Posted June 28, 2013 Author Report Share Posted June 28, 2013 i ended up getting a gated hx35w Link to comment Share on other sites More sharing options...
ultraflexxj Posted June 28, 2013 Author Report Share Posted June 28, 2013 dred are you running an oil ristictor Link to comment Share on other sites More sharing options...
Technology Posted June 28, 2013 Report Share Posted June 28, 2013 He is. If it's standard bearing, you shouldn't have to run a restricter. Link to comment Share on other sites More sharing options...
Dred_85.5_TSI Posted June 28, 2013 Report Share Posted June 28, 2013 (edited) I made a Nitrous Jet oil restrictor. It is common on DSM cars that run a Holset. Plus I built a -6AN oil feed line so a restrictor was kind of needed. Don't use a -6AN line. -3 or-4 is more than enough.http://i632.photobucket.com/albums/uu41/Dred_85-5_tsi/84%20Starion%20ES%20project/DSC01272.jpg http://i632.photobucket.com/albums/uu41/Dred_85-5_tsi/84%20Starion%20ES%20project/DSC01273.jpg Edited June 28, 2013 by Dred_85.5_TSI Link to comment Share on other sites More sharing options...
