Montero owners
white quest ky
Im taking delivery on bryan vaughans (cyberquests) montero next week and i was curious as to what you guys have done other than fuel injecting or turbocharging to squeeze some power out any input would be appreciated
Kendall wrench
If you want it to run well, don't "F" with the factory carburetor. It has a pretty well designed exhaust manifold so a header is not absolutely necessary but may help a little. You'll get a pretty good gain by going with a weber conversion but the Montero you're getting runs very well as is. Pat the gas twice and she'll fire right up every time. Personally having owned this one, if I weren't going turbo, I wouldn't mess with it. Even if you hop the engine up, it's still gonna be slow.
Kane
Im not gonna do anything till the motor blows then its gettin multiport and turbocharged from a conquest motor im gonna start putting building next week tax returns helped me alot but i just wanna have some fun in,it without goin off road i have an 84 toyota thats a trail rig and the first rule of muddin is dont take a dd off road ha
I have run TBI N/A, MPI N/A and both turbo. as well as some hiticitch carb crap that came with it from some other hack job instaling it. The MPI N/A ran by far the best of the N/A setups. I run 4 diff turbos on them. A smaller turbo is what I would put on it if you did go that way. As for N/A power clean up the heads and port match all the manifolds will help. Mill the head a bit.
Here is a link to a dyno with header and cam. + Weber. Was done on a 4 wheel dyno.http://www.26liter.us/gallery/albums/userpics/12127/NA_Montero_dyno_2_6_with_after_market_cam.jpg
Edited by TainterRacing
  • 3 weeks later...
Built myself a strong, daily driven, normally aspirated, 2.6L Astron engine mid last year.
CR was around 9.5:1
My build thread (on Sigma-Galant.com)
Used motorbike carbs instead of the standard carb choices.
http://users.tpg.com.au/ntome44/SG/Motorbike_carbs/38mm-top.jpg
My last dyno..
http://users.tpg.com.au/ntome44/SG/DYNO/dyno-thornleigh.jpg
I've since fixed up the AF ratio's between 2500 and 3500 but haven't re-dyno'd it yet.
It's around 133HP at the wheels.
Cheers.
