drummer030201 Posted January 5, 2011 Report Share Posted January 5, 2011 this happened today. was drivin home from flight and decided to give ol' rosie some gusto. all went just fine until i just kicked the clutch in to bring her down a lil. rpms dropped fine, but boost on stock gauge indicated below zero but stayed at the solid orange line, and the car shut off. i have no idea what it is. car specs 87 124XXX mileshard pipes SSQV bov88/89 ecumbc 10 lbsstock 12a thanks in advance guys and gals ~Muzzy Link to comment Share on other sites More sharing options...
Caliber308 Posted January 5, 2011 Report Share Posted January 5, 2011 Just Curious. When is the last time you or someone else did a ISC/TPS Reset. Sometimes if the ISC is out of adjustment, when you decelerate too fast and push in the clutch or come to a abrupt stop, the car will die. Bill Link to comment Share on other sites More sharing options...
Indiana Posted January 5, 2011 Report Share Posted January 5, 2011 When using a BOV and a MAF that can happen. The idle motor can't react quick enough and even then it has to be properly adjusted and working. Link to comment Share on other sites More sharing options...
kyle's89quest Posted January 5, 2011 Report Share Posted January 5, 2011 my car just about shuts off when i let off hard... going to do a tps/isc reset soon Link to comment Share on other sites More sharing options...
drummer030201 Posted January 6, 2011 Author Report Share Posted January 6, 2011 Just Curious. When is the last time you or someone else did a ISC/TPS Reset. Sometimes if the ISC is out of adjustment, when you decelerate too fast and push in the clutch or come to a abrupt stop, the car will die. Bill Well Bill i have never done it and im quite positive the previous owner never did it. are they difficult to do? When using a BOV and a MAF that can happen. The idle motor can't react quick enough and even then it has to be properly adjusted and working. well i know it works, some what, because all other times the car runs perfect. Just when i give it the goods and let off hard is when it dies. Thanks for your help guys, its much appreciated ~Muzzy Link to comment Share on other sites More sharing options...
strang3majik Posted January 6, 2011 Report Share Posted January 6, 2011 yeah, if you have a lightened flywheel and a BOV...they can stall out when you're on them hard then let off. Its the momentary rich condition from ventilating all the metered air that does it. So, if you have a BOV, try removing it and see if it still does it. Link to comment Share on other sites More sharing options...
drummer030201 Posted January 6, 2011 Author Report Share Posted January 6, 2011 yeah, if you have a lightened flywheel and a BOV...they can stall out when you're on them hard then let off. Its the momentary rich condition from ventilating all the metered air that does it. So, if you have a BOV, try removing it and see if it still does it. never did it before until just recently Link to comment Share on other sites More sharing options...
