steering center link..some damage
03CL55AMG
I pulled the steering gearbox off to rebuild it while my engine is out and I damaged the rubber boot that the pitman arm attaches to on the center link...is this a bad problem or is this a sealed unit and that is a dust cover..any thoughts ? Edited by 03CL55AMG
The rubber boot only protects the joint from dust and dirt as there is no Zerk fitting to re-grease it. You can replace the dust boot by removing the nut and Idler arm from the Center link to install a new one. (Torque the nut to 33 ft.lbs.)
Part no. MB076000 Dust Cover. Appox. $8.16 from your online Mitsubishi Dealer.
Bill
Edited by Caliber308
You can drill for a zerk fitting on the center link and save it, the left side rotates, the right side is a ball. You will drill some into the cylinder that is what rotates in the pocket on the left side so you can get a fitting installed as the center link is pretty thin but at least now you can grease it and it should have been done that way when it was new but they were too cheap to do it. It will make the steering easier too btw, those two old pivot points are dried up.
