bigjoe Posted October 10, 2011 Report Share Posted October 10, 2011 i see people take off this factory oil catch can n put a litle filter on top o the valve cover .. if u put onw of hose on what can u do with the catch can n the line or tubes? Link to comment Share on other sites More sharing options...
19cturbo Posted October 10, 2011 Report Share Posted October 10, 2011 leave the catch can there. if you remove it and put a filter back there, you will have oil residue everywhere.. Link to comment Share on other sites More sharing options...
Indiana Posted October 10, 2011 Report Share Posted October 10, 2011 Soak it in solvent, Rinse it in solvent. Let it dry and make sure you can easily blow through it. The hoses can't be kinked or mashed. Pull the dipstick tube tube out and seal it to the stub tube where it inserts into the oil pan. There's a small oring there but it doesn't get the job done and the system has to be 100% sealed or it will not work. You also must only use an OEM PCV valve. NO AFTERMARKET PCV VALVES. Link to comment Share on other sites More sharing options...
Wally Walt Posted October 19, 2011 Report Share Posted October 19, 2011 Ok i have mine and it has three arms or tubes coming off it one go to the oil pan the bottom tube the side one goes to the valve cover and the top one goes were? And if it to the stock air cleaner what do i do if i no longer have that? Also were does it bolt to be cause i cant find anywhere to place it Link to comment Share on other sites More sharing options...
Indiana Posted October 19, 2011 Report Share Posted October 19, 2011 (edited) It goes in the connection from the air filter to the compressor outlet. Edited October 19, 2011 by Indiana Link to comment Share on other sites More sharing options...
bigjoe Posted October 20, 2011 Author Report Share Posted October 20, 2011 what happened if i wana put a after market catch can ? Link to comment Share on other sites More sharing options...
Indiana Posted October 20, 2011 Report Share Posted October 20, 2011 If you do not have a connection back to that tube you will still vent out the crankcase pressure but it first has to build up before it can blow out. Link to comment Share on other sites More sharing options...
Technology Posted October 24, 2011 Report Share Posted October 24, 2011 It builds up pressure if the engine is running. You may remove or leave the stock one, and use the new catch can in addition to the stock one. Link to comment Share on other sites More sharing options...
