natedog_37 Posted June 20, 2008 Report Share Posted June 20, 2008 The hood latch will not open the hood. I opened it maybe 5 min closed it took the car for a drive, and now it will not open. I tried to pull on the cable connected to the latch but nothing. Hood has very little play. I can't lift the hood up, our push the hood down. Tried some WD40 but still nothing. There seems to be a ton of slack in the cable since the hood latch is simple to move. Any ideas on how to get my hood open..... Link to comment Share on other sites More sharing options...
jd_stazza_brendan Posted June 20, 2008 Report Share Posted June 20, 2008 Crawl under the car and try get to the bottom of the latch by hand. Link to comment Share on other sites More sharing options...
natedog_37 Posted June 20, 2008 Author Report Share Posted June 20, 2008 jd_stazza_brendan said: Crawl under the car and try get to the bottom of the latch by hand. trying. I searched and I found that but man I am not a small man and my arms are to big. I am going to try to go up from behind the rad. But right now it is to hot. Link to comment Share on other sites More sharing options...
rosengrant826 Posted June 20, 2008 Report Share Posted June 20, 2008 this happend to me a few days ago...i ended up taking the front grill peice out and reaching up and behind with a screwdriver to push the latch up....good luck .... its a hard spot to get to Link to comment Share on other sites More sharing options...
BrokenquestTSI Posted June 20, 2008 Report Share Posted June 20, 2008 (edited) that happend to me, and my friend (workinprogress) went up underneath with a huge crow bar thingy i bought, (or you could use a long scewdriver) and somehow popped it open. i tried it a million times and couldnt get it but he did in like 5 mins. Now i got it rigged up in the front witht the cable so i have to open it from that hanging behind the airdamn on the drivers side. i would suggest trying that, but like i said, i never got it. my friend did. Good luck man. -Broken Edited June 20, 2008 by BrokenquestTSI Link to comment Share on other sites More sharing options...
natedog_37 Posted June 20, 2008 Author Report Share Posted June 20, 2008 BrokenquestTSI said: that happend to me, and my friend (workinprogress) went up underneath with a huge crow bar thingy i bought, (or you could use a long scewdriver) and somehow popped it open. i tried it a million times and couldnt get it but he did in like 5 mins. Now i got it rigged up in the front witht the cable so i have to open it from that hanging behind the airdamn on the drivers side. i would suggest trying that, but like i said, i never got it. my friend did. Good luck man. -Broken Got a pic of how you rigged it up? I want to do this. I am going to give it another try tonight. I needed to let the car cool down, and my temper was flairing. I need to get a crow bar I think. I am hoping I can get my hand up there behind the Rad. Link to comment Share on other sites More sharing options...
BrokenquestTSI Posted June 20, 2008 Report Share Posted June 20, 2008 ill take a pic of it when i go to my moms and see my car if you want. My friend just tied the cable up around whatever he pushed up with the cro bar, but like i said, he did it for me. I'll snap a pic with the cable just the way it is, then when the cables pulling the latch to open it. ill get back to you whenever i get over there. hopefully today. Link to comment Share on other sites More sharing options...
JAinsworth Posted June 20, 2008 Report Share Posted June 20, 2008 You can take a looongg screwdriver and attack it from underneath. The latch needs to be pushed from the engine side and towards the driver's door. Jimmy Link to comment Share on other sites More sharing options...
natedog_37 Posted June 20, 2008 Author Report Share Posted June 20, 2008 JAinsworth said: You can take a looongg screwdriver and attack it from underneath. The latch needs to be pushed from the engine side and towards the driver's door. Jimmy I had what I though was a long screw driver but I guess it wasn't. I can't get my hands up above the intercooler, our next to it they are to big. GOD I LOVE BEING FAT> hahahah Thanks for all the help I am going to give it another shoot tonight. Glad this is a fun car.. Link to comment Share on other sites More sharing options...
natedog_37 Posted June 21, 2008 Author Report Share Posted June 21, 2008 1 1/2 hours under the car and it is still closed!!! UGH. At this rate I am going to say screw it and leave it close. Link to comment Share on other sites More sharing options...
Indiana Posted June 21, 2008 Report Share Posted June 21, 2008 I never tried it from under the car but if he grill is out an you remove the bolts you can see in the header panel it will pull out enough to get your arms in the gap, you'll feel a tab sticking down and its what needs to move to the left side of the car you can get new clips for the grill if they break, and usually do, they are about $1 if you don't have a replacement cable in the mean time you can bend a coat hanger and attach it to that folded down arm and run it through the grill and bend it backwards and have a loop sticking out Link to comment Share on other sites More sharing options...
natedog_37 Posted June 21, 2008 Author Report Share Posted June 21, 2008 Got the stupid thing. I had the grill off but I have hard charge pipes and my hands are to fat to get up there. I used the rod from the vertical shades in the garage. Took me 30 sec. !!!! Thanks Indiana I am going to rig it like that and leave it after I have a cable just in case. Link to comment Share on other sites More sharing options...
JAinsworth Posted June 21, 2008 Report Share Posted June 21, 2008 natedog, I believe Dad sells the cable. Leave the old one in until you get the new one. Then you can just tape the new one to the old one and pull it through to the inside. Jimmy Dad's Site for Conquest Parts Link to comment Share on other sites More sharing options...
89PalermoSHP Posted June 21, 2008 Report Share Posted June 21, 2008 Ill have to keep this pic handy... this is the third or so similar topic. Heres what youll see from the bottom(the top of the pic face the front of the car) http://i177.photobucket.com/albums/w202/89PalermoSHP/plate1.jpg Coming in behind the radiator wont do you any good. Look up between the front bumper and intercooler. Ive got a set of the craftsman prybars that have the red screwdriver hanle that probably would be long enough. Link to comment Share on other sites More sharing options...
natedog_37 Posted June 21, 2008 Author Report Share Posted June 21, 2008 (edited) Yeah I didn't pull the old one off yet I just hooked a cable to the level ran it down to the Front Driver side tow hook. I used a bolt, and 2 washers. Put the bolt though the tow hook. Put a washer on the bolt. Tie the cable to the bolt, and then another washer, and then a lock nut. Made it really tigh and I have a way now to open the hood. and I know the cable is not going anywere. I will order the new cable from Dad this week. Thanks everyone for the help. Edited June 21, 2008 by natedog_37 Link to comment Share on other sites More sharing options...
BrokenquestTSI Posted June 22, 2008 Report Share Posted June 22, 2008 how difficult is it to do if you already pulled the cable through....? (i know, im an idiot) Quote At this rate I am going to say screw it and leave it close. you never want to do this, thats what i did and look at my car. (unless theirs nothing wrong with your engine) glad you got it. -Broken Link to comment Share on other sites More sharing options...
