brogers Posted April 17, 2008 Report Share Posted April 17, 2008 Does anyone else have trouble keeping their tilt steering column locked in position? Mine always loosens up while driving. Link to comment Share on other sites More sharing options...
Wolf87Conquest Posted April 17, 2008 Report Share Posted April 17, 2008 I've never experianced this....but can be quite dangerous I'd think. I'm not real sure how the mechanism is on the StarQuest, but it sounds to me like a missing or worn spring is the problem area. Take the bottom dash cover (under column) and steering column cover off...then with a flashlight, try adjusting the wheel to see what's going on. Anything looking worn or out of place should be evident as you adjust it. There could be a exploded view or pics of how this mechanism is on Starquestgarage.com...don't know for sure, but worth a try. Good luck Link to comment Share on other sites More sharing options...
starionheaven Posted April 17, 2008 Report Share Posted April 17, 2008 I've never experianced this....but can be quite dangerous I'd think. I'm not real sure how the mechanism is on the StarQuest, but it sounds to me like a missing or worn spring is the problem area. Take the bottom dash cover (under column) and steering column cover off...then with a flashlight, try adjusting the wheel to see what's going on. Anything looking worn or out of place should be evident as you adjust it. There could be a exploded view or pics of how this mechanism is on Starquestgarage.com...don't know for sure, but worth a try. Good luck Theres an easy repair step to fix this and requires u to take nothing apart. Grab a set of Vice Grip pliers and pull the tilt lever out as if u were trying to adjust it. Now lock those pliers at the end and bend it to the left slightly. Push it back in and see if it fixes it. If not pull it back out and bend it a little more until it stops. Common problem and this method was found by old gangster starquest owner Buzzkill Link to comment Share on other sites More sharing options...
Dad Posted April 17, 2008 Report Share Posted April 17, 2008 Theres an easy repair step to fix this and requires u to take nothing apart. Grab a set of Vice Grip pliers and pull the tilt lever out as if u were trying to adjust it. Now lock those pliers at the end and bend it to the left slightly. Push it back in and see if it fixes it. If not pull it back out and bend it a little more until it stops. Common problem and this method was found by old gangster starquest owner Buzzkill I did that exactly and it worked for Me. i suggest you loosen the lock nut and remove the plastic lever first so you don't break it. Dad Link to comment Share on other sites More sharing options...
brogers Posted April 17, 2008 Author Report Share Posted April 17, 2008 I'll give it a shot, thanks, let u know if it actually worked. Link to comment Share on other sites More sharing options...
SOTTY Posted April 17, 2008 Report Share Posted April 17, 2008 My 89 did this yet never had this problem with the earlier design of tilt wheel, scary when your steering wheel falls in your lap at 130 plus isnt it! ive recently replaced mine from a parts car and so far so good. Link to comment Share on other sites More sharing options...
brogers Posted April 17, 2008 Author Report Share Posted April 17, 2008 :thumbsup: Vise grips and a little bend to the left, problem solved. Thanks all! Link to comment Share on other sites More sharing options...
SOTTY Posted April 17, 2008 Report Share Posted April 17, 2008 :thumbsup: Vise grips and a little bend to the left, problem solved. Thanks all! x2. Link to comment Share on other sites More sharing options...
