Fome Posted February 6, 2010 Report Share Posted February 6, 2010 i couldnt turn up the boost last year on the starion due to my Walbro 255 not being able to keep up after i made the switch to E-85 so im revamping the entire fuel system Started out with a new Aeromotive A-1000 fuel pump and a new spin on napa fuel filterthen i was thinking whats the point in adding a massive fuel pump and filter and then trying to suck the fuel to it through a 3/8" line in the tank so a little fabrication was in order http://i625.photobucket.com/albums/tt331/fomes9282/DSC00592.jpg then i removed the stock pickup in the tank and welded the new one in its placehttp://i625.photobucket.com/albums/tt331/fomes9282/DSC00593.jpg and here is a compairison of the stuck vs newhttp://i625.photobucket.com/albums/tt331/fomes9282/DSC00594.jpg i know i need to trim it more but this is just a start and there is alot more work to be done on it ill try to keep it updatedbtw i have alot to do under the hood toohttp://i625.photobucket.com/albums/tt331/fomes9282/DSC00595.jpg Link to comment Share on other sites More sharing options...
jwbrocloud Posted February 6, 2010 Report Share Posted February 6, 2010 Nice . . . glad to see you steady improving your 4g swap. I hope when mine is finish it will be half of what you've got there. Link to comment Share on other sites More sharing options...
smallblock12 Posted February 6, 2010 Report Share Posted February 6, 2010 dude you are gonna have one insane setup Link to comment Share on other sites More sharing options...
Fome Posted February 8, 2010 Author Report Share Posted February 8, 2010 well i didnt get as much time to work on it as i had hoped to this weekend but i made 1 more step had to fab up a mount for my spin on fuel filter housing and ran the line to that http://i625.photobucket.com/albums/tt331/fomes9282/DSC00596.jpgi was planning on using 3/4" fuel line for it but the largest napa had was 5/8 so i gonna call around Wed and see if i can find some locallyhttp://i625.photobucket.com/albums/tt331/fomes9282/DSC00597.jpg Link to comment Share on other sites More sharing options...
mgrissom Posted February 8, 2010 Report Share Posted February 8, 2010 Looking really good. Link to comment Share on other sites More sharing options...
Fome Posted February 12, 2010 Author Report Share Posted February 12, 2010 well ive been a little busy the last 2 day since i was off work and i really need to tanks Bryen (quikconq) for most of it todayi ask about every part im buying about compatibility with ethanol and everything is sposta workim planning on a FIC rail -8 in -6 out and FIC 1600's and my goal is to lay down 600 ponies to the tires mounted the fuel pumphttp://i625.photobucket.com/albums/tt331/fomes9282/DSC00600.jpg got the tank and the filter were i wanted it (had to trim 1" off my bracket)http://i625.photobucket.com/albums/tt331/fomes9282/DSC00603.jpgthen ran the -8 from the fuel pump up to the front of the car (no pic just pretend you see a braided line under a oily undercarriage) then we worked on cleaning up the plumbing under the hoodhere is a beforehttp://i625.photobucket.com/albums/tt331/fomes9282/DSC00595.jpg we decided on killing the DSM waterpump setup that was on the car and going with a mighty max pump but i will have to run v-belts instead of a multi-ribhttp://i625.photobucket.com/albums/tt331/fomes9282/DSC00601.jpgand this is why went went with this we got to go from a large diameter dsm pipe on the side of the blockhttp://i625.photobucket.com/albums/tt331/fomes9282/DSC00605.jpgto this and the small nipple that needs to be brazed on pipe yet will be the return for the water to turbohttp://i625.photobucket.com/albums/tt331/fomes9282/DSC00606.jpg then i pulled the tranny out so i can put the alumnium flywheel inhttp://i625.photobucket.com/albums/tt331/fomes9282/DSC00602.jpg Link to comment Share on other sites More sharing options...
quikconq Posted February 12, 2010 Report Share Posted February 12, 2010 got the tranny down??sweeta fairly productive afternnon Link to comment Share on other sites More sharing options...
smallblock12 Posted February 20, 2010 Report Share Posted February 20, 2010 need more updates. i will be starting mine sometime soon. im supposed to be getting a car Link to comment Share on other sites More sharing options...
Fome Posted February 20, 2010 Author Report Share Posted February 20, 2010 ok i havent been sluffung off on my progect just been too busy to post updates i decided to go with a mighty max water pump as stated earlier but that took some modification to clear the duel cam tentioner braketi had to counter sink the bolt hole here and grind it down a little (dont worrie i allready cleaned it up before i put the belt on)http://i625.photobucket.com/albums/tt331/fomes9282/DSC00607-1.jpghttp://i625.photobucket.com/albums/tt331/fomes9282/DSC00609-1.jpg then i put the belt on and degreeed the cams and that took just about all day yesterday http://i625.photobucket.com/albums/tt331/fomes9282/DSC00614.jpgand a good use for you old steel flywheels (it worked)http://i625.photobucket.com/albums/tt331/fomes9282/DSC00613.jpg here is the final resaults for were they ended up can hardly tell but you seehttp://i625.photobucket.com/albums/tt331/fomes9282/DSC00616.jpghttp://i625.photobucket.com/albums/tt331/fomes9282/DSC00617.jpg i also decided another thing that bothered me was the way they ran the power steering line so might as well since im down to thatits the blue hose in this picturehttp://i625.photobucket.com/albums/tt331/fomes9282/DSC00618.jpghere is the after and you can also see the black cloth braided line that is running from the prethermostat side of the wateroutlet and the nipple on that steel pipe there will be the turbo return. when they did the build they didnt run any water to the turbohttp://i625.photobucket.com/albums/tt331/fomes9282/DSC00619.jpghttp://i625.photobucket.com/albums/tt331/fomes9282/DSC00620.jpg Link to comment Share on other sites More sharing options...
smallblock12 Posted February 20, 2010 Report Share Posted February 20, 2010 nice! im likin it! Link to comment Share on other sites More sharing options...
slowquest Posted February 21, 2010 Report Share Posted February 21, 2010 i decided to go with a mighty max water pump as stated earlier but that took some modification to clear the duel cam tentioner braketi had to counter sink the bolt hole here and grind it down a little (dont worrie i allready cleaned it up before i put the belt on) http://i625.photobucket.com/albums/tt331/fomes9282/DSC00609-1.jpg then i put the belt on and degreeed the cams and that took just about all day yesterday http://i625.photobucket.com/albums/tt331/fomes9282/DSC00614.jpg I don't remember having any trouble with clearance on that bolt on mine. I used new mitsu bolts on the waterpump instead of allen heads, but I can't see that being much of a difference. I did have to grind down that rib and actually some of the "turbine" of the pump for clearance on the tensioner pulley. And if you don't mind my asking, what did you degree the cams to? If I remember correctly, you have the 292's right? Link to comment Share on other sites More sharing options...
Fome Posted February 22, 2010 Author Report Share Posted February 22, 2010 if you use a eclipse water pump you dont need to clearance it but with the MM pump i had to the cams are HKS 272'si set the cams to this but i do plan to do some testing on the dyno to see what gives me the best power272 IntakeMax Valve Lift - 10.3mm (0.4055")Centerline at 0mm vavle lift 105 degIntake Valve timing at 1mm (0.0394")Valve opens at 4 deg BTDCValve closes at 30 deg ABDCValve Centerline 105 deg (WRONG - 103 deg)272 ExhaustMax Valve Lift - 9.8mm (0.3858")Centerline at 0mm vavle lift 111 degExhaust Valve timing at 1mm (0.0394")Valve opens at 34 deg BBDCVavle closes at 0 deg ATDCVavle Centerline 111 deg (WRONG - 107 deg) Link to comment Share on other sites More sharing options...
slowquest Posted February 22, 2010 Report Share Posted February 22, 2010 I'm running the MM pump also, hated the idea of running the hose up over the P/S pump and having that huge pipe running back. http://www.26liter.us/gallery/albums/userpics/10108/car_pics_004.jpg I don't have a pic of the waterpump installed without the tensioner already on though. Link to comment Share on other sites More sharing options...
Fome Posted February 26, 2010 Author Report Share Posted February 26, 2010 couple small updates im getting down to the nitty gritty and small tedious things but had a special delivery by the mail man todayhttp://i625.photobucket.com/albums/tt331/fomes9282/DSC00628.jpg got those put inhttp://i625.photobucket.com/albums/tt331/fomes9282/DSC00629.jpg front of the engine is starting to look like a champhttp://i625.photobucket.com/albums/tt331/fomes9282/DSC00631.jpg finished resault of the replumbfront half of motorhttp://i625.photobucket.com/albums/tt331/fomes9282/DSC00632.jpgback halfhttp://i625.photobucket.com/albums/tt331/fomes9282/DSC00633.jpg Link to comment Share on other sites More sharing options...
Fome Posted February 26, 2010 Author Report Share Posted February 26, 2010 plastic blasted the cam cover and painted the lettering i like ithttp://i625.photobucket.com/albums/tt331/fomes9282/DSC00634.jpg Link to comment Share on other sites More sharing options...
smallblock12 Posted February 26, 2010 Report Share Posted February 26, 2010 im likin it! its finally looking like its supposed to Link to comment Share on other sites More sharing options...
smallblock12 Posted February 26, 2010 Report Share Posted February 26, 2010 so what exactly did you do with the pully setup? Link to comment Share on other sites More sharing options...
Fome Posted February 26, 2010 Author Report Share Posted February 26, 2010 Its a MM crank waterpump and alt pully on (I'm assuming) a DSM alt with a alt relocation kit and a starion power steering pump. But with the MM dampener you can't use a timing belt cover but I like having mine open Link to comment Share on other sites More sharing options...
smallblock12 Posted March 4, 2010 Report Share Posted March 4, 2010 yeah that cover is ugly anyway haha Link to comment Share on other sites More sharing options...
button Posted March 5, 2010 Report Share Posted March 5, 2010 yeah, id like to be able to pick up the rock that just cost me my motor too.I'd highly recommend setting up some sort of timing cover so you don't lose a head to a small object.just my 2 cents Link to comment Share on other sites More sharing options...
Fome Posted March 5, 2010 Author Report Share Posted March 5, 2010 If it were more than just a weekend warrior car and some blasts down the quarter I would worrie about it but seeing as how its not... thanks I appreciate your sarcasm. Ill be sure to drive down a gravel road peeling out in reverse just to try and get gravel in there Link to comment Share on other sites More sharing options...
jwbrocloud Posted March 5, 2010 Report Share Posted March 5, 2010 Haha, nice work man. All the pics you've got here is going to help me out big time with my build. Thank you sir jon Link to comment Share on other sites More sharing options...
Fome Posted March 6, 2010 Author Report Share Posted March 6, 2010 ok havent been slacking just not posted all i have done here is a quick and dirty update here was the exhaust i had 3" stainless DP coupled to 2.5" crushbent http://i625.photobucket.com/albums/tt331/fomes9282/DSC00642.jpg bought a 3" turboback but it was stock starquest style and used the back half of that and welded it to the downpipe for the DSM stylehttp://i625.photobucket.com/albums/tt331/fomes9282/DSC00643.jpg went with a 2 speed radiator fan from a 90-95 taurus it flow 2500 cfm on low speed and 4000 cfm on hihttp://i625.photobucket.com/albums/tt331/fomes9282/DSC00644.jpg ran some relays to activate the fan automaticly from the stock thermosensor low speed comes on at 180 and high at 212also wired a switch under the hood to activate high speed for like when im on the dynohttp://i625.photobucket.com/albums/tt331/fomes9282/DSC00639.jpg while i was over on that fender i relocated all the stock relays (outa site outa mind)http://i625.photobucket.com/albums/tt331/fomes9282/DSC00640.jpg then after looking down in the engine bay i decided i didnt like the stock oil cooler, so...http://i625.photobucket.com/albums/tt331/fomes9282/DSC00636.jpgand -6 lines from the filter housing to the cooler http://i625.photobucket.com/albums/tt331/fomes9282/DSC00641.jpg and my fitting finally came for the -8 to the fuel railhttp://i625.photobucket.com/albums/tt331/fomes9282/DSC00645.jpghttp://i625.photobucket.com/albums/tt331/fomes9282/DSC00646.jpg Link to comment Share on other sites More sharing options...
smallblock12 Posted March 6, 2010 Report Share Posted March 6, 2010 man that fan is insanely close. im likin it tho Link to comment Share on other sites More sharing options...
Fome Posted March 8, 2010 Author Report Share Posted March 8, 2010 I think its time for me to take a little time off from this car. I'm getting down to the nifty gritty and its fighting me the entire way. The worried g on this car is a complete nightmare I tried wiring the wideband to my dsm link and I want to wire the clutch up as well so I can no lift to shift but once again the wireing is a nightmare. I hooked up the battery and turned the key on and am having some other problems elsewere.But anyway I work Mon and Tue and Wed I'm going to Three Rivers Mi to get a new motor for the 86 and I work all weekend this coming weekend so a week off ought to do me good Link to comment Share on other sites More sharing options...
