FLATBROKE313 Posted August 23, 2010 Report Share Posted August 23, 2010 K so car runs but wont stay running unless i keep taping the gas pedal everything else is great so starting to lean towards fuel pressure regulator it cam on the magna fuel rail.Any way to test it or just put in afpr also what fits in stock location thanks. Link to comment Share on other sites More sharing options...
pagemo Posted August 24, 2010 Report Share Posted August 24, 2010 Have you tried setting the idle up? at what rpm does it start to stumble and stall? Does the car drive and pull under load ok? What is the AFR right before it dies? Link to comment Share on other sites More sharing options...
jszucs Posted August 24, 2010 Report Share Posted August 24, 2010 and to address your testing question do you have a fuel presure gage? If you want to test if it raises IE 1 to 1 use your compreser and blow air into the vac hose (not alot) use like 2 3 pounds and see if your fpg goes up. Link to comment Share on other sites More sharing options...
