1986ro4starion Posted November 6, 2011 Report Share Posted November 6, 2011 (edited) were do i start on this?, i was thinking maybe the coil being hooked up wrong? everything else turns off... i havent let it keep running long enough to see if the fuel pump turns off when turning key off dont really want to run it out of gas or start it up again knowing i cant turn it off haha thanks Edited November 6, 2011 by 1986ro4starion Link to comment Share on other sites More sharing options...
Spooled_Starion Posted November 6, 2011 Report Share Posted November 6, 2011 Does it shut off after about a minute or so? Maybe you have a turbo timer? Link to comment Share on other sites More sharing options...
Indiana Posted November 6, 2011 Report Share Posted November 6, 2011 That happened to someone a few week ago after a battery or cables were hooked up backwards but what happened was it melted the ignition switch. You can get a new one they are inexpensive, look at rockauto.com They are fastened to the underside of the locking mechanism, just remove the plastic and you'll see it. If you unplug the switch and it shuts off then the switch is bad. The pigtail from it runs down the column. http://www.b2600turbo.com/images/IM006067.JPG Link to comment Share on other sites More sharing options...
Dred_85.5_TSI Posted November 6, 2011 Report Share Posted November 6, 2011 I shorted a wrench on the body of the car when I was connecting the battery. spark, pop, and it did the same thing yours is doing. Link to comment Share on other sites More sharing options...
1986ro4starion Posted November 7, 2011 Author Report Share Posted November 7, 2011 it dosnt drain the battery at all, could i possply use this defect as a turbo timer jus let it run out of gas after i turn the key off? that would be cool haha Link to comment Share on other sites More sharing options...
1986ro4starion Posted November 9, 2011 Author Report Share Posted November 9, 2011 That happened to someone a few week ago after a battery or cables were hooked up backwards but what happened was it melted the ignition switch. You can get a new one they are inexpensive, look at rockauto.com They are fastened to the underside of the locking mechanism, just remove the plastic and you'll see it. If you unplug the switch and it shuts off then the switch is bad. The pigtail from it runs down the column. http://www.b2600turbo.com/images/IM006067.JPGi tried to unplug it while it was running and it kept running!!! so whats this mean that the switch is good? where should i go from here? Link to comment Share on other sites More sharing options...
Shelby Posted November 9, 2011 Report Share Posted November 9, 2011 connect a test lamp to the coil posi terminal and look for a power scourse to it with ign key off , remember the ign coil has nothing to do with the ecu or main relay but any non factory add on's can cause a power run on , any add'd power feed after the ign swt to say the radio, or heater fans or amp would keep the ign alive with no key on Link to comment Share on other sites More sharing options...
