Indiana Posted January 19, 2010 Report Share Posted January 19, 2010 Did you look at the crank pulley? Does it wobble? Link to comment Share on other sites More sharing options...
JoeyLeet2 Posted November 30, 2010 Author Report Share Posted November 30, 2010 Okay so we found out the problem and I figure I should tell you all what it was since you tried to help. Imagine our faces when we remove the timing cover and see this! http://i56.tinypic.com/24deyo0.jpg Okay so it might not be hard to tell. but the bolt was broken off! of that upper chain guide. The threads were stuck in the block and the collared bolt was just sitting in the chain guide. Anyone see crap like this before?? Link to comment Share on other sites More sharing options...
Indiana Posted December 1, 2010 Report Share Posted December 1, 2010 Yes and its because that bolt, someone didn't put the lock washer in the proper location and it was against the bolt head and then it locks the guide from being able to pivot and it causes the bolt to loosen and it screws out until it is snapped off. The washer is to go against the block side on top of the timing chain guide and its to lock the bolt from coming out but the guide will still pivot because the collar sticks out just a little bit past the guide. http://www.b2600turbo.com/images/IM000234.JPGhttp://www.b2600turbo.com/images/IM000236.JPG http://www.b2600turbo.com/images/IM000259.JPG http://www.b2600turbo.com/TSBs/26%20pump%20chain1.jpghttp://www.b2600turbo.com/TSBs/26%20pump%20chain2.jpghttp://www.b2600turbo.com/TSBs/26%20pump%20chain4.jpg Link to comment Share on other sites More sharing options...
JoeyLeet2 Posted October 26, 2011 Author Report Share Posted October 26, 2011 stupid question maybe, but would a balance shaft elim kit fix this problem? are there any kits that re route the chain away from that broken guide, would love to avoid pulling the motor Link to comment Share on other sites More sharing options...
Shelby Posted October 26, 2011 Report Share Posted October 26, 2011 stupid question maybe, but would a balance shaft elim kit fix this problem? are there any kits that re route the chain away from that broken guide, would love to avoid pulling the motor deff go the bal shaft elim kit direction odds are the bal shaft brgs are damage'd any wayand the engine would not need to be pull'd for any of this,, now the rad , will need to be remove'd Link to comment Share on other sites More sharing options...
JoeyLeet2 Posted October 26, 2011 Author Report Share Posted October 26, 2011 well i took the radiator out and fixed that broken bolt with a helicoil, but that broke again after a 3 mile test drive cause its so cheap. but it was still a tight fit to get a drill in there. so would a BSEK fix this problem? because thats a heck of a lot cheaper than a new block. Link to comment Share on other sites More sharing options...
psu_Crash Posted October 27, 2011 Report Share Posted October 27, 2011 Don't bother with that bolt and guide anymore. Get the broken bolt out and install a BSE kit befor you run it again! Then hopefully it will be fine Link to comment Share on other sites More sharing options...
JoeyLeet2 Posted October 27, 2011 Author Report Share Posted October 27, 2011 so i didnt even need to try to fix that guide with the helicoil? i could have just gotten the elim kit? GULL DERN IT Link to comment Share on other sites More sharing options...
psu_Crash Posted October 27, 2011 Report Share Posted October 27, 2011 so i didnt even need to try to fix that guide with the helicoil? i could have just gotten the elim kit? GULL DERN IT Yup Link to comment Share on other sites More sharing options...
JoeyLeet2 Posted October 27, 2011 Author Report Share Posted October 27, 2011 shoot! why didnt anybody tell me haha i feel like an idiot. car has been down for months for no reason! driving season is almost ova! Link to comment Share on other sites More sharing options...
Indiana Posted October 27, 2011 Report Share Posted October 27, 2011 Look at the gear on the end of your balance shaft and the one on the oil pump. The gears are the same but one goes on one direction and the other is opposite. If not positioned correctly the chain will not run in the guides and will jump. For that guide to have fallen down that far, wasn't the lower bolt missing from it too? Link to comment Share on other sites More sharing options...
JoeyLeet2 Posted October 28, 2011 Author Report Share Posted October 28, 2011 No, but the lower bolt wasn't exactly tight. the chain guide was basically hanging down and resting/bouncing off the chain, and using the loose lower bolt as a pivot point Link to comment Share on other sites More sharing options...
Shelby Posted October 28, 2011 Report Share Posted October 28, 2011 the vibration is the bal shafts being out of time, due to the loose chain from the guide not being in place when doing a bal shaft elim,,both bal shafts are remove'd so there is nothing on the frt to get into time other then the cam chain,,DO NOT forget to install the cam brg in the kit into the upper shaft hole , and follow the instructions to the letter,, there are a number of threads detailing how to install an elim kit Link to comment Share on other sites More sharing options...
JoeyLeet2 Posted October 29, 2011 Author Report Share Posted October 29, 2011 (edited) Thank you Shelby and Indiana. Sounds stupid but I lost my job because I couldn't get there when the Quest broke. Gonna see if my family wants to buy me the BSE for a holidays present if I need too lol. Hopefully I will be able to do the BSE at some point, and if I do, I will let you all know how the engine is. I'm hoping all will be well, anybody have input? I put gas saver additive crap in it cause i knew itd be sittingcar has a new complete cylinder headbottom end looked spotless with the oil pan off, as well as very fresh and clean cyl. wallsclutch with less than 10k and obviously new trans fluidbrand new turbo2.5 in dpall fuses checked for burns, all electronics work except the blinkers dont blinkcomplete tune up all done by myself after extensive reading on every subjects by you fine fellas. Think this should be her last problem?? lets hope Edited October 29, 2011 by JoeyLeet Link to comment Share on other sites More sharing options...
Shelby Posted October 30, 2011 Report Share Posted October 30, 2011 well if the car is gona be down for any length of time,, put the oil pan and frt cover loosely back in place,, only a couple bolt's need'd on the oil pan just to keep out dirt and varmits Link to comment Share on other sites More sharing options...
JoeyLeet2 Posted October 10, 2015 Author Report Share Posted October 10, 2015 Ended up having to sell that Quest due to bills piling up and my mom declaring it junk. I think I sold it off for $250, with a huge list of new parts. Now, four years later, with a much better head on my shoulders, I bought a '88 Starion with 75k miles on it. Cant stay away from these cars! Link to comment Share on other sites More sharing options...
