importwarrior Posted November 24, 2010 Report Share Posted November 24, 2010 well it idles perfectly no hiccup at all smooth as can be. just perfect.Then i plug in the MAS sensor and it breaks up stutters just about stalls.i have to see if i can find one to try. im sure it is either bad or needs to be cleaned again.I might just try out my megasquirt this weekend and toss the stock setup. Link to comment Share on other sites More sharing options...
Funsockstv Posted November 24, 2010 Report Share Posted November 24, 2010 You have a bad sensor in your mass get a new working one. i had the same problem and i just replaced it with a used stock one that i bought off this site. Link to comment Share on other sites More sharing options...
Edde Posted November 24, 2010 Report Share Posted November 24, 2010 If you're adventurous, and I think you are, you can test the functions per FSM. Or you can swap one even more easily. Of course I don't know why it would idle well without one - assuming it's a post 86. Link to comment Share on other sites More sharing options...
franky weldon Posted November 24, 2010 Report Share Posted November 24, 2010 my car did the sam but the pipe running frim the itake manifold and to the intercooler was getting pushed over by my aftermarket intake and caused the cupplings right after my MAFS to get pinched and it idled like s*** so i zippy tied it to a old bracket Link to comment Share on other sites More sharing options...
Caliber308 Posted November 24, 2010 Report Share Posted November 24, 2010 well it idles perfectly no hiccup at all smooth as can be. just perfect.Then i plug in the MAS sensor and it breaks up stutters just about stalls.i have to see if i can find one to try. im sure it is either bad or needs to be cleaned again.I might just try out my megasquirt this weekend and toss the stock setup. Try testing the error codes with a analog voltmeter. If code three comes up (Air Flow Sensor) that might be your problem. Testing: FSM volume no. 1. pages 14-21,22,61 and 62. Self-Diagnosis. Bill Link to comment Share on other sites More sharing options...
Indiana Posted November 24, 2010 Report Share Posted November 24, 2010 Had that issue with one that stopped by here. He had those replacement injectors and they were both leaking. When the MAF wasn't plugged in you could get it to run but it wouldn't make boost and at idle with it plugged in it would just load up, foul the plugs and die just as you are describing. I swapped in a cleaned set of stock injectors and it ran just fine. There wasn't a MAF issue at all but that is the same situation that can happen that will throw that stupid MAF "code" and its not the MAF its something else. It threw the code when the engine DIED. http://www.b2600turbo.com/images/errorcodes1.jpg Link to comment Share on other sites More sharing options...
importwarrior Posted November 24, 2010 Author Report Share Posted November 24, 2010 thanks guys. i do not think it is the injectors. the car runs great. just will not hold an idle and stumbles when cruising. accells real nice. Link to comment Share on other sites More sharing options...
importwarrior Posted November 25, 2010 Author Report Share Posted November 25, 2010 Thanks Coke AKA Justin for the maf sensor. it did the trick!runs like a new car. Thanks for all your help. now to fix the seat belt track. if it isnt one thing after another. Link to comment Share on other sites More sharing options...
Edde Posted November 25, 2010 Report Share Posted November 25, 2010 The seatbelt drive thing is not really a tough job. Just pay attention to the way it comes out. Link to comment Share on other sites More sharing options...
